help on howe to configure CME phoneload files
monasir
Hi guys,
I'm keep having problems with callmanager express, i'm struggling with the skinny firmware.
I configured my 2801 router as a tftp server so that my phones can pick the skinny firmware from the router.
I've downloaded the files from the cisco site (skinny software)
The phones probably not getting the files i think?
My phones on my CME are still registrering.
I've checked several things:
Sh ephone reg=> nothing
Sh ip dhcp binding
10.10.202.51        0100.1818.7c18.44       Nov 23 2012 10:14 PM    Automatic
10.10.202.53        0100.1795.b0d7.ce       Nov 23 2012 10:13 PM    Automatic
This is good
sh telephony tftp binding:
tftp-server system:/its/spain/7960-tones.xml alias Spain/7960-tones.xml
tftp-server system:/its/united_states/7960-font.xml alias English_United_States/7960-font.xml
tftp-server system:/its/united_states/7960-font.xml alias English_United_States/7920-font.xml
tftp-server system:/its/united_states/7960-dictionary.xml alias English_United_States/7960-dictionary.xml
tftp-server system:/its/united_states/7960-kate.xml alias English_United_States/7960-kate.xml
tftp-server system:/its/united_states/7960-kate.xml alias English_United_States/7920-kate.xml
tftp-server system:/its/united_states/SCCP-dictionary.xml alias English_United_States/SCCP-dictionary.xml
tftp-server system:/its/SEPDEFAULT.cnf alias SEPDefault.cnf
tftp-server system:/its/vrf1/XMLDefault.cnf.xml alias XMLDefault.cnf.xml
tftp-server system:/its/vrf1/ATADefault.cnf.xml alias ATADefault.cnf.xml
check my router config i really don't no why the phones keeps saying registrering??
Is there something i am missing??
current configuration : 3184 bytes
version 12.4
hostname BR2-RTR
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
memory-size iomem 20
no network-clock-participate wic 0
dot11 syslog
ip source-route
ip dhcp excluded-address 10.10.202.1 10.10.202.49
ip dhcp excluded-address 10.10.202.70 10.10.202.254
ip dhcp pool CME
   network 10.10.202.0 255.255.255.0
   option 150 ip 10.10.110.3
   default-router 10.10.202.1
ip cef
no ipv6 cef
voice-card 0
archive
log config
  hidekeys
controller E1 0/0/0
interface Loopback0
ip address 10.10.110.3 255.255.255.255
interface FastEthernet0/0
ip address 10.10.210.16 255.255.255.0
duplex auto
speed auto
interface Service-Engine0/0
no ip address
shutdown
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1/0
switchport trunk native vlan 200
switchport mode trunk
switchport voice vlan 400
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface Serial0/2/0
no ip address
shutdown
no fair-queue
interface Serial0/2/1
ip address 10.10.112.2 255.255.255.0
encapsulation ppp
ip ospf mtu-ignore
interface Vlan1
no ip address
interface Vlan200
ip address 10.10.102.1 255.255.255.0
interface Vlan400
ip address 10.10.202.1 255.255.255.0
ip forward-protocol nd
no ip http server
no ip http secure-server
disable-eadi
tftp-server flash:SCCP41.9-3-1SR1-1S.loads
tftp-server flash:apps41.9-3-1ES8.sbn
tftp-server cmterm-7941_7961-sccp.9-3-1SR1-1.cop.sgn
tftp-server cnu41.9-3-1ES8.sbn
tftp-server flash:term61.default.loads
tftp-server flash:term41.default.loads
tftp-server flash:jar41sccp.9-3-1ES8.sbn
tftp-server flash:dsp41.9-3-1ES8.sbn
tftp-server flash:cvm41sccp.9-3-1ES8.sbn
control-plane
ccm-manager fax protocol cisco
gatekeeper
shutdown
telephony-service
max-ephones 2
max-dn 2
ip source-address 10.10.110.3 port 2000
auto assign 1 to 2
network-locale ES
network-locale 1 ES
network-locale 2 ES
network-locale 3 ES
network-locale 4 ES
load 7960-7940 P00
max-conferences 4 gain -6
transfer-system full-consult
server-security-mode non-secure
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  1  dual-line
number 3001
ephone-dn  2  dual-line
number 3002
line con 0
exec-timeout 0 0
password cisco
line aux 0
line 66
no activation-character
no exec
transport preferred none
transport input all
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
privilege level 15
password cisco
login
transport input all
line vty 5 15
password cisco
login
transport input all
scheduler allocate 20000 1000
end
sky_voice
Hi Monasir,
I believe you would need to add ephone configuration here. Looking at the high level that's only part I see missing here.
ephone  11
mac-address xxxx.xxxx.xxxx
ephone-template 1
username "John"
type 7942
button  1:11
also configure ephone templates and ephone-dn templates as follows...
ephone-template  1
transfer max-length 11
softkeys hold  Resume Newcall
softkeys idle  Redial Newcall Cfwdall Pickup Dnd
softkeys seized  Redial Endcall Cfwdall Pickup
softkeys alerting  Callback Endcall
softkeys connected  Hold Trnsfer Confrn TrnsfVM Endcall
softkeys ringing  Dnd Answer
HTH.
Sky,
Pls rate helpful posts.
sky_voice
Hi Monasir,
ephone  11
ephone-template 1
username "John"
type 7942
button  1:11
ephone-template  1
HTH.
Sky,
Ensure button assignment 1:11 means first line of your physical phone is binded with ephone-dn 11.
Here in your case it would
1:1
1:2
anchoudh
Level 9
Level 9
Please use the below link for reference.
http://www.cisco.com/image/gif/paws/99946/cme-sip-guide.pdf
Hope this helps.
Anand
Please rate helpful posts !!
Hi there everyone
It worked but i had to something else the phones where still keep registering.
So what i did is i've put both phones on the CME in factory reset and they where both rebooting in the good firmware/load files.
I've assigned them both a mac adress and everything went fine.
Also when i say sh telephony service tftp binding you can see both phones have the right XML files.
Any way i would like to thank you guys for your support and help!
Appreciate it...
