H323 gw incoming call not working.
Hi all,
I have 12.x cucm and ISR 4351 voice gateway router with NIM-4MFT-T1/E1 (PRI). Incoming calls not working but outside calls work well. I tried to troubleshoot but couldn't find a solution.
I'd be grateful for your help.
I've attached gw config and q931 outputs.
You are sending the call to CM as called number 5475200 on dial peer 100 first and then 101. In both cases CM respond that it can’t find the number. Do the CSS on the H.323 trunk in CM have visibility of the partition that holds the directory number or any other configuration item(s) you might have in place for this number?
Response Signature
7 Replies 7
You’re getting a unallocated number
Cause i = 0x8181 - Unallocated/unassigned number
You need to check what you send as called number from the gateway to CM and verify that the CSS sees the number.
Do a debug voip ccapi inout to get more information about the call flow in the gateway.
Response Signature
"debug voip ccapi inout" output is attached.
Response Signature
I've noticed that I didn't enter CSS info in H323 gateway config. I entered it and incoming calls forwarded to hunt pilot.
Problem is solved.
Thank you Roger.
Glad to hear that and your welcome.
Response Signature
Hello @Roger Kallberg ,
Could you post the line that refers to the CUCM response that it can’t find the number?
@Faisal.Saoud
First reference of dial peer 100 in the outbound direction is on line 69 and the answer for this request is on line 190, then dial peer 101 is first reference in the outbound direction on line 279 and the answer for this request is on line 397. Further down on line 491 and 493 the response towards the telco is sent, with a release complete to end the call.
*Oct 14 20:18:04.821: ISDN Se0/1/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0145
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Calling Party Number i = 0x2183, '05495992901'
                Plan:ISDN, Type:National
        Called Party Number i = 0xC1, '5475200'
                Plan:ISDN, Type:Subscriber(local)
        Sending Complete
*Oct 14 20:18:04.821: ISDN Se0/1/0:15 Q931: Received SETUP  callref = 0x8145 cal        lID = 0x0058 switch = primary-net5 interface = User
*Oct 14 20:18:04.822: //-1/335EEA9E8055/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=05495992901
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=5475200
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdie=FFFFFFFFFFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
*Oct 14 20:18:04.823: //-1/335EEA9E8055/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x7FDEE1F708B8, Call Info(
   Calling Number=05495992901,(Calling Name=)(TON=National, NPI=ISDN, Screening=        Network, Presentation=Allowed),
   Called Number=5475200(TON=Subscriber, NPI=ISDN),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFl        ag=TRUE,
   Incoming Dial-peer=99, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALS        E), Call Id=-1
*Oct 14 20:18:04.823: //-1/335EEA9E8055/CCAPI/ccCheckClipClir:
   In: Calling Number=05495992901(TON=National, NPI=ISDN, Screening=Network, Pre        sentation=Allowed)
*Oct 14 20:18:04.824: //-1/335EEA9E8055/CCAPI/ccCheckClipClir:
   Out: Calling Number=05495992901(TON=National, NPI=ISDN, Screening=Network, Pr        esentation=Allowed)
*Oct 14 20:18:04.824: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Oct 14 20:18:04.824: :cc_get_feature_vsa malloc success
