How to change the DN length from 4 digits to 6 digits?
Hello everyone,
I'm facing the problem that my CUCM is integrated with new branches with the same DN that already have.
We were using translation and prefixes but I think is time to change the DN to 5 or 6 digits length.
Somebody knows how can I complete this task?
I have +1800 DN splited into 11 DP
one by one is not an option.
Thanks to read, any coment will be helpful.
AM
Chris Deren
This is a daunting task and this has been asked here few times. Search for dial plan changes and you will find quite a few threads with steps, including SQL queries to execute on CUCM side.
HTH,
Chris
Chris Deren
HTH,
Chris
I found this.
https://supportforums.cisco.com/thread/2165894
but i dont want to add only one digit to all DN, I want to add the prefix in the DN to avoid the traslation numbers.
I was thinking to use the bluk tool, and update the DN by DP/phone type
Thanks for reply
AM
