I have a SIP provider and they want the phone number to be presented as 12016543343 I have to dial a 9 to get out of CME. I do not want to dial an extra "1" and then the 10 digit phone number. A simple translation rule to strip th...
Hi friends my task is to setup 3745 router as analogue PABX and i need your help.The router has 2 NM-2V with 8 Voice Ports where 6 are FXS and 2 are FXO1 FXO is connected to BT Landline , 1 FXO is free for future uses.6 FXS are connected to standard ...
In "enterprise parameters configuration", you can't choose which server you select, so I know the parameters are cluster-wide. But in "service parameter configuration", you have to choose which server. Does that mean the parameters are only applied t...
SNR and CFA to external numbers are not working following a cutover to a different phone carrier.I was talking with somebody else and thought I needed to set up a forwarding number translation pattern.I'm not entirely sure how to set that up, if that...
Hi All,We have CUCM 8.6.2.20000.1 (CUBE) and 7945(SCCP45.9-2-3S) when phone is in power saving mode, when incoming calls comes phone does not comes out of power saving mode, we have to reset netowrk connectivity phone started working fine. Phones are...
Hi,This is a new site in the existing Cisco Unity connection 8 server, hence i had to create a new user templae, in which i did not select "Set for self-enrolment at next login". and gave a default user password as 123456.Now the p...
I have an user that is complaining about his CIPC 8.6.1.0 popping to the foreground at random times (several times a day) for no reason. He is not getting a call... but he does have the option "Bring to front on active call" checked. So it would ma...
I need to connect 4 X ISDN BRI ports to the Telco for PSTN connectivity, would i use a cross-over cable or a straight-through cable to the Telco from my Cisco Router? I tried a Straight through and could only get layer one active but failed to bring ...
Hi guysHave any situation or solution for when use AppServer 8.5 with Webex Scheduling the users/account can login by AD/LDAP?We are replacing the MPE 2.x for MP8.5 and in old system the login by AD/LDAP was possible.I'm thinking about SSO but I'm no...
Hi,I'm using a UCM 8.5(1) with COP for Jabber for iPhone and iPad, but it refuses my connection and it aky for a password.Where should I configure that password?How do I login on to my chisco Jabber?
Hi,CUCM 8.6.2.21900-5Cisco IP 7962I wondering if there is a way to configure the Cico IP Phone to answer a incoming call only using the phone buttons, even you on hook the hand-set.Example:Incoming call -> on hook handset -> The calls is still un ans...
Hello, is it possible to configure B-ACD in a UC560 so that a caller has the option to transfer "out" to leave a VM in a GDM?I see no options in CCA Basic ACD to choose anything but different prompts.We'd like to be able to let the caller press a "di...
Hi folks....I am trying to setup a home lab where i have a PSTN router which provides E1 connectivity to two other routers (preparing for CCIE). I have no experience in setup up an E1 connection from the PSTN side hence facing issues.... i have check...
I have 3x CUC clusters arranged in an INTRASITE architecture configuration. All 3x clusters are configured to be able to import users from CUCM (via AXL).On CUC-Cluster-1, when I import a user ‘testuser1’ from CUCM, that user is correctly replicated...
Call Manager System version: 8.5.1.10000-26A few years ago in version 4.x I added an intercom button onto our admins second line space with a fake number "1000". I set the "Directory Number Information" to "Auto answer with speakerphone". I then adde...
Subject | Author | Posted |
07-14-2025 11:42 AM | ||
07-14-2025 08:15 AM | ||
07-09-2025 09:52 AM | ||
07-08-2025 12:50 PM | ||
07-02-2025 08:49 AM |
User | Count |
2 | |
2 | |
1 | |
1 | |
1 |
