H323 FXO incoming call issue...
VLT06
Level 3
Level 3
Hi Guys,
Got a weird one where an incoming call just ring out for the caller however no CUCM phones are ringing etc…
When I programmed as MGCP, worked fine in and out. But when I reprogrammed as H323, incoming call rings out without any of the CUCM phones ringing. Can dial out ok from the phones though.
Have checked dial peers over and over again and also CUCM translation but still can’t seem to get going… Anyone come across a similar issue?
Debug shows nothing out of the norm...
voice-port 0/0/0
 supervisory disconnect dualtone mid-call
 output attenuation -4
 cptone AU
 timeouts call-disconnect 2
 timeouts wait-release 2
 connection plar opx 52321191
 impedance complex1
 description indial 0352321191
 caller-id enable
dial-peer voice 10 voip
 preference 1
 destination-pattern 52321191
 translate-outgoing calling 1
 session target ipv4:XX.XX.XXX.XX
 voice-class codec 100
 voice-class h323 1
 dtmf-relay h245-alphanumeric
 ip qos dscp cs5 media
 no vad
TAG    TYPE  MIN  OPER PREFIX    DEST-PATTERN      FER THRU SESS-TARGET    STAT PORT    KEEPALIVE
100    pots  up   up             0T                 1                      up   0/0/0
102    pots  up   up             0T                 2                      up   0/0/1
103    pots  up   up             0T                 3                      up   0/0/2
10     voip  up   up             52321191           1  syst ipv4:XX.XX.XXX.XX
11     voip  up   up             52321191           2  syst ipv4:XX.XX.XXX.XX
7 Replies 7
Manish Gogna
Hi James,
Can you uncheck "Wait for Far End H.245 Terminal Capability Set " on the h323 gateway, reset it and then check if it works.
Manish
- Do rate helpful posts -
Thanks Manish,
Yeah, still the same.
A colleague of mine was also doing some tracing and it looks at the moment that the router is not communicating to the CUCM on and incoming perspective. Can see traffic back to other way (CUCM -> Router)... Very odd....
Hi James,
You can take the output of the following debug
debug ip tcp transactions
Also, a restart of the ccm service on cucm if possible to reinitialize the h225D process.
Manish
Please post your router config.
Voice config as follows;
voice-card 0
  dsp services dspfarm
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 supplementary-service ringback h225-info
 no ip address trusted authenticate
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
voice class codec 100
 codec preference 1 g729r8
 codec preference 2 g711alaw
 codec preference 3 g711ulaw
voice class h323 1
  h225 timeout tcp establish 3
translation-rule 1
 Rule 1 ^0.% 0
 Rule 2 ^1.% 001
 Rule 3 ^2.% 002
 Rule 4 ^3.% 003
 Rule 5 ^4.% 004
 Rule 6 ^5.% 005
 Rule 7 ^6.% 006
 Rule 8 ^7.% 007
 Rule 9 ^8.% 008
 Rule 10 ^9.% 009
interface Loopback5
 no snmp trap link-status
 h323-gateway voip interface
 h323-gateway voip bind srcaddr 10.184.72.1
voice-port 0/0/0
 cptone AU
 impedance complex1
voice-port 0/0/1
 cptone AU
 impedance complex1
 description indial 0352322547
voice-port 0/0/2
 cptone AU
 impedance complex1
 description indial 0352321834
ccm-manager music-on-hold
dial-peer voice 100 pots
 preference 1
 destination-pattern 0T
 direct-inward-dial
 port 0/0/0
dial-peer voice 102 pots
 preference 2
 direct-inward-dial
 port 0/0/1
dial-peer voice 103 pots
 preference 3
 direct-inward-dial
 port 0/0/2
 preference 1
 session target ipv4:XXX.XXX.XXX.XXX
 voice-class h323 1
 no vad
dial-peer voice 11 voip
 preference 2
 voice-class h323 1
 no vad
call-manager-fallback
 secondary-dialtone 0
 max-conferences 8 gain -6
 transfer-system full-consult
 ip source-address XXX.XXX.XXX.XXX port XXXX
 max-ephones 50
 max-dn 300 dual-line
 transfer-pattern .T
 alias 1 52321191 to 90020 timeout 60
 moh-file-buffer 4000
 moh flash:AdelaideBankMOH.ulaw.wav
 multicast moh XXX.XXX.XXX.XXX port 16384 route XXX.XXX.XXX.XXX
 time-zone 50
 time-format 24
 date-format dd-mm-yy
sccp local Loopback5
sccp ccm XXX.XXX.XXX.XXX identifier 2 version 7.0
sccp ccm XXX.XXX.XXX.XXX identifier 1 version 7.0
sccp
sccp ccm group 1
 associate ccm 1 priority 1
 associate ccm 2 priority 2
 associate profile 1 register br1-q27_cfb
 keepalive timeout 10
 switchback method immediate
 switchback interval 1
dspfarm profile 1 conference
 codec g729br8
 codec g729r8
 codec g729abr8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 maximum sessions 5
 associate application SCCP
Interesting....
