How to define a specific ip address as source for sip trunk with SIP provider
I need to set a SIP trunk with CME and SIP provider, I have already defined network segment for voice and data, but SIP provider told  me that I need to send a specific IP address ( 172.53.225.130 / 30) in order to be allowed to make call through SIP server.
My doubt is how can I set the config in router in order  to sent the IP address SIP provider required as source, if I have already defined voice segment where CME, unity express and ip phones will be.
This SIP provider is going to delivered also a MPLS link for DATA in the same interface (fastethernet), the segment for MPLS data is 172.53.1.6 / 30.
Any recommendation??
regards
CME express
interface GigabitEthernet0/0.3
DESCRIPTION  DATA LAN
encapsulation dot1Q 3 native
ip addres 172.29.57.154 255.255.255.0
interface GigabitEthernet0/0.6
description CME
ip address 172.29.67.154 255.255.255.0
h323-gateway voip bind srcaddr 172.29.67.154
encapsulation dot1Q 6
Ayodeji Okanlawon
This is very easy to do with sip bind commands. Eg if the ip address is configured for loopback interface for example...
int loop0
ip address 172.53.225.130 255.255.55.252
voice service voip
sip
  bind control source-interface loop0
  bind media source-interface loop0
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Karthik Sivaram
Level 4
Level 4
hi filiberto,
1. enable
2. configure terminal
3. voice service voip
4. sip
5. bind all source-interface x/x
6. exit
Use the above config .
http://www.cisco.com/en/US/docs/ios/12_3/sip/configuration/guide/chapter7.html
Hope this helps!
Karthik
Hi  Karthink,
Thanks a lot for the link, finally I understood why I have to use bind option .
regards
Ayodeji Okanlawon
int loop0
voice service voip
sip
Hi aokanlawon,
thanks  a lot for your clear example, with it I can go on with the config.
regards
