09-04-2013 02:05 PM - edited 03-16-2019 07:12 PM
Hello Friends,
I´m working with CUCM 6.1 and route pattern and calls to PSTN. I´m receiving and sending 4 digits from PSTN at MGCP Gw.
MGCP Gw -> PSTN (4digits) OK
Phones -> Phones (4 digits) OK
PSTN -> MGCP Gw (4 digits) NOK
CSS OK
Partitions OK
0.2[^1]XXXXXX part_local_Chicureo (look m3 file)
Any another idea?
09-04-2013 02:09 PM
can you send debug isdn q931...
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
09-04-2013 02:12 PM
172.20.200.20#
*Sep 3 20:18:21.913: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x07B2
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Calling Party Number i = 0x0181, '24139496'
Plan:ISDN, Type:Unknown
Called Party Number i = 0xA1, '5253'
Plan:ISDN, Type:National
Sending Complete
*Sep 3 20:18:25.913: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x07B2
Standard = CCITT
Sending Complete
*Sep 3 20:18:29.941: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x07B2
Cause i = 0x80E6 - Recovery on timer expiry
09-04-2013 02:25 PM
Your gateway is not responding to the setup request from the PSTN. That is strange and weird. What is the status of your isdn?
sh isdn status
show ccm-manager
06-12-2017 05:50 AM
09-04-2013 11:43 PM
Try to reset the Gateway. Is there any transaltion pattern configured ?
09-06-2013 06:29 AM
Selvarathnam,
Reset Gateway Ok
Reset MGCP Service Ok
Gateway does not have any translation pattern.
09-05-2013 02:32 AM
Collect the following logs:
++ Show version
++ Show tun
++ debug voip ccapi inout
++ debug isdn q931
++ debug isdn events
09-05-2013 06:44 AM
Hello Friends.
Please, look the file.
I called from:
2413 9496 - > 2950 5253
PSTN-> 5253 - > Gw
_________________________________________________
172.20.200.20#
Standard = CCITT
Sending Complete
Standard = CCITT
Sending Complete
____________________________________________________________
172.20.200.20#show isdn status
Global ISDN Switchtype = primary-net5
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 0. Layer 3 output may not apply
ISDN Serial0/0/0:15 interface
dsl 0, interface ISDN Switchtype = primary-net5
L2 Protocol = Q.921 0x0000 L3 Protocol(s) = CCM MANAGER 0x0003
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0xFFFF7FFF
Number of L2 Discards = 0, L2 Session ID = 35
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 1. Layer 3 output may not apply
ISDN Serial0/1/0:15 interface
dsl 1, interface ISDN Switchtype = primary-net5
Layer 1 Status:
ACTIVE
Layer 2 Status:
Layer 3 Status:
Active dsl 1 CCBs = 0
Number of L2 Discards = 0, L2 Session ID = 170
Total Allocated ISDN CCBs = 0
_____________________________________________________________________________________
172.20.200.20#show ccm-manager
MGCP Domain Name: 172.20.200.20
Priority Status Host
Primary Registered 172.20.200.15
First Backup Backup Ready 172.20.200.16
Second Backup None
Current active Call Manager: 172.20.200.15
Backhaul/Redundant link port: 2428
Failover Interval: 30 seconds
Keepalive Interval: 15 seconds
Last keepalive sent: 13:03:33 UTC Sep 5 2013 (elapsed time: 00:00:13)
Last MGCP traffic time: 13:03:33 UTC Sep 5 2013 (elapsed time: 00:00:13)
Last failover time: 16:15:53 UTC Aug 7 2013 from (172.20.200.15)
Last switchback time: 16:16:23 UTC Aug 7 2013 from (172.20.200.16)
Switchback mode: Immediate
MGCP Fallback mode: Enabled/OFF
Last MGCP Fallback start time: 16:16:42 UTC Aug 7 2013
Last MGCP Fallback end time: 16:17:34 UTC Aug 7 2013
MGCP Download Tones: Disabled
TFTP retry count to shut Ports: 2
Backhaul Link info:
Link Protocol: TCP
Remote Port Number: 2428
Remote IP Address: 172.20.200.15
