incoming pots line help (call mgr express)
yzbobyzbob
hi all.
Hoping someone can point me in the right direction. I don't usually dabble with Call manager express so my voice skill are pretty limited (as you can see from the below questions).
We have recently changed from sip lines to analog. (numbers xxxx and yyyyy are no longer relevant to the new incoming analog numbers. ultimately the sip details can all be deleted but i'm leaving them in to make it easier to add back at a later date if needed).
After some reading up and making some minor changes I can successfully make calls out over 001 and 002 (dial-peer voice 106 & 107 pots) but can only receive incoming calls on the vsat line 001 line.
for now 003,004,005,006 are all irrelevant.  But phone lines 005 and 006 are receiving incoming calls as well. We no longer have faxes so that can probably get tidied up.
In the sanitised config below I am receiving outside calls through voice port 0/1/0
but i'm not receiving calls coming from the line connected to voice port 0/1/1
I just want to understand why calls are successfully coming in on Vsat line 001 so that i can replicate it onto 002.  Also let me know if i should be adding other instructions to make everything proper and correct.
I would much appreciate if someone could explain to me what instructions are allowing the incoming calls to process. i understand the translation rules and dial-peers much better for outgoing calls than i do for incoming and if you notice other amateur mistakes below please point them out to me. Thanks.
CME#show run
voice service voip
 allow-connections sip to sip
 redirect ip2ip
 sip
  bind control source-interface GigabitEthernet0/1
  bind media source-interface GigabitEthernet0/1
  header-passing
voice class codec 10
 codec preference 1 g729r8
 codec preference 2 g711ulaw
voice register global
 system message
 max-dn 192
 max-pool 58
voice hunt-group 21 sequential
 final 260
 list 110,260,160,320
 timeout 18
 pilot 901
voice hunt-group 25 parallel
 final 160
 list 110,260,261,320
 timeout 18
 pilot 905
voice hunt-group 26 parallel
 final 160
 timeout 18
 pilot 906
voice hunt-group 27 sequential
 final 260
 list 200,110
 timeout 18
 pilot 907
voice hunt-group 28 parallel
 list 260,261,250,151,161,320
 timeout 40
 pilot 908
voice hunt-group 29 sequential
 final 260
 list 210,110
 timeout 18
 pilot 909
voice hunt-group 30 sequential
 final 260
 list 220,130,320
 timeout 18
 pilot 910
voice hunt-group 31 parallel
 list 130,140
 timeout 40
 pilot 911
voice hunt-group 32 parallel
 list 500,510,430,420,400,410
 timeout 40
 pilot 912
voice translation-rule 10
 rule 1 /1$/ /1#/
 rule 2 /2$/ /2#/
 rule 3 /3$/ /3#/
 rule 4 /4$/ /4#/
 rule 5 /5$/ /5#/
 rule 6 /6$/ /6#/
 rule 7 /7$/ /7#/
 rule 8 /8$/ /8#/
 rule 9 /9$/ /9#/
 rule 10 /0$/ /0#/
voice translation-rule 11
 rule 1 /xxxxxxxxxxx/ /910/
 rule 2 /yyyyyyyyyyy/ /130/
voice translation-rule 12
 rule 1 /^00100/ /00/
 rule 2 /^0011/ /1/
 rule 3 /^00200/ /00/
 rule 4 /^0021/ /1/
voice translation-rule 13
 rule 1 /220/ /xxxxxxxxxxx/
 rule 2 /130/ /yyyyyyyyyyy/
voice translation-profile Add_Pound
 translate called 10
voice translation-profile SIP_Provider_in
 translate called 11
voice translation-profile SIP_Provider_out
 translate calling 13
 translate called 12
voice-card 0
 no dspfarm
control-plane
voice-port 0/0/0
 no echo-cancel enable
 compand-type a-law
 cptone NL
 timeouts call-disconnect 2
 timeouts wait-release 2
 description Fax (190)
 bearer-cap 3100Hz
 station-id name Fax 1
 station-id number 190
voice-port 0/0/1
 compand-type a-law
 cptone NL
 description Fax (191)
 bearer-cap 3100Hz
 station-id name Fax 2
 station-id number 191
voice-port 0/1/0
 cptone NL
 connection plar opx 901
 impedance complex2
 description Vsat Line 1 001
 station-id name Vsat Line 1 001
voice-port 0/1/1
 cptone NL
 connection plar opx 902
 impedance complex2
 description Vsat Line 2 002
 station-id name Vsat Line 2 002
voice-port 0/1/2
 compand-type a-law
 cptone NL
 connection plar opx 903
 impedance complex2
 description FBB Fleet Broadband 003 wwwwwwwwwwww
 station-id name FBB 500 Voice 003
voice-port 0/1/3
 cptone NL
 connection plar opx 190
 impedance complex2
 description FBB Fleet Fax 004
 station-id name FBB Fleet Fax 004
voice-port 0/2/0
 cptone NL
 connection plar opx 905
 impedance complex2
 description GSM Voice 005 vvvvvvvvvvv
 station-id name GSM Voice 005
voice-port 0/2/1
 cptone NL
 connection plar opx 906
 impedance complex2
 description GSM Voice/Fax 006
 station-id name GSM Voice/Fax 006
voice-port 0/2/2
voice-port 0/2/3
voice-port 0/3/0
voice-port 0/3/1
voice-port 0/3/2
voice-port 0/3/3
dial-peer cor custom
 name Internal-only
 name Vsat-Line-001
 name Vsat-Line-002
 name FBB-Voice-003
 name FBB-Fax-004
 name GSM-Voice-005
 name GSM-VoiceFax-006
 name Intercom-Numbers
dial-peer cor list Call-Internal
 member Internal-only
dial-peer cor list Call-Vsat-Line1
 member Vsat-Line-001
dial-peer cor list Call-Vsat-Line2
 member Vsat-Line-002
dial-peer cor list Call-FBB-Voice
 member FBB-Voice-003
dial-peer cor list Call-FBB-Fax
 member FBB-Fax-004
dial-peer cor list Call-GSM-Voice
 member GSM-Voice-005
dial-peer cor list Call-GSM-VoiceFax
 member GSM-VoiceFax-006
dial-peer cor list Call-All-Lines
 member FBB-Fax-004
dial-peer cor list Call-Vsat-FBB-GSM
dial-peer cor list Call-O…...
