FXS extension with trans coding not working
kotushaMx
I recently setup trans coding for the AA to work, but the FXS extensions no longer work, this is the configuration, if you can point to get them to work again I will greater appreciated, thank you.
************Transcoder part************************
voice-card 0
 dspfarm
 dsp services dspfarm
sccp local GigabitEthernet0/1
sccp ccm 172.16.1.1 identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
 bind interface GigabitEthernet0/1
 associate ccm 1 priority 1
 associate profile 1 register MTP881dfcdf4502
dspfarm profile 1 transcode
 description Hardware Transcoder
 codec g711alaw
 codec g711ulaw
 codec pass-through
 maximum sessions 30
 associate application SCCP
telephony-service
 sdspfarm units 10
 sdspfarm transcode sessions 30
 sdspfarm tag 1 MTP881dfcdf4502
************FXS Voice Extentions not working************************
voice-port 0/0/0
 timeouts ringing infinity
 caller-id enable
dial-peer voice 1 pots
  destination-pattern 128
  port 0/0/0
3 Accepted Solutions
Jonathan Schulenberg
Codec pass-through on a transcoder is an odd choice; however, you shouldn’t need a transcoder on analog or TDM ports. They already have a DSP invoked for the conversion to IP. Configure whichever codec you need from the start.
I doubt that your issue with call from/to the FXS ports is related to that you configured a transcoder. Please collect debugs for FXS port troubleshooting and post it here if you require help on this.
Response Signature
Logs are necessary to have any clue. In the transcoder, add G729 as well, and you can avoid using pass-through as @Jonathan Schulenberg  mentioned.
Response Signature
6 Replies 6
Response Signature
kotushaMx
thank you I will check I let you know. Thank you very much.
Response Signature
kotushaMx
thank you very much to everybody, the problem was the fxs card itself, after I replace it everything work fine.
kotushaMx
the problem was that after finishing setting up trans-coding stop working, probably after reboot the card stop  working.
Thank you.
