12-31-2012 12:07 AM - edited 03-16-2019 02:56 PM
Hi all,
am having cisco 2921 with PVDM3-32U64, 2 fxo, 1 fxs and 1 E1 cards. Meet me conferece can`t be initiated. it shows in the phone cannot complete conference
It allow me to do maximum session 1 for conferece and max session 5 for transcoding. the config is :
voice-card 0
dspfarm
dsp services dspfarm
voice class custom-cptone LeaveConf
dualtone conference
frequency 600 900
cadence 300 150 300 100 300 50
voice class custom-cptone JoinConf
dualtone conference
frequency 600 900
sccp local GigabitEthernet0/0
sccp ccm 10.201.47.10 identifier 1 version 7.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/0
associate ccm 1 priority 1
associate profile 2 register CONFERENCE
associate profile 1 register TRANSCODE
keepalive retries 5
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 3 (it allow up to 5)
associate application SCCP
dspfarm profile 2 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum conference-participants 16
maximum sessions 1 (it allows only 1)
conference-join custom-cptone JoinConf
conference-leave custom-cptone LeaveConf
telephony-service
sdspfarm conference mute-on 11 mute-off 22
sdspfarm units 3
dspfarm tag 1 TRANSCODE
sdspfarm tag 2 CONFERENCE
conference hardware
max-conferences 8 gain -6
ephone-template 2 (added to the ephone)
conference drop-mode local
softkeys hold Join Newcall Resume Select
softkeys idle ConfList Gpickup Join Login Newcall Pickup Redial RmLstC
softkeys seized Redial Endcall Cfwdall Pickup Gpickup Callback Meetme
softkeys connected Hold Trnsfer Park Endcall Confrn ConfList Join Select RmLstC
ephone-dn 35 octo-line (done also with dual-line with same issue)
number 4440
conference meetme
no huntstop
ephone-dn 36 octo-line
number 4040
conference ad-hoc
no huntstop
can some one help, Meet-me softkey can`t be viwed in the idle state to initiate the conference????????
Solved! Go to Solution.
01-08-2013 06:50 AM
No, I havent try it yet. I`ll try and i`ll update you.
Do you mean restore the factory default for the cue and install again the CUE ios software with language package.?
regards,
01-08-2013 07:28 AM
Hi Mohammed,
Nope, just the following:
NME-CUE# offline
NME-CUE(offline)# restore factory default
Check the licenses and try the the CUE initialization wizard.
Harmit.
01-08-2013 08:03 AM
ok , I`ll do it and i`ll update you my friend.
regards,
01-09-2013 05:39 AM
Hi my friend again, Mr, Harmit and hope you are in a good health.
I solved the problem, the issue was in the username command under the ephone. the username was typed with a space between the two words. eg. James Bond i updated to JamesBond or James-Bond,
Thanks a lot for your time and cooperation, it is nice to know someone like you,
Hope to keep in touch, if u dont mind.
regards,
01-09-2013 05:45 AM
Hi Mohammed,
Very happy to hear that you found the problem! +5 for sharing the resolution, it will certainly come in handy for anyone else who runs into this issue. I'm glad I could be of help, yes, lets stay in touch!
Harmit.
01-14-2013 06:01 AM
Hi Mr. Harmit again,
I `ve another issue if you dont mind, the license i ordered with my 2921 is for 25 users. only 21 ip phone is working and any other phone(7931)is connected it shows upgrading on its screen and continues like that.
Is the license get installed in the router by default from cisco. ?/?
I would like to inform you too that one from the ip phone was working normally, after it is reseted it keep showing the upgrading on the screen.?
Is it the issue relates to the issue, or something else.?
GW# sh telephony-service license
License Supported:
cme-srst: Registered, In Use. Handle: 0xE1000005
Maximum User License: 110
CSL license count: 110
CSL Requested User License: 50
Used User License: 21
Available User License: 89
Max Users Provisioned (ephone + pool): 50
Allowance - Extra user license: 10
temp_license_expired_event: 0
license_installed_event: 0
license_count_change_event: 0
eula_not_accepted: 0
license_check_approved: 49
license_check_denied: 0
01-28-2013 09:55 PM
Hi again,
I want plz a resource how to get and configure the default cisco voice messages which request for example to enter the meetme conference number and other voice messages.
"Voice messages for entering and leaving the conference and others"
regards,
01-06-2013 05:55 AM
Mohammed,
Calls between two phones are not conferenced. Its a. Simple direct call. Conferencing starts when you have 3 or more parties on a call.
No, you only hear a ring even when the user is busy unless you set your busy trigger to 1, you get a busy tone. There is no other prompt.
Sent from Cisco Technical Support Android App
01-06-2013 11:17 PM
01-28-2013 09:54 PM
Hi again,
regards,