Current Link State: OPEN
Statistics:
Packets recvd: 471
Recv failures: 0
Packets xmitted: 597
Xmit failures: 0
PRI Ports being backhauled:
Slot 0, VIC 0, port 0
Slot 0, VIC 1, port 0
Configuration Error History:
FAX mode: cisco
172.20.200.20#
172.20.200.20#debug voip ccapi inout
voip ccapi inout debugging is on
172.20.200.20#
*Sep 5 13:09:41.179: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x45372E1C, Interface Type=6, Destination=, Mode=0x9,
Call Params(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=A
d),
Called Number=(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id
00000408b880000000F580001da5)
*Sep 5 13:09:41.179: //4615278/426E3569B642/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
*Sep 5 13:09:41.179: //4615278/426E3569B642/CCAPI/ccCallSetContext:
Context=0x44D8D8A8
Interface=0x44FDA58C, Interface Type=9, Destination=0.0.0.0, Mode=0x9,
d),
Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=TRUE,
*Sep 5 13:09:41.179: //4615279/426E3569B642/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=9, FlowMode=1
*Sep 5 13:09:41.179: //4615279/426E3569B642/CCAPI/ccCallSetContext:
Context=0x44D8B0A0
*Sep 5 13:09:41.183: //4615279/426E3569B642/CCAPI/cc_api_call_connected:
Interface=0x44FDA58C, Data Bitmask=0x0, Progress Indication=NULL(0),
Connection Handle=0
Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
*Sep 5 13:09:41.187: //4615278/426E3569B642/CCAPI/cc_api_call_proceeding:
Interface=0x45372E1C, Progress Indication=NULL(0)
*Sep 5 13:09:41.187: //4615278/426E3569B642/CCAPI/cc_api_call_connected:
Interface=0x45372E1C, Data Bitmask=0x1, Progress Indication=DESTINATION IS NON ISDN(2),
Connection Handle=0
*Sep 5 13:09:41.187: //4615278/426E3569B642/CCAPI/ccCallModify:
Nominator=0x1000, Params=0x466CB360, Call Id=4615278
*Sep 5 13:09:41.187: //4615278/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
(callID=0x466C6E, digit_event=0x1, enable=TRUE, consume=FALSE)
*Sep 5 13:09:41.187: //4615278/426E3569B642/CCAPI/ccCallReportDigits:
Enabled=TRUE, Call Id=4615278
*Sep 5 13:09:41.187: //4615278/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x45372E1C, callID=0x466C6E, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
*Sep 5 13:09:41.187: //4615278/426E3569B642/CCAPI/cc_api_call_report_digits_done:
Enabled=TRUE, Disposition=0x0, Interface=0x45372E1C, Call Id=4615278
Call Entry(Initial Digit Timeout=10000(ms), Inter Digit Timeout=10000(ms))
*Sep 5 13:09:41.187: //4615278/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
(confID=0x466CB4BC, callID1=0x466C6E, callID2=0x466C6F, tag=0x0)
*Sep 5 13:09:41.187: //4615278/426E3569B642/CCAPI/ccConferenceCreate:
Conference Id=0x466CB4BC, Call Id1=4615278, Call Id2=4615279, Tag=0x0
*Sep 5 13:09:41.187: //4615278/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0x233630, Source Interface=0x45372E1C, Source Call Id=4615278,
Destination Call Id=4615279, Disposition=0x0, Tag=0xFFFFFFFF
*Sep 5 13:09:41.191: //4615279/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0x233630, Source Interface=0x44FDA58C, Source Call Id=4615279,
Destination Call Id=4615278, Disposition=0x0, Tag=0x0
*Sep 5 13:09:41.191: //4615278/426E3569B642/CCAPI/cc_generic_bridge_done:
*Sep 5 13:09:41.191: //4615278/426E3569B642/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x233630, Destination Call Id=4615279)
*Sep 5 13:09:41.191: //4615279/426E3569B642/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x233630, Destination Call Id=4615278)
*Sep 5 13:09:41.191: //4615278/426E3569B642/CCAPI/cc_api_caps_ind:
Destination Interface=0x44FDA58C, Destination Call Id=4615279, Source Call Id=4615278,
Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
Modem=0x2, Codec Bytes=20, Signal Type=3)
Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Playout Max=200(ms), Fax Nom=300(ms))
*Sep 5 13:09:41.191: //4615279/426E3569B642/CCAPI/cc_api_caps_ind:
Destination Interface=0x45372E1C, Destination Call Id=4615278, Source Call Id=4615279,
Caps(Codec=0x1, Fax Rate=0x2, Vad=0x1,
Modem=0x0, Codec Bytes=160, Signal Type=2)
Playout Max=250(ms), Fax Nom=300(ms))
*Sep 5 13:09:41.191: //4615279/426E3569B642/CCAPI/cc_api_caps_ack:
Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=5522)
*Sep 5 13:09:41.191: //4615278/426E3569B642/CCAPI/cc_api_caps_ack:
*Sep 5 13:09:41.195: //4615278/426E3569B642/CCAPI/cc_api_call_modify_done:
Result=0, Interface=0x45372E1C, Call Id=4615278
*Sep 5 13:09:41.195: //4615278/426E3569B642/CCAPI/cc_api_voice_mode_event:
Call Id=4615278
Call Entry(Context=0x44D8D8A8)
*Sep 5 13:09:41.195: //4615278/426E3569B642/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x233630, Call Id1=4615278, Call Id2=4615279
*Sep 5 13:09:41.199: //4615278/426E3569B642/CCAPI/ccSetDigitTimeouts:
Initial Digit Timeout=4000(ms), Inter Digit Timeout=4000(ms)
Call Entry(Inter Digit Timeout=4000(ms), Initial Digit Timeout=4000(ms))
*Sep 5 13:09:41.199: //4615278/426E3569B642/CCAPI/ccRestartDigitTimeoutMsec:
Digit Timeout=0, Call Id=4615278
*Sep 5 13:09:41.199: //4615278/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
*Sep 5 13:09:41.199: //4615278/426E3569B642/CCAPI/ccCallReportDigits:
*Sep 5 13:09:41.199: //4615278/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
*Sep 5 13:09:41.199: //4615278/426E3569B642/CCAPI/cc_api_call_report_digits_done:
Call Entry(Initial Digit Timeout=4000(ms), Inter Digit Timeout=4000(ms))
*Sep 5 13:09:41.307: //4615278/426E3569B642/CCAPI/ccCallModifyExtended:
Nominator=0x466CB0D0, Params=0x466CA718, Call Id=4615278
*Sep 5 13:09:41.307: //4615279/426E3569B642/CCAPI/ccCallModify:
Nominator=0x18E30, Params=0x466CA860, Call Id=4615279
*Sep 5 13:09:41.307: //4615278/426E3569B642/CCAPI/cc_api_call_modify_done:
*Sep 5 13:09:41.311: //4615279/426E3569B642/CCAPI/cc_api_call_modify_done:
Result=0, Interface=0x44FDA58C, Call Id=4615279
*Sep 5 13:09:45.199: //4615278/426E3569B642/CCAPI/cc_handle_inter_digit_timer:
Generate inter-digit timeout CC_EV_CALL_DIGIT_END event
*Sep 5 13:10:00.195: //4615278/426E3569B642/CCAPI/ccCallModifyExtended:
*Sep 5 13:10:00.195: //4615279/426E3569B642/CCAPI/ccCallModify:
Nominator=0x800, Params=0x466CA860, Call Id=4615279
*Sep 5 13:10:00.195: //4615278/426E3569B642/CCAPI/cc_api_call_modify_done:
*Sep 5 13:10:00.195: //4615279/426E3569B642/CCAPI/cc_api_call_modify_done:
*Sep 5 13:10:00.203: //4615278/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
(callID=0x466C6E, digit_event=0x0, enable=FALSE, consume=FALSE)
*Sep 5 13:10:00.203: //4615278/426E3569B642/CCAPI/ccCallReportDigits:
*Sep 5 13:10:00.203: //4615278/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x45372E1C, callID=0x466C6E, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
*Sep 5 13:10:00.203: //4615278/426E3569B642/CCAPI/cc_api_call_report_digits_done:
*Sep 5 13:10:00.203: //4615279/426E3569B642/CCAPI/ccGetCallStatistics:
Call Stats=0x4416CB08, Call Id=4615279
*Sep 5 13:10:00.207: //4615278/426E3569B642/CCAPI/ccConferenceDestroy:
Conference Id=0x233630, Tag=0x0
*Sep 5 13:10:00.207: //4615278/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Destination Call Id=4615279, Disposition=0x0, Tag=0x0
*Sep 5 13:10:00.207: //4615279/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
