Has anyone been able to change port 8443 on collab_edge SRV record
dwayne rattan
Hi I am configuring expressway for MRA the customer currently has a web application that customers log into that utilized port 8443 and as a result that port cannot be used for MRA.
My team is asking if there is anyway that the 8443 port used by jabber to register via MRA can be changed? The think here is the port is a common port that is used for web applications and as such if the port is unavailable for use there must be someway around it.
We are using static NAT to connect to the external side.
Jaime Valencia
No, it cannot be changed.
java
if this helps, please rate
5 Replies 5
Not sure I understand the use case of the problem here. Even if the ports would be the same, wouldn't the public IPs used for the web service and the MRA (Expressway E) be different?
Response Signature
The IP address will actually be the same. Trying to use the same public address but have the destination port be different for MRA and the web application.
If your existing port usage conflict with MRA ports, use a different Static Ip.
Response Signature
This would not be a viable option. You would need to use different public IPs.
Response Signature
Jaime Valencia
java
