Gateway 2921 Incoming Calls CUCM
Hello Friends,
I´m working with CUCM. Last friday incoming calls don´t work in gateway 2921, however out calls and internal calls don´t have problem. Principal number is 756 2300. Exist translation rules into 2921 and CUCM, this is 6300.
Do you think pattern XX is the problem? Any idea?
Please, watch configuration...
GW_2921#show run
Building configuration...
Current configuration : 8344 bytes
! Last configuration change at 12:17:33 GMT Tue Oct 16 2012
! NVRAM config last updated at 19:29:33 GMT Fri Oct 12 2012
version 15.2
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service sequence-numbers
hostname GW_2921
boot-start-marker
boot system flash c2900-universalk9-mz.SPA.152-3.T.bin
boot-end-marker
card type e1 0 0
no logging queue-limit
logging buffered 3000000
no logging rate-limit
no logging console
no logging monitor
enable secret 5 $1$0G7D$cbDUzq1z3nz9ktwETPT6E.
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
clock timezone GMT -4 0
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
no ipv6 cef
ip domain name GW_CHILE.com
ip cef
isdn switch-type primary-net5
crypto pki trustpoint TP-self-signed-1160206030
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1160206030
revocation-check none
rsakeypair TP-self-signed-1160206030
crypto pki certificate chain TP-self-signed-1160206030
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31313630 32303630 3330301E 170D3132 30343230 31333134
  30375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 31363032
  30363033 3030819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100C37F 301CEEB2 226CADA8 C7C278B4 4B199E71 A34D14E4 A6DB9836 397B0000
  06A5ADB0 078C4054 3198C01A 6BEA920C 5A13F97E 22AC1B9C 729FCD64 499737A4
  31CBAAF5 F3C42051 9785609A B2AFB156 90A7E7E1 0A392421 AAC5AF62 8C03AD08
  229E0275 88CCFD8B F935CF73 56DBD7F6 F75EE94B B18B38BC AFD0239D FCC73C18
  763D0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 14361D3E 466F90B0 880BBA46 E4FAC251 0FD9A717 86301D06
  03551D0E 04160414 361D3E46 6F90B088 0BBA46E4 FAC2510F D9A71786 300D0609
  2A864886 F70D0101 05050003 81810004 557ECF4C 85A435DF E654E9C5 4D7AD6A4
  634F40BE 3C80B7D0 C93AB016 6EA77C99 945D4312 F9A54E68 E9438D12 84511FA8
  44BE9350 BF648F77 83EA98A9 6D60E32E E2F0B57B 48E9BC32 26A79DE9 FEDF34F1
  C1A7462F E52327DC 91C409EB 69CD7E4C 86C48AED 743BB520 97F40AFA 279920BB
  5214CB61 6488EF93 0306EC39 14239B
        quit
voice-card 0
dspfarm
dsp services dspfarm
voice call send-alert
voice call convert-discpi-to-prog
voice call carrier capacity active
voice rtp send-recv
voice dsp release early
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-thro
h323
  h225 connect-passthru
sip
  registrar server
voice translation-rule 1
rule 2 /2331/ /6309/
rule 3 /2301/ /6301/
rule 4 /2300/ /6302/
rule 5 /2330/ /6303/
rule 6 /2302/ /6304/
rule 7 /2323/ /6305/
rule 8 /2304/ /6306/
rule 9 /2315/ /6307/
rule 10 /2329/ /6308/
rule 11 /2305/ /6310/
rule 12 /2322/ /6311/
rule 13 /2318/ /6312/
rule 14 /2328/ /6313/
rule 15 /2309/ /6314/
rule 16 /2311/ /6315/
rule 17 /2303/ /6316/
rule 18 /2317/ /6317/
rule 19 /2319/ /6318/
rule 20 /2307/ /6319/
rule 21 /2306/ /6320/
rule 22 /2308/ /6321/
rule 23 /2313/ /6322/
rule 24 /2312/ /6323/
voice translation-profile Ingreso_SRST
translate called 1
application
global
  service alternate Default
license udi pid CISCO2921/K9 sn FTX1610AL8K
hw-module ism 0
hw-module pvdm 0/0
username admin privilege 15 secret 5 $1$zhNp$tBfY0wdYdMcYxOrDt0OpF/
username nocjapan privilege 15 secret 5 $1$nSly$Qm1Q1RYNJu1FiHuSCawA50
username pier privilege 15 secret 5 $1$UBzH$oAoSwavpZWkmWtW4iGzcK.
redundancy
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31 service mgcp
description **To PSTN**
ip ssh version 2
interface Loopback0
ip address 10.254.25.1 255.255.255.252
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description "UPLINK_3560"
ip address 172.22.25.250 255.255.255.0
duplex full
speed 1000
h323-gateway voip interface
h323-gateway voip bind srcaddr 172.22.25.250
interface ISM0/0
ip unnumbered Loopback0
service-module ip address 10.254.25.2 255.255.255.252
!Application: CUE Running on ISM
service-module ip default-gateway 10.254.25.1
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface ISM0/1
description Internal switch interface connected to Internal Service Module
no ip address
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bind-l3 ccm-manager
isdn bchan-number-order ascending
no cdp enable
interface Vlan1
no ip address
ip default-gateway 172.22.25.1
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip route 0.0.0.0 0.0.0.0 172.22.25.1
ip route 10.254.25.2 255.255.255.255 ISM0/0
tftp-server flash:cmterm-69xx-sccp.9-2-2-6.cop.sgn
control-plane
voice-port 0/0/0:15
echo-cancel coverage 64
cptone CL
timeouts ringing 5
voice-port 0/1/0
voice-port 0/1/1
ccm-manager fallback-mgcp
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 172.16.2.240
ccm-manager config
mgcp
mgcp call-agent 172.16.2.240 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
no mgcp explicit hookstate
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/0
mgcp bind media source-interface GigabitEthernet0/0
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm 172.16.2.240 identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 2 register HW_XCOD_CL
associate profile 1 register HW_CONF_CL
dspfarm profile 2 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 4
associate application SCCP
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 1
dial-peer voice 1 pots
translation-profile incoming Ingreso_SRST
incoming called-number .