*Sep 5 13:10:00.207: //4615278/426E3569B642/CCAPI/cc_generic_bridge_done:
*Sep 5 13:10:00.207: //4615278/426E3569B642/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
*Sep 5 13:10:00.207: //4615278/426E3569B642/CCAPI/cc_api_get_transfer_info:
Transfer Number Is Null
*Sep 5 13:10:00.207: //4615279/426E3569B642/CCAPI/ccCallDisconnect:
*Sep 5 13:10:00.211: //4615279/426E3569B642/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x44FDA58C, Tag=0x0, Call Id=4615279,
Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
*Sep 5 13:10:00.215: //4615278/426E3569B642/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x45372E1C, Tag=0x0, Call Id=4615278,
*Sep 5 13:10:00.219: //4615278/426E3569B642/CCAPI/cc_api_call_disconnect_done:
172.20.200.20#sh run
Building configuration...
Current configuration : 2805 bytes
version 12.4
hostname 172.20.200.20
boot-start-marker
boot system flash:c2800nm-ipvoicek9-mz.124-19.bin
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
network-clock-participate wic 0
network-clock-participate wic 1
network-clock-select 1 E1 0/0/0
ip cef
no ip domain lookup
isdn switch-type primary-net5
voice-card 0
dspfarm
no local-bypass
username toip privilege 15 secret 5 $1$oJRv$6.bQa33NY7TnFWcPOaggj/
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31 service mgcp
description CS2K
controller E1 0/1/0
framing NO-CRC4
description PRIOPERADORAS
interface FastEthernet0/0
ip address 172.20.200.20 255.255.254.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bind-l3 ccm-manager
interface Serial0/1/0:15
no ip address
encapsulation hdlc
no cdp enable
no ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 172.20.200.1
ip route 172.20.0.0 255.255.0.0 172.20.200.1
ip route 192.168.255.0 255.255.255.0 172.20.200.1
no ip http server
no ip http secure-server
control-plane
voice-port 0/0/0:15
voice-port 0/1/0:15
ccm-manager switchback immediate
ccm-manager fallback-mgcp
ccm-manager redundant-host 172.20.200.16
ccm-manager mgcp
ccm-manager config server 172.20.200.15
mgcp
mgcp call-agent 172.20.200.15 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp profile default
dial-peer voice 1 pots
service mgcpapp
destination-pattern .T
direct-inward-dial
port 0/0/0:15
dial-peer voice 3 voip
service mgcpapp
destination-pattern ....
session target ipv4:172.20.200.15
incoming called-number .T
codec g711alaw
dial-peer voice 2 pots
service mgcpapp
direct-inward-dial
port 0/1/0:15
call-manager-fallback
secondary-dialtone 0
max-conferences 16 gain -6
user-locale ES
limit-dn 7940 2
limit-dn 7960 2
ip source-address 172.20.200.20 port 2000
max-ephones 42
max-dn 144
system message primary Servicio de
system message secondary Emergencia Activo
access-code pri 0 direct-inward-dial
moh music-on-hold.au
time-format 24
date-format dd-mm-yy
line con 0
login local
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
privilege level 15
login local
scheduler allocate 20000 1000
end
__________________________________________________________________________________________
172.20.200.20#sh version
Cisco IOS Software, 2800 Software (C2800NM-IPVOICEK9-M), Version 12.4(19), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 29-Feb-08 20:08 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)T7, RELEASE SOFTWARE (fc1)
172.20.200.20 uptime is 1 year, 49 weeks, 2 days, 20 hours, 52 minutes
System returned to ROM by reload at 16:21:45 UTC Sun Sep 25 2011
System image file is "flash:c2800nm-ipvoicek9-mz.124-19.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Cisco 2811 (revision 53.51) with 249856K/12288K bytes of memory.
