09-04-2018 04:44 AM - edited 03-17-2019 01:25 PM
Solved! Go to Solution.
09-04-2018 05:34 PM - edited 09-05-2018 05:26 AM
No public ca will touch that CSR for sure.
If you local one doesn’t have a problem with it you can always try if should work however why bother with it. Just make yourself some book marks. However those other names would need to be in your SANs field not CN
09-05-2018 12:09 AM
no if requesting a certificate from a public CA, the CN can only contain ONE name, either domain name or FQDN. the other names must be specified in the SAN
depends on the CA if only names within the same domain as the CN are accepted.
09-05-2018 07:44 AM
09-04-2018 05:23 AM
09-04-2018 05:38 AM
09-04-2018 09:55 AM
09-04-2018 03:32 PM
What if I put Hostname, IP Address and FQDN while generating CSR from CUCM.
09-04-2018 09:04 PM
https://support.dnsimple.com/articles/what-is-common-name/
09-05-2018 12:09 AM
09-05-2018 07:44 AM