direct-inward-dial
port 0/0/0:15
dial-peer voice 10 pots
description ** Primario dial-peer LOCAL FIJO**
preference 5
destination-pattern 0[2-9]......
direct-inward-dial
port 0/0/0:15
forward-digits 7
no sip-register
dial-peer voice 11 pots
description ** Primario dial-peer MOVIL**
preference 5
destination-pattern 009[6-9].......
port 0/0/0:15
forward-digits 10
no sip-register
gatekeeper
shutdown
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 172.22.25.250 port 2000
max-ephones 30
max-dn 60
line con 0
exec-timeout 5 0
logging synchronous
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 131
no exec
transport input all
stopbits 1
line vty 0 4
exec-timeout 5 0
privilege level 15
logging synchronous
transport input all
line vty 5 15
exec-timeout 5 0
privilege level 15
logging synchronous
transport input all
scheduler allocate 20000 1000
ntp source Loopback0
ntp master
end
Hi Claudio,
So to clarify when the VPN is connected you have incoming issues to DNs in Chile when the gateway is registered via MGCP with CallManger in Peru?
If I have understood the above correctly then is fallback SRST inbound is working fine, so the problem I suspect is the translation patterns in CUCM applied to the incoming gateway CSS. Have you confirmed these are in order?
I can see from your updated post that the output indicates that the gateway is unregistered with the CUCM mgcp call agent. I assume that the VPN is connected at this point? This would definitely be an issue if this was true, what is confusing is your statement that outbound calls work when the VPN is up? If the VPN is connected that I would expect ip phones to register to the CUCM in Peru and follow the CUCM route pattern and associated route-list. The route-list would contain a route-group consisting of the mgcp gateway. If you have a second mgcp gateway in this group then it is likely that this is the outgoing gateway,
If ip phones are able to register when the VPN. Is connected the I would look at any rules on the VPN gateway which is possibly restricting mgcp traffic.
Please rate helpful posts. Thank you.
Allan
5 Replies 5
Chris Deren
Please post "debug isdn q931".
Not sure why you stated this is CME as this is a CUCM GW configuration, so also ensure the MGCP GW configuration in CUCM is accurate.
Chris
Cisco Unified CM Administration 7.1.5.33900-10
GW_2921#debug isdn q931
debug isdn q931 is              ON.
GW_2921#show isdn status
Global ISDN Switchtype = primary-net5
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 0. Layer 3 output may not apply
ISDN Serial0/0/0:15 interface
        dsl 0, interface ISDN Switchtype = primary-net5
        L2 Protocol = Q.921 0x0000  L3 Protocol(s) = CCM MANAGER 0x0003
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0xFFFF7FFF
    Number of L2 Discards = 0, L2 Session ID = 50
    Total Allocated ISDN CCBs = 0
Hi Claudio,
Ideally you need to debug isdn q931 during the time that you are having problems with your incoming calls as Chris suggested. This will enable you to determine whether you are having problems with channel availability. The important aspect here is understanding whether the gateway was registered to CUCM or in H.323 fallback state when you had incoming problems? Can you post the show ccm-manager output this will indicate the last mgcp failover event.
I suspect that your gateway was possibly operating in fallback and either there was a channel issue on time-slot 1 which affected all incoming calls on this slot or either your actual translation rules failed to match the digits presented by your carrier. Are you aware of how many digits your carrier is presenting, the debug isdn q931 will indicate this during an incoming call.
Allan
Hi Allan,
2921 is in Chile and CUCM is in Peru. Exist VPN between them, Internal telephony is trought VPN connection. When VPN is out local incoming calls work perfectly and problem dissapear. SRST 2921 works perfectly. When VPN is in, the problem goes on.
Product
H.323 Gateway
H.225
RegistrationUnknown
IPv4 Address172.22.25.250
Provider is sending four digits.
GW_2921#show ccm-manager
MGCP Domain Name: GW_2921.GW_CHILE.com
Priority        Status                   Host
Primary         Down                     172.16.2.240
First Backup    None
Second Backup   None
Current active Call Manager:    None
Backhaul/Redundant link port:   2428
Failover Interval:              30 seconds
Keepalive Interval:             15 seconds
Last keepalive sent:            17:49:42 GMT Oct 19 2012 (elapsed time: 00:02:36
Last MGCP traffic time:         17:49:12 GMT Oct 19 2012 (elapsed time: 00:03:06
Last failover time:             None
Last switchback time:           None
Switchback mode:                Graceful
MGCP Fallback mode:             Enabled/ON
Last MGCP Fallback start time:  17:50:00 GMT Oct 19 2012
Last MGCP Fallback end time:    17:27:13 GMT Oct 19 2012
MGCP Download Tones:            Disabled
TFTP retry count to shut Ports: 2
FAX mode: disable
Configuration Error History:
no network-clock-participate wic 0
end
Hi Claudio,
Allan
