08-13-2021 12:50 AM
Hello Friends,
I have this typical issue in some of my 7841 and 7821 phones registered with cisco cucm 12.5.1
The phones are registered properly but in some phones when user pick up the handset to call he don't get dial tone, for dial tone he have to press the call key on the phone keypad only then he can dial and make the call without any issue. I tried resetting the phone but it didn't help
any kind of input is deeply appreciated
Solved! Go to Solution.
08-20-2021 11:03 PM - edited 08-21-2021 07:54 AM
This would conclude that the micro switch in the cradle is faulty or that the spring that lifts up the block that should be “released” when you lift the handset don’t have enough tension. As this is a mechanical thing you could try to “massage” it, aka make it go smoother, to see if it helps. Or if you have the device covered by support contract do an RMA as @Nithin Eluvathingal suggested.
08-13-2021 02:02 AM
Can you check on the back side of the phone ,that the headsets are connected on the handset port and not the headset ports.
Try changing the headset or cable used. I have seen cables and even the headsets going faulty.
08-17-2021 08:20 AM
Yes I have checked it and tried everything nothing worked
08-14-2021 11:46 PM
Do you see anything happen on the phone when you lift the handset? Does the phones “react” to the handset being lifted? If not you likely have an issue with the switch in the cradle of the handset.
08-17-2021 08:21 AM
I can't remember this i will check this tomorrow and will let you know thanks.
08-20-2021 10:10 PM
Hi Roger,
I checked it and the phone has no reaction when we lift the handset.
Is there anything else I can do?
08-20-2021 10:24 PM
If you have a valid smartnet, I suggest to initiate RMA.
08-21-2021 03:20 AM
Ok everyone thanks for the help.
I will try to do a little tweaking and see if it works or else I have a smartnet and will raise a case in cisco
thanks again for the support