Dubug shows nothing for inbound call only for outbound call as follows;
Jul  7 07:03:41.820 aest: TCBC1AB0A18 created
Jul  7 07:03:41.820 aest: TCBC1AB0A18 setting property TCP_NO_DELAY (0) 2B3F9F94
Jul  7 07:03:41.820 aest: TCBC1AB0A18 setting property TCP_NONBLOCKING_WRITE (10) 2B3FA050
Jul  7 07:03:41.820 aest: TCBC1AB0A18 setting property TCP_NONBLOCKING_READ (14) 2B3FA050
Jul  7 07:03:41.820 aest: TCBC1AB0A18 setting property TCP_TOS (11) 2B3FA038
Jul  7 07:03:41.820 aest: TCP: Random local port generated 58697, network 1
Jul  7 07:03:41.820 aest: TCBC1AB0A18 bound to 10.184.72.65.58697
Jul  7 07:03:41.820 aest: Reserved port 58697 in Transport Port Agent for TCP IP type 1
Jul  7 07:03:41.820 aest: TCP: sending SYN, seq 4262580139, ack 0
Jul  7 07:03:41.820 aest: TCP0: Connection to 10.32.4.9:9001, advertising MSS 536
Jul  7 07:03:41.820 aest: TCP0: state was CLOSED -> SYNSENT [58697 -> 10.32.4.9(9001)]
Jul  7 07:03:41.820 aest: TCB41DCC090 created
Jul  7 07:03:41.820 aest: TCB41DCC090 setting property TCP_NO_DELAY (0) 2B3F9F94
Jul  7 07:03:41.820 aest: TCB41DCC090 setting property TCP_NONBLOCKING_WRITE (10) 2B3FA050
Jul  7 07:03:41.820 aest: TCB41DCC090 setting property TCP_NONBLOCKING_READ (14) 2B3FA050
Jul  7 07:03:41.820 aest: TCB41DCC090 setting property TCP_TOS (11) 2B3FA038
Jul  7 07:03:41.820 aest: TCP: Random local port generated 48049, network 1
Jul  7 07:03:41.820 aest: TCB41DCC090 bound to 10.184.72.65.48049
Jul  7 07:03:41.820 aest: Reserved port 48049 in Transport Port Agent for TCP IP type 1
Jul  7 07:03:41.820 aest: TCP: sending SYN, seq 2480795731, ack 0
Jul  7 07:03:41.820 aest: TCP0: Connection to 10.32.136.59:445, advertising MSS 536
Jul  7 07:03:41.820 aest: TCP0: state was CLOSED -> SYNSENT [48049 -> 10.32.136.59(445)]
Jul  7 07:03:41.848 aest: TCP0: state was SYNSENT -> ESTAB [58697 -> 10.32.4.9(9001)]
Jul  7 07:03:41.848 aest: TCP: tcb C1AB0A18 connection to 10.32.4.9:9001, peer MSS 1370, MSS is 536
Jul  7 07:03:41.852 aest: TCP0: state was ESTAB -> FINWAIT1 [58697 -> 10.32.4.9(9001)]
Jul  7 07:03:41.852 aest: TCP0: sending FIN
Jul  7 07:03:41.852 aest: TCP0: state was SYNSENT -> ESTAB [48049 -> 10.32.136.59(445)]
Jul  7 07:03:41.852 aest: TCP: tcb 41DCC090 connection to 10.32.136.59:445, peer MSS 1370, MSS is 536
Jul  7 07:03:41.856 aest: TCP0: state was ESTAB -> FINWAIT1 [48049 -> 10.32.136.59(445)]
Jul  7 07:03:41.856 aest: TCP0: sending FIN
Jul  7 07:03:41.856 aest: TCB41E30814 created
Jul  7 07:03:41.856 aest: TCB41E30814 setting property TCP_NO_DELAY (0) 2B3FA024
Jul  7 07:03:41.856 aest: TCB41E30814 setting property TCP keepalive timeout (17) 2B3FA0E0
Jul  7 07:03:41.856 aest: TCB41E30814 setting property TCP_NONBLOCKING_WRITE (10) 2B3FA0E0