*Oct 14 20:18:04.824:  cc_get_feature_vsa count is 1
*Oct 14 20:18:04.824: :FEATURE_VSA attributes are: feature_name:0,feature_time:1        40595118788444,feature_id:188
*Oct 14 20:18:04.824: //188/335EEA9E8055/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=05495992901(TON=National, NPI=ISDN, Screening=Networ        k, Presentation=Allowed),
   Called Number=5475200(TON=Subscriber, NPI=ISDN))
*Oct 14 20:18:04.824: //188/335EEA9E8055/CCAPI/cc_process_call_setup_ind:
   Event=0x7FDEDA1EE1B0
*Oct 14 20:18:04.824: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 5475200
*Oct 14 20:18:04.825: //188/335EEA9E8055/CCAPI/ccCallSetContext:
   Context=0x7FDEE31F56F0
*Oct 14 20:18:04.825: //188/335EEA9E8055/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 188 with tag 99 to app "_ManagedAppProcess_Default"
*Oct 14 20:18:04.826: //188/335EEA9E8055/CCAPI/ccCallProceeding:
*Oct 14 20:18:04.826: //188/335EEA9E8055/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=100, Params=0x7FDEE31E7170, Progress Indication=NULL(0)
*Oct 14 20:18:04.826: //188/335EEA9E8055/CCAPI/ccCheckClipClir:
   Destination Pattern=5475200, Called Number=5475200, Digit Strip=FALSE
   Calling Number=05495992901(TON=National, NPI=ISDN, Screening=Network, Present        ation=Allowed),
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=TRUE,
   Guid=335EEA9E-0D91-11EB-8055-24169DC33F40, Outgoing Dial-peer=100
*Oct 14 20:18:04.827: //188/335EEA9E8055/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=5475200
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
*Oct 14 20:18:04.828: //188/335EEA9E8055/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x7FDED8A0E398, Interface Type=1, Destination=, Mode=0x0,
   Call Params(Calling Number=05495992901,(Calling Name=)(TON=National, NPI=ISDN        , Screening=Network, Presentation=Allowed),
   Called Number=5475200(TON=Subscriber, NPI=ISDN), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-pee        r=100, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Appl        ication Call Id=)
*Oct 14 20:18:04.828: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Oct 14 20:18:04.828: :cc_get_feature_vsa malloc success
*Oct 14 20:18:04.828:  cc_get_feature_vsa count is 2
*Oct 14 20:18:04.828: :FEATURE_VSA attributes are: feature_name:0,feature_time:1        40595118788220,feature_id:189
*Oct 14 20:18:04.828: //189/335EEA9E8055/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
*Oct 14 20:18:04.828: //189/335EEA9E8055/CCAPI/ccCallSetContext:
   Context=0x7FDEE31E70F0
*Oct 14 20:18:04.828: //188/335EEA9E8055/CCAPI/ccSaveDialpeerTag:
*Oct 14 20:18:04.829: //189/335EEA9E8055/CCAPI/ccGetMediaClassTag:
   media class tag 0
*Oct 14 20:18:04.829: //189/335EEA9E8055/CCAPI/ccSetMediaclassIp2ipTags:
   media class tags set: NR 0, ASP 0
*Oct 14 20:18:04.829: //188/335EEA9E8055/CCAPI/ccSetMediaclassIp2ipTags:
*Oct 14 20:18:04.829: //189/335EEA9E8055/CCAPI/ccGet_xc_nr_asp_info:
   media class tags: NR 0, ASP 0
*Oct 14 20:18:04.829: //188/335EEA9E8055/CCAPI/ccGet_xc_nr_asp_info:
*Oct 14 20:18:04.830: ISDN Se0/1/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x        8145
*Oct 14 20:18:04.850: //189/335EEA9E8055/CCAPI/cc_api_set_called_ccm_detected:
   CallInfo(called ccm detected=TRUE ccmVersion 3)
*Oct 14 20:18:04.850: //189/335EEA9E8055/CCAPI/cc_api_call_proceeding:
   Interface=0x7FDED8A0E398, Progress Indication=NULL(0)
*Oct 14 20:18:04.850: //189/335EEA9E8055/CCAPI/ccIsInfoRingback:
