ā04-04-2022 12:08 AM
client planning to connect their fax machine with voice gateway FXS port. voice gateway will be added to cucm .
So do we need to configure this from cucm side or independently on voice gateway?
how can I configure FXS port if voice gateway added CUCM with MGCP, H323 or SIP trunk?
ā04-04-2022 12:36 AM
I have sites with both mgcp and SCCP. Once I have access to my pc I will share the sample configs.
Find out which protocol is used by the isp t38 or pass through. Thatās more important. Or fax will fail.
ā04-04-2022 12:39 AM
thnx. my question is that if the voice gateway is already configured with H323 still we can use mgcp for this purpose?
i heard it can be managed using local configuration with dial peer as well.
Which option is better in this case?
ā04-04-2022 01:04 AM
You can run multiple protocols on same vg. But only one protocols can be used for the VG ports..
ā04-04-2022 01:36 AM
What would be the preference is depending upon your specifics, there is no one fits all type of setup. As @Nithin Eluvathingal wrote you can run multiple protocols simultaneously.
