03-10-2016 05:09 AM - edited 03-17-2019 06:11 AM
Dear All,
Please help me with license backup from call manager 8.5.1.
Thank you
Solved! Go to Solution.
03-10-2016 05:48 AM
03-10-2016 05:31 AM
https://supportforums.cisco.com/discussion/10867761/cucm-7-export-license-file-upload
Deepak
03-10-2016 05:44 AM
Hello Deepak,
When I try the following commands from command line I get the below output, please help..
admin:file get license ?
Syntax:
file get license file-spec [options]
file-spec mandatory file to transfer
options optional reltime months|weeks|days|hours|minutes timevalue
abstime hh:mm:MM/DD/YY hh:mm:MM/DD/YY
match regex
recurs
compress
admin:file get install?
Syntax:
file get install file-spec [options]
match regex
recurs
compress
03-10-2016 05:48 AM
Can you try
file get license /*
file get install /*
Deepak
03-10-2016 06:18 AM
you can try file list license * to see what all license files are there in Call manager
to download, you can try
file get license *
you need to have sftp working in background to download files.
secondly, you can also refer the link
https://supportforums.cisco.com/discussion/12915411/mac-address-ccm-offline-mode
regds,
aman
03-10-2016 10:26 AM
Thank you Deepak/All,
Backed up licenses...
03-10-2016 10:31 AM
Glad that it worked and thanks for updating the forum.
Deepak
