info about css CUCM 8.0.3
gevangelista
Good morning at all.
I've a little question about CUCM Calling-search-space.
I need  th change a CSS name.
If I change the ccs name , all dependecy associate to this css will change the css or not?
for example
if I've one  phone 1 are using the css  (css- check)  in callforward section and I' change the css name to css.new, this new css will be automatically assigned to the  phone 1?
Thanks in advance
Giancarlo
2 Accepted Solutions
Rob Huffman
Hi Giancarlo,
As always, Java is most correct here +5 Java-Man!
I thought this was an interesting question and I couldn't remember
if I'd ever actually tried this out. So I created a new CSS Called test_css
and applied it to a couple of test phones. I then went back to the CSS
config page and changed the name from test_css to test12_css and saved
the changes. Sure enough, as Java nicely noted the new name test12_css
had been applied to the phones that were using test_css before
Cheers!
Rob
"May your heart always be joyful
May your song always be sung" - Bob Dylan
The name of the CSS is just an attribute in the DB, the primary key (which ties it all together) doesn't change.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
Yes
java
Rob Huffman
Hi Giancarlo,
Cheers!
Rob
java
java
