Hardware conferencing
Davidwagman1
Level 7
Level 7
Hi Everyone,
I'm trying to set up hardware conferencing in CME with a on board PVDM2.  I'm having some trouble with the config:
CME(config-dspfarm-profile)#no shut
Please associate the profile to an application and retry
Pertinent part of the config is attached.
Any ideas what I'm doing wrong?
David
ETA: Updated config.
2 Accepted Solutions
clileikis
Level 7
Level 7
Hi David,
Add the following to your dspfarm profile:
associate application sccp
David I believe you need two things ad-hoc dn and the shared line dn. do you have both?
Create shared line ephone-dn and ad-hoc conference ephone-dn e.g
ephone-dn  3  octo-line
number 5003
ephone-dn  4  octo-line
number A123
conference ad-hoc
Please rate all useful posts
"There is a wideness in God's mercy Like the wideness of the sea.There's a kindness in His justice Which is more than liberty"
10 Replies 10
clileikis
Level 7
Level 7
Hi David,
Hi Clileikis,
Thanks for the reply. That got conferencing working, thank you.
Cbarge is still not working. The cbarge softkey never shows up.
Any ideas?  Updated config.
David
David for cbarge to work privacy must be disbaled either globally or on the specific phone. By default privacy is turned on and hence phones hid their remote in use state. So do this..
1. globally
telephony-service
no privacy
2. Locally from each phone:
ephone  2
privacy off
Hi Aokanlawon,
I have no privacy under both tel serv and each ephone. I think its an issue with the remote in use, its not coming up for the shared line.
Best,
David
You also need ad-hoc conference configured. I dont see this in your config.
I have:
ephone-dn  40  octo-line
 number 3030 no-reg primary
 conference ad-hoc
 preference 1
 no huntstop
I posted an updated config after the first post, and updated the first post to reflect that.
Am I missing something?
David
David,
Try and re-configure your ad-hoc dn like this. Dont use existing DN. Use DN that only system can use. eg Remove the ad-hoc on the exisitng DN and re-configure
ephone-dn x octo-line
number A100
conference ad-hoc
ephone-dn y octo-line
number A101
conference ad-hoc
Hi Aokanlawon,
I deleted the old ephone-dn 40 and re-created as follows:
 number A300
 conference ad-hoc
ephone-dn  41  octo-line
 number A301
 conference ad-hoc
Still, no cbarge. Conferencing is working however.
ephone-template  1
 softkeys remote-in-use  CBarge Newcall
 softkeys idle  Redial Newcall Cfwdall Pickup Gpickup Join Login Mobility
 softkeys connected  Hold Endcall Trnsfer Confrn TrnsfVM Mobility LiveRcd Park
 type 7970
ETA: I did also reset the ephones before testing.
Best,
David
number 5003
number A123
conference ad-hoc
Aokanlawon,
Brilliant, as usual. Thank you for your help.
Looks like I get the fun of going through and deleting and re-creating all my DNs now...
Best,
David
