Inbound Calls fail PSTN Gateway
Hello Friends,
I´m working with CUCM 6.1 and route pattern and calls to PSTN. I´m receiving and sending 4 digits from PSTN at MGCP Gw.
MGCP Gw -> PSTN (4digits)      OK
Phones -> Phones (4 digits)      OK
PSTN -> MGCP Gw (4 digits)     NOK
CSS   OK
Partitions    OK
0.2[^1]XXXXXX          part_local_Chicureo (look m3 file)
Any another idea?
22 Replies 22
Carlo,
The CSS is 4 digits,
The similars routern pattern are in diferent partitions, please look the files: m1, m2, m3 y m4.
For local numbers try with subscriber format.
Nishant Savalia
Level 4
Level 4
Hi Claudio,
Can you please share debug mgcp packets of gateway and trace from RTMT as well.
Regards, Nishant Savalia
Nishant,
    Cisco Unified Communications Manager Dialed Number Analyzer  Results
  • Results  Summary
    • Calling Party Information
      • Calling Party = 24139496
      • Partition =
      • Device CSS =
      • Line CSS = Local Chicureo
      • AAR Group Name =
      • AAR CSS =
    • Dialed Digits = 029505253
    • Match Result = RouteThisPattern
    • Matched Pattern Information
      • Pattern = 0.2[^1]XXXXXX
      • Partition = part_local_Chicureo
      • Time Schedule =
    • Called Party Number = 29505253
    • Time Zone = Greenwich Standard Time
    • End Device = GW_2811_CS2K
    • Call Classification = OffNet
    • InterDigit Timeout = NO
    • Device Override = Disabled
    • Outside Dial Tone = NO
  • Call Flow
    • Route  Pattern :Pattern= 0.2[^1]XXXXXX
      • Positional Match List =  29505253
      • DialPlan =
      • Route  Filter
      • Require Forced  Authorization Code = No
      • Authorization Level = 0
      • Require Client Matter  Code = No
      • PreTransform Calling Party  Number = 24139496
      • PreTransform Called Party  Number = 029505253
      • Calling Party Transformations
        • External Phone Number  Mask = NO
        • Calling Party Mask =
        • Prefix =
        • CallingLineId  Presentation = Default
        • CallingName Presentation =  Default
        • Calling Party Number =  24139496
      • ConnectedParty Transformations
      • Called Party Transformations
        • Called Party Mask =
        • Discard Digits  Instruction = PreDot
        • Prefix =
        • Called Number = 29505253
    • Route  List :Route List Name=  GW_2811_CS2K
      • RouteGroup :RouteGroup  Name= GW_2811_CS2K
          • External Phone Number  Mask = On
          • Prefix =
          • Discard Digits  Instructions =
          • Prefix =
          • Called Number = 029505253
        • Device :Type= MGCPE1PRIPort
          • End Device Name =  S0/SU0/DS1-0@172.20.200.20
          • PortNumber = 0
          • Device Status = Registered
          • AAR Group Name =
          • AAR Calling Search Space =
          • AAR Prefix Digits =
          • Calling Party Selection =
          • CallingLinePresentation =
          • ConnectedLinePresentation =
          • Number Of Strip Digits =
          • CallerID DN =
  • Alternate Matches
    • Note: Information Not Available
172.20.200.20#terminal monitor
172.20.200.20#debug isdn q931
debug isdn q931 is              ON.
172.20.200.20#
*Sep  6 18:07:38.259: MGCP Packet sent to 172.20.200.15:2427--->
NTFY 365618475 *@172.20.200.20 MGCP 0.1
X: 0
O:
*Sep  6 18:07:38.259: MGCP Packet received from 172.20.200.15:2427--->
200 365618475
*Sep  6 18:07:52.235: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x1E66
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Calling Party Number i = 0x0181, '24139496'
                Plan:ISDN, Type:Unknown
        Called Party Number i = 0xA1, '5253'
                Plan:ISDN, Type:National
        Sending Complete
*Sep  6 18:07:52.243: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x9E66
        Cause i = 0x809B - Destination out of order
*Sep  6 18:07:53.259: MGCP Packet sent to 172.20.200.15:2427--->
NTFY 365618476 *@172.20.200.20 MGCP 0.1
X: 0
O:
*Sep  6 18:07:53.259: MGCP Packet received from 172.20.200.15:2427--->
200 365618476
172.20.200.20#terminal no monitor
*Sep  6 18:08:08.259: MGCP Packet sent to 172.20.200.15:2427--->
NTFY 365618477 *@172.20.200.20 MGCP 0.1
X: 0
O:
*Sep  6 18:08:08.259: MGCP Packet received from 172.20.200.15:2427--->
200 365618477
This box has been up for a year. Have considered rebooting before troubleshooting further this issue.
It could save you time and energy .
Please rate helpful answers!
Is it just happening for the single number "5253" or for all number.
I see you have two E1, is the other one acting as a backup for inbound and outbound calls.
If so, can you shut the E1 0/0/0 and see how the calls are working on other controller.
From my understanding it seems like call manager is not responding with CRCX after the Gateway NTFY about the inbound event. Can you try negate mgcp with "no mgcp" and add mgcp back and test the calls.
It would be great if you can pull the detailed CUCM trace and attach here.
Kasi
Hi Claudio,
This time your gateway resonded and your gateway is sending different release code "Destination out of Order" to the PSTN.
Have you done any kind of modification?
Also please share the detailed RTMT trace of CUCM as well.
Thanks & Regards,
Nishant Savalia
Nishant,
I´ve never used RTMT trace. Please give me steps  i Want to do it as soon as possible.
