07-07-2011 07:17 AM - edited 03-16-2019 05:49 AM
I would like to configure the 7962 at my desk to look like a 7962 at another location. I have added BLF speed dials and I want to make sure they are working from my phone without disturbing the other line how do I go about this? I want my phone to be configured like theirs so I know theirs is working properly. I do not want to just add the BLF to my phone I want my phone to look like and act just like theirs. IE it rings when someone dials their number.
So number for distant phone is 1234 my number is 5678 I want my phone to mimick 1234 ring blf everything....I know there is a couple settings to do this in CUCM but, can not remember exactly where.
Thank You
Solved! Go to Solution.
07-07-2011 07:28 AM
Hi Greg,
If you delete your config first you should be able to use
Super-copy
Device>Phone>Find phone where DN = 1234>Super Copy (far right on page)
Cheers!
Rob
07-07-2011 07:43 AM
Fantastic reply from Rob as always, rated +5.
07-07-2011 08:01 AM
Greg,
If you want 'your' phone back after the tests just change the MAC address to something else like changing the first two digits to FF so it changes from SEP001E4A3498AC to SEPFF1E4A3498AC then as Rob said do a supercopy.
When your tests are over delete the copied phone and rename yours back.
Hope this helps,
Craig
(PLEASE RATE HELPFUL POSTS)
07-07-2011 07:28 AM
Hi Greg,
Super-copy
Cheers!
Rob
07-07-2011 07:37 AM
I was trying to avoid deleting and recreatng my phone but, if that is the only way ?
07-07-2011 07:43 AM
07-07-2011 08:01 AM
Greg,
Hope this helps,
Craig
07-07-2011 08:19 AM
Duh......coffee has not kicked in yet.....
Thanks Everyone