   Returning dpRingBack=0
*Oct 14 20:18:04.850: //189/335EEA9E8055/CCAPI/cc_api_call_cut_progress:
   Interface=0x7FDED8A0E398, Progress Indication=INBAND(8), Signal Indication=SI        GNAL RINGBACK(1),
   Cause Value=1
*Oct 14 20:18:04.851: //189/335EEA9E8055/CCAPI/cc_api_call_cut_progress:
   Call Entry(Responsed=TRUE)
*Oct 14 20:18:04.851: //188/335EEA9E8055/CCAPI/ccCallCutProgress:
   Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1), Cause Va        lue=1
   Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
*Oct 14 20:18:04.851: //188/335EEA9E8055/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Network, Params=0x0, Call Id=188
*Oct 14 20:18:04.852: //188/335EEA9E8055/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFFFFFFFFFF, callID1=0xBC, gcid=335EEA9E-D9111EB-80552416-9DC3        3F40, tag=0x0)
*Oct 14 20:18:04.852: //189/335EEA9E8055/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFFFFFFFFFF, callID2=0xBD, gcid=335EEA9E-D9111EB-80552416-9DC3        3F40, tag=0x0)
   Conference Id=0xFFFFFFFFFFFFFFFF, Call Id1=188, Call Id2=189, Tag=0x0
*Oct 14 20:18:04.852: //188/335EEA9E8055/CCAPI/cc_api_bridge_done:
   Conference Id=0x60, Source Interface=0x7FDEE1F708B8, Source Call Id=188,
   Destination Call Id=189, Disposition=0x0, Tag=0xFFFFFFFFFFFFFFFF
*Oct 14 20:18:04.852: //189/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Oct 14 20:18:04.852: cc_api_get_xcode_stream : 4981
*Oct 14 20:18:04.852: //189/335EEA9E8055/CCAPI/cc_api_bridge_done:
   Conference Id=0x60, Source Interface=0x7FDED8A0E398, Source Call Id=189,
   Destination Call Id=188, Disposition=0x0, Tag=0x0
*Oct 14 20:18:04.852: //188/335EEA9E8055/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x60, Destination Call Id=189)
   Call Entry(Conference Id=0x60, Destination Call Id=188)
*Oct 14 20:18:04.852: confID:0x60; callEntry1 callID1:0xBC, type:6; callEntry2 c        allID2:0xBD, type:1
*Oct 14 20:18:04.853: //188/335EEA9E8055/CCAPI/cc_api_caps_ind:
*Oct 14 20:18:04.853:  voice_rtp_nse_payload 0, voice_rtp_sse_payload 118 voice_        sprt_payload 120
*Oct 14 20:18:04.853:  sprt_latency 200, sprt_retries 12
   Destination Interface=0x7FDED8A0E398, Destination Call Id=189, Source Call Id        =188,
   Caps(Codec=0x1, Fax Rate=0x1, Fax Version:=0, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
*Oct 14 20:18:04.853: //188/335EEA9E8055/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x60, Call Id1=188, Call Id2=189
*Oct 14 20:18:04.854: ISDN Se0/1/0:15 Q931: TX -> PROGRESS pd = 8  callref = 0x8        145
        Progress Ind i = 0x8188 - In-band info or appropriate now available
*Oct 14 20:18:04.854: //189/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Oct 14 20:18:04.854: cc_api_get_xcode_stream : 4981
*Oct 14 20:18:04.869: //189/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Oct 14 20:18:04.869: cc_api_get_xcode_stream : 4981
*Oct 14 20:18:04.870: //189/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Oct 14 20:18:04.870: cc_api_get_xcode_stream : 4981
*Oct 14 20:18:04.871: //189/335EEA9E8055/CCAPI/cc_api_caps_ind:
*Oct 14 20:18:04.871:  voice_rtp_nse_payload 100, voice_rtp_sse_payload 118 voic        e_sprt_payload 120
*Oct 14 20:18:04.871:  sprt_latency 200, sprt_retries 12
   Destination Interface=0x7FDEE1F708B8, Destination Call Id=188, Source Call Id        =189,
   Caps(Codec=0x1, Fax Rate=0x2, Fax Version:=0, Vad=0x1,