Jul  7 07:03:41.856 aest: TCB41E30814 setting property TCP_NONBLOCKING_READ (14) 2B3FA0E0
Jul  7 07:03:41.856 aest: TCB41E30814 setting property TCP_REUSEADDR (13) 2B3FA0E4
Jul  7 07:03:41.856 aest: TCB41E30814 setting property TCP_TOS (11) 2B3FA0C8
Jul  7 07:03:41.856 aest: TCP: Random local port generated 43802, network 1
Jul  7 07:03:41.856 aest: TCB41E30814 bound to 10.160.0.35.43802
Jul  7 07:03:41.856 aest: Reserved port 43802 in Transport Port Agent for TCP IP type 1
Jul  7 07:03:41.856 aest: TCP: sending SYN, seq 743252, ack 0
Jul  7 07:03:41.856 aest: TCP0: Connection to 10.32.4.16:4080, advertising MSS 536
Jul  7 07:03:41.856 aest: TCP0: state was CLOSED -> SYNSENT [43802 -> 10.32.4.16(4080)]
Jul  7 07:03:41.924 aest: TCP0: state was FINWAIT1 -> FINWAIT2 [58697 -> 10.32.4.9(9001)]
Jul  7 07:03:41.924 aest: TCP0: FIN processed
Jul  7 07:03:41.924 aest: TCP0: state was FINWAIT2 -> TIMEWAIT [58697 -> 10.32.4.9(9001)]
Jul  7 07:03:41.932 aest: TCP0: state was SYNSENT -> ESTAB [43802 -> 10.32.4.16(4080)]
Jul  7 07:03:41.932 aest: TCP: tcb 41E30814 connection to 10.32.4.16:4080, peer MSS 1370, MSS is 536
Jul  7 07:03:41.940 aest: TCP0: state was FINWAIT1 -> FINWAIT2 [48049 -> 10.32.136.59(445)]
Jul  7 07:03:41.940 aest: TCP0: FIN processed
Jul  7 07:03:41.940 aest: TCP0: state was FINWAIT2 -> TIMEWAIT [48049 -> 10.32.136.59(445)]
Jul  7 07:03:42.464 aest: TCP0: FIN processed
Jul  7 07:03:42.464 aest: TCP0: state was ESTAB -> CLOSEWAIT [43802 -> 10.32.4.16(4080)]
Jul  7 07:03:42.464 aest: TCP0: state was CLOSEWAIT -> LASTACK [43802 -> 10.32.4.16(4080)]
Jul  7 07:03:42.464 aest: TCP0: sending FIN
Jul  7 07:03:42.492 aest: TCP0: Got ACK for our FIN
Jul  7 07:03:42.492 aest: TCP0: state was LASTACK -> CLOSED [43802 -> 10.32.4.16(4080)]
Jul  7 07:03:42.492 aest: Released port 43802 in Transport Port Agent for TCP IP type 1 delay 240000
Jul  7 07:03:42.492 aest: TCB 0x41E30814 destroyed
Jul  7 07:03:53.824 aest: TCP0: timewait timeout timer expired
Jul  7 07:03:53.824 aest: TCP0: state was TIMEWAIT -> CLOSED [1720 -> 10.32.184.11(60032)]
Jul  7 07:03:53.824 aest: TCB 0x2B44AF9C destroyed
Jul  7 07:04:41.923 aest: TCP0: timewait timeout timer expired
Jul  7 07:04:41.923 aest: Released port 58697 in Transport Port Agent for TCP IP type 1 delay 0
Jul  7 07:04:41.923 aest: TCP0: state was TIMEWAIT -> CLOSED [58697 -> 10.32.4.9(9001)]
Jul  7 07:04:41.923 aest: TCB 0xC1AB0A18 destroyed
Jul  7 07:04:41.939 aest: TCP0: timewait timeout timer expired
Jul  7 07:04:41.939 aest: Released port 48049 in Transport Port Agent for TCP IP type 1 delay 0
Jul  7 07:04:41.939 aest: TCP0: state was TIMEWAIT -> CLOSED [48049 -> 10.32.136.59(445)]
Jul  7 07:04:41.939 aest: TCB 0x41DCC090 destroyed
R M
I have a very similar issue. Were you ever able to resolve it?
