06-24-2018 02:59 AM - edited 03-17-2019 01:04 PM
Hi ,
I'm having CUCM
06-24-2018 07:46 AM
Hi ,
Please have a look into the bug even it occurs while doing migration
06-24-2018 11:29 PM
Hi Aman ,
Thanks for reply .
Please note that this screenshot is after added these parameters , I've already added these values with the same result .
06-25-2018 09:11 PM
Hi ,
you can check the status of ntp from CUCM PUB using the command "utils ntp status".
If it does not show Syncronised with stratum less than 5 , then , u need to check the ntp source else suggest opening TAC case for resolution.
regds,
aman
