I need to configure h323 output groups
jserce
I need to configure h323 output groups. Ie, for a user groups need to go through a FX0 (1) and another different groups of users occupying FX0 other door (2). How I can do this?
I usually just configure route patterns with a prefix, on the GW configure the POTS DPs with that prefix and since it's going to be an exact match it will be stripped and you'll only send the original digits out.
ie route pattern 5XXX, prefix 152
destination-pattern 152XXXX
port 0/0
route pattern 5XXX, prefix 151
destination-pattern 151XXXX
port 0/1
Just adjusts CSS and partitions so that the users reach the right route pattern which will prefix the right digits depending on what FXO you want to use.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
5 Replies 5
Jaime Valencia
You always need to mention what product you're using (CUCM, CME, UC520, etc and version) and not just what you're trying to do.
java
java
Sorry. I'm using CUCM 7.1.5. Thanks
port 0/0
port 0/1
java
java
Chris Deren
You'll need to use cor-lists, you can find plenty of good examples here and on Cisco pages.
HTH,
Chris
No need to place restrictions. Just assign a resource (FXO) to a group of users and other resources (other different FXO) to other specific users. Both outputs (FXO) have the same privileges.
