Log on failed on Cisco Unity Connection
I attempt to login in my Cisco unity Connection version 10.5 system but it's failed.
Also I have lost the ssh password which permit to join the cli command.
Please can you help me to solve it?
Aristide
6 Replies 6
Jaime Valencia
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/8x/os_administration/guide/8xcucosagx/8xcucosag020.html
Then you can reset the GUI admin once you're able to login via CLI.
java
if this helps, please rate
Hi Jaime,
 Thank you for your reply. What CD can I use? Any or CUC CD.
The CUC is intalled on a BE6000 server.
Aristide
Hi Aristide,
Just to follow up on what Java nicely linked (+5 - "J")
Yes a CUC - CD/DVD would be fine but it can be any "data" CD?DVD as noted in the link he sent;
Step 5 Insert a valid CD or DVD into the disk drive.
Note For this test, you must use a data CD, not a music CD.
The system tests to ensure that you have inserted the disk.
Cheers!
Rob
Thank you Rob. I will test it.
Aristide
Any ISO will do the job, just make sure something is there selected in the Data Store. Since you will be doing it on BE6K, simply check/uncheck the CD option on the top right hand side to simulate insert/eject option respectively.
Deepak
Thank you Deepak.
Aristide