   Modem=0x0, Codec Bytes=160, Signal Type=2)
*Oct 14 20:18:04.871: //189/335EEA9E8055/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Fax Version:=0, Vad=O        FF(0x1),
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=8670)
*Oct 14 20:18:04.871: //189/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Oct 14 20:18:04.871: cc_api_get_xcode_stream : 4981
*Oct 14 20:18:04.871: //188/335EEA9E8055/CCAPI/cc_api_caps_ack:
*Oct 14 20:18:04.874: //188/335EEA9E8055/CCAPI/cc_api_voice_mode_event:
   Call Id=188
   Call Entry(Context=0x7FDEE31F56F0)
*Oct 14 20:18:04.875: //189/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Oct 14 20:18:04.875: cc_api_get_xcode_stream : 4981
*Oct 14 20:18:14.199: //189/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Oct 14 20:18:14.199: cc_api_get_xcode_stream : 4981
*Oct 14 20:18:14.203: //189/335EEA9E8055/CCAPI/cc_api_call_disconnected:
   Cause Value=1, Interface=0x7FDED8A0E398, Call Id=189
*Oct 14 20:18:14.204: //189/335EEA9E8055/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=1, Retry Count=0)
*Oct 14 20:18:14.204: //188/335EEA9E8055/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
*Oct 14 20:18:14.204: //189/335EEA9E8055/CCAPI/ccCallSetAAA_Accounting:
   Accounting=1, Call Id=189
*Oct 14 20:18:14.204: //188/335EEA9E8055/CCAPI/ccConferenceDestroy:
   Conference Id=0x60, Tag=0x0
*Oct 14 20:18:14.204: confID:0x60; callEntry1 callID1:0xBC, type:6; callEntry2 c        allID2:0xBD, type:1
*Oct 14 20:18:14.204: //188/335EEA9E8055/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=189, Disposition=0x0, Tag=0x0
*Oct 14 20:18:14.204: //189/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Oct 14 20:18:14.204: cc_api_get_xcode_stream : 4981
*Oct 14 20:18:14.204: //189/335EEA9E8055/CCAPI/cc_api_bridge_drop_done:
*Oct 14 20:18:14.205: //188/335EEA9E8055/CCAPI/cc_generic_bridge_done:
*Oct 14 20:18:14.206: //189/335EEA9E8055/CCAPI/ccCallDisconnect:
   Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Ca        use=1)
*Oct 14 20:18:14.207: //189/335EEA9E8055/CCAPI/ccCallDisconnect:
   Cause Value=1, Call Entry(Responsed=TRUE, Cause Value=1)
*Oct 14 20:18:14.207: //189/335EEA9E8055/CCAPI/cc_api_get_transfer_info:
   Transfer Number=NULL
*Oct 14 20:18:14.222: //189/335EEA9E8055/CCAPI/cc_api_get_transfer_info:
*Oct 14 20:18:14.223: //189/335EEA9E8055/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x7FDED8A0E398, Tag=0x0, Call Id=189,
   Call Entry(Disconnect Cause=1, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
*Oct 14 20:18:14.223: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Oct 14 20:18:14.223: :cc_free_feature_vsa freeing 7FDEDA1CCE70
*Oct 14 20:18:14.223:  vsacount in free is 1
*Oct 14 20:18:14.223: //188/335EEA9E8055/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=101, Params=0x7FDEE31ECD70, Progress Indication=NULL(0)
*Oct 14 20:18:14.223: //188/335EEA9E8055/CCAPI/ccCheckClipClir:
*Oct 14 20:18:14.224: //188/335EEA9E8055/CCAPI/ccCheckClipClir:
*Oct 14 20:18:14.224: //188/335EEA9E8055/CCAPI/ccCallSetupRequest:
   Guid=335EEA9E-0D91-11EB-8055-24169DC33F40, Outgoing Dial-peer=101
*Oct 14 20:18:14.224: //188/335EEA9E8055/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=5475200
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
*Oct 14 20:18:14.225: //188/335EEA9E8055/CCAPI/ccIFCallSetupRequestPrivate:
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-pee        r=101, Call Count On=FALSE,
