Inbound Calls not working on cucm
Alexander Nejo
We have CUCM>>>> VOICE GATEWAY>>>>>>PSTN
Inbound calls to pilot number "08039055000" is working fine but calls to the direct lines i.e "08035095207" is not working.
I did a dna and attached is the outcome.
Kindly advise on what to do
22 Replies 22
Steven L
need to post some debugs.....is this SIP or ...something else?
It is PSTN with MGCP registration
Can you please provide a screenshot of the entire MGCP gateway and port configuration from CM, also include any transformations patterns that you might have defined being in use, any CSS that you have the partition(s) for these transformations in, plus the content of the inbound CSS set on the port. We need to make sure that the MGCP gateway has visibility of the directory number as it stands after transformation(s).
Response Signature
Also can you please provide the output for debug isdn q931 for a working and a non working call in an attached text file? As we’re at it asking for text files can you please also share your entire running configuration, minus any sensitive information, in another file for us to validate your configuration? Not that is all that much to validate in a MGCP setup, but it can’t hurt to have a few extra pairs of eyes looking over it.
Response Signature
What is the Partition on the internal DNs and what Inbound Calling Search Space is on the gateway?
Maren
The internal Partition is "internal-Pt" while the inbound CSS "VGW-Inbound-CSS"
Is Internal-PT in the VGW-Inbound-CSS?
Response Signature
Yes, it is
The Partition on Internal DN is "Internal-PT" while the CSS on the Gateway is "VGM-Inbound-CSS"
AFAIK the DNA is made for a directory number that is 5195, not 5207 as you wrote in your original post. What is your number scheme, do you have 4 digit extensions?
Response Signature
Yes, we have 4 digits extensions
Alexander Nejo
The DNA is for extension 5207
That I have some doubts about as the DNA output for called number is this.
Dialed Digits = 08039055195
Match Result = RouteThisPattern
Matched Pattern Information
Pattern = 5195
So no it does not seem to be made for the number (5207) you state.
Response Signature
Alexander Nejo
Hello Roger, What doubt do have about it?
