HTTP status 404- /ccmadmin/ ERROR
RKha
Hi Every One,
i am installed Call Manager 6.0 , i am trying to log to the Administrator page the following message appeare
type status report
message /ccmadmin/
Discription: The requested resource (ccmadmin/) is not available.
Apache Tomcat/5.5.17
just for administartion page , i can enter to servesability and other web-interface except the administrator.
i tray to restart Tomcat servece and callmanager servese , nothing happen , message still appear .
2 Accepted Solutions
HI friend,
i have the same problem with a vmware.
you have reinstall it?
thanks!
Hello
I had the problem in VMware as well, but when i re-installed it fixed the problem.
19 Replies 19
raguado04
Hi Rami,
I have exactly the same issue, did you happen to find a fix for it?
I am also experiencing the same issue except with CUCM 7.1.5.
I can access ccmservice and cmpplatform but i cant access ccmadmin.  Any solutions who be a big help.
Impressive. I have not run into this. Is it consistant at every boot since install; or, did this just start?
If it's like this since install you may have a corrupt install.
If it just started, one thing you can try (during a maintenance window) is to restart the Tomcat service. Each of these webapps are independant and this one may have crashed. Read this for the CLI commands: https://supportforums.cisco.com/message/3118771#3118771
Its happened consistently since the initial install, and restarting the tomcat service and the entire server several times haven't remedied the situation.  I am going to try and re-install the application to see if that will fix the problem.
I'll let you know if a re-install fixes the problem.
RKha
Hi every one , really i read many solutions but no one work , so i am traying to reinstall th call manager . cuse when installation proccess maybe some servese not installed probably fine , i am perceptive that the Tomcat services the responsible servecis for these issue .
after i will reinstall it i will inform you
HI friend,
thanks!
Hello
Hi friend
i have a problem with Vmware...
it possible don't re-install? where is the problem? a tomcat service? a Callmanager service?
thanks
RKha
Thank you every one for participate ,Emanuele Padovano no i am traying to stop and run the Tomcat service it not work maybe the tomcat not installe correctly or error had occure within the installation, and thank you  afischer1  for your answer .
No problem, I had tried the same thing.  I restarted the Tomcat and Call Manager Services a lot before finally re-installing,  I was pretty frustrating.  Now that that I have a good install I made sure to take a snapshot in VM so that if anything goes wrong I can easily revert back to it.
Best of luck with the re-install.
RKha
thanx alot afischer1 .
see you in another question
Hi All
I just installed the latest patch to fix vulnerability
ciscocm.removeVIR.cop.sgn
and it kills the ccmadmin web page.  I tried and stopped the Cisco Tomcat service but no luck.  Reboot did not help as well.
Is there a way to fix
Brent Rockburn
Level 2
Level 2
I'm having this issue, with cmplatform. Also in a VM. Has anyone figured this out? Or am I doomed to a reinstall?
Yes Brent reinstall it ,, i did not find any solution , when i reinstall it , work fine
