How trigger TCL script from inside network
moises7777
I am working on a TCL script and would like to test it. I have a 2811 and CUCM with two cisco phones and one analog phone. This is in a lab environment. I am attempting to trigger the TCL script by calling the dial peer with the script attached to it, but it doesn't seem to work. I need to trigger it from inside the network.
This is the dial peer I am calling extension 2002 to from attempting to trigger the script.
Router#sh run | s dial-peer
dial-peer voice 2000 voip
destination-pattern 2...
session target ipv4:10.10.25.254
dtmf-relay h245-alphanumeric
codec g711ulaw
This is the dial peer that has the script in it. I have tried both incoming called number and destination pattern with no luck.
dial-peer voice 2002 voip
service disa
incoming called-number 2002
Any help would be greatly appreciated.
22 Replies 22
Post a show tech from the GW.
Show flash
Debug voip ccapi inout with calling and called number
the debug voice ccapi doesn't show anything different, I can only get output when I use tha analog phone hooked up to an fxs port, the two ip phones in the lab are registered to CM and don't show any output when i dail to the disa line from them.
Router#sh flash
-#- --length-- -----date/time------ path
1     66483320 Oct 25 2009 03:45:24 +00:00 c2800nm-adventerprisek9-mz.151-3.T.bin
2        39540 Feb 28 2011 22:22:38 +00:00 auth_fail_final.AU
3        24476 Feb 28 2011 22:23:40 +00:00 en_enter_pin.AU
4        11020 Feb 28 2011 22:24:44 +00:00 out_of_time.AU
5         5778 Feb 28 2011 22:25:20 +00:00 DISA.tcl
dial-peer voice 222 voip
service disa
destination-pattern 2010
incoming called-number 2010
codec g711ulaw
no vad
session target is missing that dial-peer.
Can you please verify whether the CUCM Route-patterns are setup correctly? Can you call the FXS Analog phone on the GW from the CUCM?
Hm, I can't call from the gw to the analog phone, let me get that sorted out.
*Apr 25 21:19:41.572: //37/91862E598055/CCAPI/cc_process_call_setup_ind:
Event=0x4AD47728
*Apr 25 21:19:41.572: //37/91862E598055/CCAPI/ccCallSetContext:
Context=0x48E43404
>>>>CCAPI handed cid 37 with tag 2003 to app "_ManagedAppProcess_Default"
If everything is working correctly we should see DISA app instead of "_ManagedAppProcess_Default"
Ok, I resolved the rout list issue. I can now call the voip phones from the ananlog phone hooked up to the VG via fxs. The VG is set up as both h323 and mgcp, the fxs ports are being handled by h323.
When I call the DISA number now 2010 I can see that the right dial peer is being triggered by doing a sh voice call status. I here two ring tones and then it seems as if the call is answered but after a few seconds I here another ring. When that happens, the call is no longer triggering the correct dial peer, it instead is triggering dial peer 200, which is weired because I have not created a dial peer 200.
When I loaded the script i  did this.
application
service new-call flash:DISA.tcl
  paramspace english language en
  paramspace english index 0
  paramspace english location flash
  paramspace english prefix en
That loaded the script. I then uploaded the audio files to flash. I think I used a command audio load.
Do you think I made a mistake in loading the script or files? Thanks in advanced.
Ok, I can see this now:
*Apr 26 17:06:46.759: //117/65978F9A808F/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 117 with tag 222 to app "_ManagedAppProcess_DISA"
It seems the app is kinda being triggered but I can not hear the prompts. I attached a new debug.
I haven't tried the DISA myself!
But try this
voice translation-rule 2009
  rule 1 /2009/ //
voice translation-profile 2009
translate called 2009
translation-profile incoming 2009
I can see a
*Apr 26 17:06:56.823:  vsacount in free is 2
*Apr 26 17:06:56.827: //116/65978F9A808F/CCAPI/cc_api_call_disconnected:
   Cause Value=28, Interface=0x4A3C9228, Call Id=116
   Call Entry(Responsed=TRUE, Cause Value=28, Retry Count=0)
Cause No. 28 - invalid number format (address incomplete).
This cause indicates that the called party cannot be reached because  the called party number is not in a valid format or is not complete.
Even the doc https://supportforums.cisco.com/docs/DOC-9795#Does_the_UC500_support_Dial_Inward_System_Access_DISA suggests removing the called number.
/divin