dial-peer cor list Call-Intercom
 member Intercom-Numbers
dial-peer cor list Call-Vsat-GSM
dial-peer voice 102 pots
 corlist outgoing Call-FBB-Voice
 translation-profile outgoing Add_Pound
 preference 7
 answer-address 003
 destination-pattern 003T
 progress_ind alert enable 8
 fax rate disable
 direct-inward-dial
 port 0/1/2
dial-peer voice 103 pots
 corlist outgoing Call-FBB-Fax
 description FBB Fleet Broadband 004
 answer-address 004
 destination-pattern 004T
 fax rate disable
 direct-inward-dial
 port 0/1/3
dial-peer voice 104 pots
 corlist outgoing Call-GSM-Voice
 answer-address 005
 destination-pattern 005T
 fax rate disable
 direct-inward-dial
 port 0/2/0
dial-peer voice 105 pots
 corlist outgoing Call-GSM-VoiceFax
 description GSM Voice 006
 answer-address 006
 destination-pattern 006T
 fax rate disable
 direct-inward-dial
 port 0/2/1
dial-peer voice 106 pots
 description VSAT outgoing 001
 destination-pattern 001T
 port 0/1/0
dial-peer voice 107 pots
 description VSAT outgoing 002
 destination-pattern 002T
 port 0/1/1
sip-ua
 credentials username
 authentication username
 retry invite 2
 retry register 10
 timers connect 100
 registrar ipv4:20….. expires 3600
 sip-server ipv4:20…...
  host-registrar
telephony-service
 load 7911 SCCP11.8-3-3S
 load 7925 CP7925G-1.3.4
 load 7945 SCCP45.8-3-3S
 load 7965 SCCP45.8-3-3S
 load ata ATA030100SCCP040211A.zup
 max-ephones 58
 max-dn 192
 ip source-address 192.168….. port 2000
 max-redirect 10
 timeouts interdigit 5
 time-zone 14
 time-format 24
 date-format dd-mm-yy
 max-conferences 8 gain -6
 call-park system redirect
 moh music-on-hold.au
 web admin system name admin secret
 dn-webedit
 time-webedit
 transfer-system full-consult
 transfer-pattern .T
 directory entry 1
 directory entry 17
ephone-dn  1  dual-line
 number 200
 label 200
 corlist incoming Call-Vsat-GSM
ephone-dn  2  dual-line
 number 100
 label 100
ephone-dn  3  dual-line
 number 110
 label 110
 corlist incoming Call-Owner-Lines
ephone-dn  4  dual-line
 number 210
 label 210
ephone-dn  5  dual-line
 number 320
 label 162
ephone-dn  6  dual-line
 number 420
 label 420
ephone-dn  7  dual-line
 number 430
 label 430
ephone-dn  8  dual-line
 number 251
 label 251
ephone-dn  9  dual-line
 number 456
 label 456
ephone-dn  10  dual-line
 number 455
 label 455
ephone-dn  11  dual-line
 number 310
 label 310
 corlist incoming Call-Internal
ephone-dn  12  dual-line
 number 150
 label 150
ephone-dn  13  dual-line
 number 250
 label 250
ephone-dn  14  dual-line
 number 500
 label 500
ephone-dn  15  dual-line
 number 510
 label 510
ephone-dn  16  dual-line
 number 400
 label 400
ephone-dn  17  dual-line
 number 410
 label 410
ephone-dn  18  dual-line
 number 300
 label 300
ephone-dn  19  dual-line
 number 333
 label 333
 call-forward noan 320 timeout 10
ephone-dn  20  dual-line
 number 666
 corlist incoming Call-All-Lines
 hold-alert 30 originator
ephone-dn  21  dual-line
 number 162
ephone-dn  22  dual-line
 number 451
 label 451
ephone-dn  23  dual-line
 number 452
 label 452
ephone-dn  24  dual-line
 number 453
 label 453
 description Guest Cabin 3
 name Guest Cabin 3
ephone-dn  25  dual-line
 number 454
 label 454
ephone-dn  26  dual-line
 number 220
 label 220
ephone-dn  27  dual-line
 number 271
 label 271
ephone-dn  28  dual-line
 number 230
 label 230
ephone-dn  29  dual-line
 number 273
 label 273
ephone-dn  30  dual-line
 number 274
 label 274
ephone-dn  31  dual-line
 number 275
 label 275
ephone-dn  32  dual-line
 number 276
