10-29-2022 04:56 AM
I have a voice gateway which is registered as MGCP to CUCM. This voice gateway has a hotline analog phone (FXS) and PSTN line (FXO) connected to it. Can someone help me on how to configure the hotline phone that when the handset is lifted, it will automatically dial the PSTN line, let's say 2222 4444 (8-digits)? I am new to CUCM, hoping that you can help me the step by step configuration.
Thank you.
10-29-2022 05:39 AM
This is what you’d be looking for. CUCM PLAR Configuration Example
Even if the document mentions SCCP and SIP phones it would work the same for a MGCP controlled FXS port. Follow the configuration for SCCP as that’s equal to what you’ll need.
10-29-2022 10:24 AM
Hi Roger,
Thanks for the inputs. However, the example on the link you shared didn't work for me. The sample configuration is for Hotline on extension number to extension number. My situation is, the Hotline analog phone will automatically dial an outside line through PSTN (FXO). I attached here the diagram for reference. Hope you can enlighten me more.
10-29-2022 11:15 AM - edited 10-29-2022 11:16 AM
Follow steps below, and share some screenshots if the setup does not work.
Create a route pattern for your hotline
Route Pattern = Your Hotline
Route Partition = Your internal partition
Gateway/Route List = MGCP Gatway/Route List
Create a new partition
Name = PlartToHotline_PT
Create a new Calling Search Space
Name= PlarToHotlineCSS
Selected Partitions = PlartToHotline_PT
Now, last step is to create your Translation Pattern for the PLAR feature
Translation pattern = Leave this field blank
Partition = PlartToHotline_PT
Calling Search Space= Any CSS that can access your internal partition
Called Party Transformation Mask = Your Hotline
Assign PlarToHotlineCSS to your analog phone, save and apply config
Now, go off hook and your analog phone should dial the hotline automatically
10-29-2022 11:17 AM - edited 10-29-2022 11:37 AM
It can be made to work for any called number, it is just a matter of adopting the configuration to fit your needs.
Can you please share a screenshot of your PLAR translation pattern, that shows the outbound CSS and the called number translation, then also share a screenshot of the CSS and the route pattern that the translation pattern should hit after it has processed the call. Also please share a screenshot of the MGCP controlled FXS port and the CSS it uses.
What you need is something along with this.
The RP should recommend send the call to a Route List/Route Group that contains the MGCP FXO port.