*Oct 14 20:18:14.225: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Oct 14 20:18:14.225: :cc_get_feature_vsa malloc success
*Oct 14 20:18:14.225:  cc_get_feature_vsa count is 2
*Oct 14 20:18:14.225: :FEATURE_VSA attributes are: feature_name:0,feature_time:1        40595118788220,feature_id:190
*Oct 14 20:18:14.225: //190/335EEA9E8055/CCAPI/ccIFCallSetupRequestPrivate:
*Oct 14 20:18:14.226: //190/335EEA9E8055/CCAPI/ccCallSetContext:
   Context=0x7FDEE31ECCF0
*Oct 14 20:18:14.226: //188/335EEA9E8055/CCAPI/ccSaveDialpeerTag:
*Oct 14 20:18:14.226: //190/335EEA9E8055/CCAPI/ccGetMediaClassTag:
   media class tag 0
*Oct 14 20:18:14.227: //190/335EEA9E8055/CCAPI/ccSetMediaclassIp2ipTags:
*Oct 14 20:18:14.227: //188/335EEA9E8055/CCAPI/ccSetMediaclassIp2ipTags:
*Oct 14 20:18:14.227: //190/335EEA9E8055/CCAPI/ccGet_xc_nr_asp_info:
*Oct 14 20:18:14.227: //188/335EEA9E8055/CCAPI/ccGet_xc_nr_asp_info:
*Oct 14 20:18:14.249: //190/335EEA9E8055/CCAPI/cc_api_set_called_ccm_detected:
*Oct 14 20:18:14.249: //190/335EEA9E8055/CCAPI/cc_api_call_proceeding:
*Oct 14 20:18:14.250: //190/335EEA9E8055/CCAPI/ccIsInfoRingback:
*Oct 14 20:18:14.250: //190/335EEA9E8055/CCAPI/cc_api_call_cut_progress:
   Cause Value=1
*Oct 14 20:18:14.251: //188/335EEA9E8055/CCAPI/ccCallCutProgress:
*Oct 14 20:18:14.251: //188/335EEA9E8055/CCAPI/ccGenerateToneInfo:
*Oct 14 20:18:14.251: //188/335EEA9E8055/CCAPI/ccConferenceCreate:
*Oct 14 20:18:14.251: //190/335EEA9E8055/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFFFFFFFFFF, callID2=0xBE, gcid=335EEA9E-D9111EB-80552416-9DC3        3F40, tag=0x0)
   Conference Id=0xFFFFFFFFFFFFFFFF, Call Id1=188, Call Id2=190, Tag=0x0
*Oct 14 20:18:14.252: //188/335EEA9E8055/CCAPI/cc_api_bridge_done:
   Conference Id=0x61, Source Interface=0x7FDEE1F708B8, Source Call Id=188,
   Destination Call Id=190, Disposition=0x0, Tag=0xFFFFFFFFFFFFFFFF
*Oct 14 20:18:14.252: //190/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Oct 14 20:18:14.252: cc_api_get_xcode_stream : 4981
*Oct 14 20:18:14.252: //190/335EEA9E8055/CCAPI/cc_api_bridge_done:
   Conference Id=0x61, Source Interface=0x7FDED8A0E398, Source Call Id=190,
*Oct 14 20:18:14.252: //188/335EEA9E8055/CCAPI/cc_generic_bridge_done:
*Oct 14 20:18:14.252: //188/335EEA9E8055/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x61, Destination Call Id=190)
*Oct 14 20:18:14.252: //190/335EEA9E8055/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x61, Destination Call Id=188)
*Oct 14 20:18:14.252: confID:0x61; callEntry1 callID1:0xBC, type:6; callEntry2 c        allID2:0xBE, type:1
*Oct 14 20:18:14.252: //188/335EEA9E8055/CCAPI/cc_api_caps_ind:
*Oct 14 20:18:14.252:  voice_rtp_nse_payload 0, voice_rtp_sse_payload 118 voice_        sprt_payload 120
*Oct 14 20:18:14.252:  sprt_latency 200, sprt_retries 12
   Destination Interface=0x7FDED8A0E398, Destination Call Id=190, Source Call Id        =188,
*Oct 14 20:18:14.253: //188/335EEA9E8055/CCAPI/cc_api_caps_ind:
*Oct 14 20:18:14.253: //188/335EEA9E8055/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x61, Call Id1=188, Call Id2=190
*Oct 14 20:18:14.254: ISDN Se0/1/0:15 Q931: TX -> PROGRESS pd = 8  callref = 0x8        145
*Oct 14 20:18:14.255: //190/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Oct 14 20:18:14.255: cc_api_get_xcode_stream : 4981
*Oct 14 20:18:14.269: //190/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Oct 14 20:18:14.269: cc_api_get_xcode_stream : 4981