 label 276
ephone-dn  33  dual-line
 number 440
 label 440
ephone-dn  34  dual-line
 number 450
 label 450
ephone-dn  35  dual-line
 number 130
 label 130
 call-forward noan 161 timeout 20
ephone-dn  36  dual-line
 number 277
 label 277
ephone-dn  37  dual-line
 number 278
 label 278
ephone-dn  38  dual-line
 number 260
 label 260
ephone-dn  39  dual-line
 number 261
 label 261
ephone-dn  40  dual-line
 number 252
 label 252
ephone-dn  41  dual-line
 number 140
 label 140
ephone-dn  42  dual-line
 number 120
 label 120
ephone-dn  43
 number 160
ephone-dn  44
 number 161
 no huntstop
ephone-dn  80
 number 800
 label 800
 paging ip 239.0.1.20 port 2000
 paging group 81,82,83,84
ephone-dn  81
 number 801
 label 801
 paging ip 239.0.1.21 port 2000
ephone-dn  82
 number 802
 label 802
 paging ip 239.0.1.22 port 2000
ephone-dn  83
 number 803
 label 803
 paging ip 239.0.1.23 port 2000
ephone-dn  84
 number 804
 label 804
 paging ip 239.0.1.24 port 2000
ephone-dn  104
 number xxxxxxxxxxx
ephone-dn  105
 number yyyyyyyyyyy
ephone  1
 mac-address 0022.905A.C6F1
 username "" password
 paging-dn 81
 type 7945
 button  1:1
 pin 12345
ephone  43
 description unused ATA port
 mac-address 21D8.B95E.D001
 max-calls-per-button 2
 type ata
ephone-hunt 1 sequential
ephone-hunt 2 sequential
 pilot 902
ephone-hunt 3 sequential
 pilot 903
 list 110, 210, 320
 final 260
 timeout 18, 18, 18
ephone-hunt 4 sequential
 pilot 900
 list 260, 261, 320
 timeout 10, 10, 10
ephone-hunt 5 longest-idle
ephone-hunt 26 sequential
banner exec ^C
kkoeper12
Level 3
Level 3
It looks like port 0/1/0 is being forwarded to hunt group 901. Port 0/1/1 is being sent to hunt group 902.
voice-port 0/1/0
cptone NL
voice-port 0/1/1
cptone NL
I see that hunt group 901 is defined but I can't find where 902 is defined.
final 260
timeout 18
pilot 901
I think if you create a new hunt group, the same config as voice hunt group 21 but with the pilot number of 902 the incoming calls on 0/1/1 will go to the extensions you put in the "list" line of the hunt group config.
voice-port 0/1/0 cptone NL connection plar opx 901 impedance complex2 description Vsat Line 1 001 station-id name Vsat Line 1 001 ! voice-port 0/1/1 cptone NL connection plar opx 902 impedance complex2 description Vsat Line 2 002 station-id name Vsat Line 2 002 - See more at: https://supportforums.cisco.com/discussion/12505626/incoming-pots-line-help-call-mgr-express#sthash.inQzmRxM.dpuf
yzbobyzbob
I  have attached a document containing the configs above which should be easier to read.
Thanks Kkoeper, that worked. Can you see anything in the outgoing dial-peers that is incorrect or something that might be missing or not best practice? particularly dial-peer voice 106 and 107?
should i have DID on those?
Also I think maybe the calls don't close properly and it keeps the line active on the other end after i hang up?
Dial-peers 106 and 107 are sending calls out the analog ports, I'm not sure what you mean by adding a DID. Is there something you want the dial peer to do that it is not doing?
If you want dial peer 106 to send calls that start with 001 out port 0/1/0 then it is OK.
If you want dial peer 107 to send calls that start with 002 out port 0/1/1 then it is OK.
If the far end is not hanging up it is related to equipment at the far end. There's nothing you can do on your end to control the disconnect supervision on the far end.
kkoeper12
Level 3
Level 3
voice-port 0/1/0
cptone NL
voice-port 0/1/1
cptone NL
final 260
timeout 18
pilot 901
