Hi all, I need help to configure CISCO2901/K9 for telephone service.
Vinnfier93
Hi all,
right now my office has subscribed a new internet plan with telephone service.
so I need to configure all cisco IP phone to get the calls from 1 line.
i'm also not sure what connection need to use. because I'm familiar to setup voice with internet router.
so I'm planning to setup using this connection:
modem>ISP Router>CISCO2901>WS-C2960>4xunit Cisco IP Phone 7960
right telephone is connected at the modem at TEL PORT 1.
so my question is, how to configure 2901 as voice router and is it possible using that above connection?
2901 got CME license. i think it possible, but i dont know how to setup this.
Please advise for other workarounds.
Router#sh inventory
NAME: "CISCO2901/K9", DESCR: "CISCO2901/K9 chassis, Hw Serial#: FGL155120MM, Hw Revision: 1.0"
PID: CISCO2901/K9      , VID: V04 , SN: xxxxxxxxxxxxx
NAME: "2nd generation two port FXO voice interface daughtercard on Slot 0 SubSlot 0", DESCR: "2nd generation two port FXO voice interface daughtercard"
PID: VIC2-2FXO=        , VID: V  , SN: xxxxxxxxxxxxxxxxx
NAME: "PVDM3 DSP DIMM with 32 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 32 Channels"
PID: PVDM3-32          , VID: V01 , SN: xxxxxxxxxxxxxx
NAME: "C1941/C2901 AC Power Supply", DESCR: "C1941/C2901 AC Power Supply"
PID: PWR-1941-2901-AC  , VID:    , SN:
Router#show license
Index 1 Feature: ipbasek9
        Period left: Life time
        License Type: Permanent
        License State: Active, In Use
        License Count: Non-Counted
        License Priority: Medium
Index 2 Feature: securityk9
        Period left: Not Activated
        Period Used: 0  minute  0  second
        License Type: EvalRightToUse
        License State: Active, Not in Use, EULA not accepted
        License Priority: None
Index 3 Feature: uck9
Index 4 Feature: datak9
Index 5 Feature: NtwkEssSuitek9
Index 6 Feature: CollabProSuitek9
Index 7 Feature: ios-ips-update
Index 8 Feature: SNASw
Index 9 Feature: hseck9
Index 10 Feature: cme-srst
        License Type: RightToUse
        License State: Active, Not in Use, EULA accepted
        License Count: 0/0  (In-use/Violation)
        License Priority: Low
Index 11 Feature: mgmt-plug-and-play
Index 12 Feature: mgmt-lifecycle
Index 13 Feature: mgmt-assurance
Index 14 Feature: mgmt-onplus
Index 15 Feature: mgmt-compliance
Router#
Hafiz
George Sotiropoulos
Hello Hafiz,
Please note that 2900 Series ISR are EOL (End-Of-Life) so you will not have support (check link below)
https://www.cisco.com/c/en/us/products/collateral/routers/2900-series-integrated-services-routers-isr/eos-eol-notice-c51-737831.html
In any case, you may have a look on the following reference of Call Manager Express to gain some understanding on the basic configuration.
https://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-express/211270-Basic-Configuration-Guide-for-CUCME-CME.pdf
Commands may vary, based on the IOS version you are running on your Router.
Hope this helps,
George
Hope the above helps,
gsotirop
b.winter
I would suggest you check out the different kinds of documentation about how to configure CME, Provider connections and so on. There are probably also hundreds of forum post about these topics.
The forum isn't here to do your work and present you a complete / working config or being a teaching platform. It's here to answer specific questions to specific problems.
Also: ISR 29xx routers are already End-of-everything. So you are on a non-supported hardware.
George Sotiropoulos
Hello Hafiz,
Hope this helps,
George
gsotirop
Strictly not actually end of life / end of support until the end of this year.
@TONY SMITH Of course you are right, my wording was not correct, wanted to point out that soon this will be EOL, so thats why I included the link
gsotirop