*Oct 14 20:18:14.270: //190/335EEA9E8055/CCAPI/cc_api_caps_ind:
*Oct 14 20:18:14.270:  voice_rtp_nse_payload 100, voice_rtp_sse_payload 118 voic        e_sprt_payload 120
*Oct 14 20:18:14.270:  sprt_latency 200, sprt_retries 12
   Destination Interface=0x7FDEE1F708B8, Destination Call Id=188, Source Call Id        =190,
*Oct 14 20:18:14.271: //190/335EEA9E8055/CCAPI/cc_api_caps_ind:
*Oct 14 20:18:14.271: //190/335EEA9E8055/CCAPI/cc_api_caps_ack:
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=6623)
*Oct 14 20:18:14.271: //190/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Oct 14 20:18:14.271: cc_api_get_xcode_stream : 4981
*Oct 14 20:18:14.271: //188/335EEA9E8055/CCAPI/cc_api_caps_ack:
*Oct 14 20:18:14.273: //188/335EEA9E8055/CCAPI/cc_api_voice_mode_event:
   Call Id=188
*Oct 14 20:18:14.273: //190/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Oct 14 20:18:14.274: cc_api_get_xcode_stream : 4981
*Oct 14 20:18:14.274: //190/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Oct 14 20:18:23.596: //190/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Oct 14 20:18:23.596: cc_api_get_xcode_stream : 4981
*Oct 14 20:18:23.601: //190/335EEA9E8055/CCAPI/cc_api_call_disconnected:
   Cause Value=1, Interface=0x7FDED8A0E398, Call Id=190
*Oct 14 20:18:23.601: //188/335EEA9E8055/CCAPI/ccCallReleaseResources:
*Oct 14 20:18:23.601: //190/335EEA9E8055/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=190
*Oct 14 20:18:23.601: //188/335EEA9E8055/CCAPI/ccConferenceDestroy:
   Conference Id=0x61, Tag=0x0
*Oct 14 20:18:23.601: confID:0x61; callEntry1 callID1:0xBC, type:6; callEntry2 c        allID2:0xBE, type:1
*Oct 14 20:18:23.602: //188/335EEA9E8055/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=190, Disposition=0x0, Tag=0x0
*Oct 14 20:18:23.602: //190/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Oct 14 20:18:23.602: cc_api_get_xcode_stream : 4981
*Oct 14 20:18:23.602: //190/335EEA9E8055/CCAPI/cc_api_bridge_drop_done:
*Oct 14 20:18:23.602: //188/335EEA9E8055/CCAPI/cc_generic_bridge_done:
*Oct 14 20:18:23.603: //190/335EEA9E8055/CCAPI/ccCallDisconnect:
*Oct 14 20:18:23.603: //190/335EEA9E8055/CCAPI/cc_api_get_transfer_info:
*Oct 14 20:18:23.621: //190/335EEA9E8055/CCAPI/cc_api_get_transfer_info:
*Oct 14 20:18:23.622: //190/335EEA9E8055/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x7FDED8A0E398, Tag=0x0, Call Id=190,
*Oct 14 20:18:23.622: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Oct 14 20:18:23.622: :cc_free_feature_vsa freeing 7FDEDA1CCE70
*Oct 14 20:18:23.623:  vsacount in free is 1
*Oct 14 20:18:23.623: //188/335EEA9E8055/CCAPI/ccCallDisconnect:
   Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Ca        use=0)
*Oct 14 20:18:23.623: //188/335EEA9E8055/CCAPI/cc_api_get_transfer_info:
*Oct 14 20:18:23.624: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0        x8145
        Cause i = 0x8081 - Unallocated/unassigned number
*Oct 14 20:18:23.717: ISDN Se0/1/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x01        45
*Oct 14 20:18:23.718: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref =        0x8145
*Oct 14 20:18:23.721: //188/335EEA9E8055/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x7FDEE1F708B8, Tag=0x0, Call Id=188,
*Oct 14 20:18:23.721: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Oct 14 20:18:23.721: :cc_free_feature_vsa freeing 7FDEDA1CCF50
*Oct 14 20:18:23.721:  vsacount in free is 0
Response Signature
