ā04-12-2013 02:08 PM - edited ā03-16-2019 04:46 PM
i have two problems i have cucm v7 and gateway which connected to E1 , outgoing all are ok.Incoming calls are hit the gateway but i get an errir in debug isdn q931 unallocated unassigned number , i am sure of my configuration. Please help , i shared my outgoing call for 911 and incoming call
dial-peer voice 911 pots
destination-pattern 911
port 0/1/0
dial-peer voice 1 pots
incoming called-number 4420804...
transltation-profile incoming incoming
direct-inward-dial
Solved! Go to Solution.
ā04-12-2013 02:15 PM
hi
for outgoing call please make sure that your pattern 911 match on gateway and cucm RP , i hope to add the below command to dial-peer 911
no digit-strip
or
forward -digits 3
thank you please rate
ā04-12-2013 02:21 PM
sorry , i missed 2nd request for the incoming please check that
1the problem of unallocated number is a famous problem but it has many reasons , if the call hit the gateway and canot reach to your cucm and based on the above configuration , maybe you miss the below
dial-peer voice 2 voip
destination-pattern 4...
session target ipv4 ip of your cucm
codec g711ulaw
please share the configuration
thank you
pkease rate if this will help
ā04-12-2013 03:03 PM
Ensure the CSS on the GW has access to the partition of the DN. Also, make sure the sig digits are properly set on the GW.
Please post your translation rule config as well along with "debug isdn q931" and the screen shot of the GW configuration in CUCM.
HTH,
Chris
hi
no digit-strip
or
forward -digits 3
codec g711ulaw
thank you
HTH,
Chris
ā04-12-2013 03:43 PM
thanks chris , all you mentioned are ok . Thanks kamal , i will check tomorrow your posts
my translation rule
voice translation-rule 1
rule 1/\(4420804)\(....\)/ /\2/
voice translation-profile incoming
translate called 1
thanks for help
ā04-13-2013 08:43 AM
Thanks Chris and kamal , i solved my two existing problems .