Processor board ID FTX0918A2CT
2 FastEthernet interfaces
62 Serial interfaces
2 Channelized E1/PRI ports
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62976K bytes of ATA CompactFlash (Read/Write)
09-05-2013 07:20 AM
I suggest you upgrade the IOS on the router first. You should also remove the service mgcpapp under your dial-peers. Thats an old command that you dont need any more..
09-06-2013 05:51 AM
Aokanlwon
If you upgrade IOS and you delete the mgcpapp command the problem goes on.....
Can you give me any specific solution?
09-06-2013 06:35 AM
Hi Claudio.
Can you please check on CUCM what is the value of T301 timer?
Carlo
Please rate all helpful posts
"The more you help the more you learn"
09-06-2013 09:22 AM
Carlo,
T301 Timer CUCM: 180000
172.20.200.20#show isdn timers
ISDN Serial0/0/0:15 Timers (dsl 0) Switchtype = primary-net5
ISDN Layer 2 values
K = 7 outstanding I-frames
N200 = 3 max number of retransmits
T200 = 1.000 seconds
T202 = 2.000 seconds
T203 = 10.000 seconds
ISDN Layer 3 values
T301 = 180.000 seconds
T303 = 4.000 seconds
T304 = 30.000 seconds
T305 = 30.000 seconds
T306 = 30.000 seconds
T307 = 180.000 seconds
T308 = 4.000 seconds
T309 Disabled
T310 = 40.000 seconds
T313 = 4.000 seconds
T316 = 120.000 seconds
T318 = 4.000 seconds
T319 = 4.000 seconds
T322 = 4.000 seconds
T3OOS = 5.000 seconds
TGUARD= 8.000 seconds, Expiry = REJECT_CALL
T-activate = 4.000 seconds
ISDN Serial0/1/0:15 Timers (dsl 1) Switchtype = primary-net5
ISDN Layer 2 values
ISDN Layer 3 values
T309 Disabled
*** dsl 2 is not configured
*** dsl 3 is not configured
*** dsl 4 is not configured
*** dsl 5 is not configured
*** dsl 6 is not configured
*** dsl 7 is not configured
*** dsl 8 is not configured
*** dsl 9 is not configured
*** dsl 10 is not configured
*** dsl 11 is not configured
*** dsl 12 is not configured
*** dsl 13 is not configured
*** dsl 14 is not configured
*** dsl 15 is not configured
*** dsl 16 is not configured
*** dsl 17 is not configured
*** dsl 18 is not configured
*** dsl 19 is not configured
*** dsl 20 is not configured
*** dsl 21 is not configured
*** dsl 22 is not configured
*** dsl 23 is not configured
*** dsl 24 is not configured
*** dsl 25 is not configured
*** dsl 26 is not configured
*** dsl 27 is not configured
*** dsl 28 is not configured
*** dsl 29 is not configured
*** dsl 30 is not configured
*** dsl 31 is not configured
*** dsl 32 is not configured
*** dsl 33 is not configured
*** dsl 34 is not configured
*** dsl 35 is not configured
*** dsl 36 is not configured
*** dsl 37 is not configured
*** dsl 38 is not configured
*** dsl 39 is not configured
*** dsl 40 is not configured
*** dsl 41 is not configured
*** dsl 42 is not configured
*** dsl 43 is not configured
*** dsl 44 is not configured
*** dsl 45 is not configured
*** dsl 46 is not configured
*** dsl 47 is not configured
09-05-2013 07:23 AM
Hi Claudio.
On your CUCM, check with the route plan report if you have overlapping pattern..
In case, modify the inbound Calling search space on gateway (ports) matching internal extensions only.
Another option, is to decrease the t301 timer... but first check the routing.,
Carlo
09-05-2013 07:25 AM
Carlo,
The gateway is not even responding to the call setup...I doubt if this is routing related...This is an inbound call...
On the q931 setup message, the gateway need to respond with a q931 setup ACK
