Hold music stopped working for inbound calls
We have UCM 10.5, MOH stopped working for inbound calls where it works for outbound calls.
All the media resources and MOH configurations looks ok
Vaijanath Sonvane
Please answer below questions:
1. What the gateway model and IOS version?
2. Are you using SIP Trunk or PRI lines? please post you gateway configuration.
3. Do you have gateway device pool configured with MRGL?
4. Which codec you are using between Phone device pool and gateway device pool?
Ensure that the region between the MOH server and the GW is G711 if you want it to play as G711, otherwise you need to enable G729 codec under MOH service parameters. Try adding software MTP resource under MRGL and enable MTP on SIP Trunk.
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
Cisco 3945 ISR , 15.4(3)M8
PRI lines, we have other gateways ISR 4451 with SIP trunk MOH on 4451 VG works fine
Yes
G.722, G.711
HARIS_HUSSAIN
Is the Path used for inbound and outbound calls the same ?
*** Please rate helpful post; Mark "Accept as a Solution" if applicable
Haris
Yes path is same we also tried restarting Cisco IP Voice Media Streaming App service on each CUCM server issue still not resolved
