08-15-2015 04:47 AM - edited 03-17-2019 04:00 AM
Hello Guys
Need your help to register how to register Polycom Soundstation IP 6000 with Call manager Express 10.5 ???
i already have Voice Global Register !
i Can't find this mode in type mode ???????
Any Idea ???
Solved! Go to Solution.
08-15-2015 08:55 AM
Hi Hassan,
This phone is not a supported endpoint with CME 10.5
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/cme105spc.html
It it supports SIP then you can add it as a third party SIP endpoint. When adding a third party SIP endpoint you do not need to specify the 'type'.
Manish
- Do rate helpful posts -
08-15-2015 08:55 AM
Hi Hassan,
Manish
08-15-2015 04:25 PM
Dear Manish,
you are right i checked your URL !!!!
and i do no type and we will see .
10-01-2015 08:55 AM
Hi Manish, could you post your config?, I have the same issue
Ruben
10-03-2015 02:34 PM
Hey Jose ,
here is conf from voice register pool ##
voice register pool 99
busy-trigger-per-button 2
id mac 0004.F2F6.XXXX
number 1 dn 99
cor incoming inside default
dtmf-relay sip-notify
username 1106 password 1106
codec g711alaw
conference max-length 5
and don't forget to configure Phone with same thing as sip user !!
Hassan Fahmy
08-31-2018 01:56 AM
Hi Hassan,
Thanks for the post, kindly share procedure for adding IP 6000 as sip endpoint and also what do you mean by "don't forget to configure Phone with same thing as sip user "
05-31-2018 10:55 AM
05-31-2018 11:24 AM
Hi there
Please refer to the config guide.
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
05-31-2018 11:54 AM
