Inbound Call Control
darijohorvat
Hi!
I have defined Meet-Me number. How can I restrict access to this number (calls from PSTN), in the way that only specific external telephone number can access this pattern?
Is this possible?
thx
paolo bevilacqua
Do you have CME or CM and which version., If the latter are you using H.323 or MGCP to the GW ?
sorry, here is the info
CM 4.1(3) with MGCP
If you have Unity or IPCC , you can do a supervised transfer, where the User should provide a PIN and tell his Name before he get connected to the Meet-Me conference.
There is no other solution for this problem.
