Interconnection CME with Panasonic KX-TDE 600
Chrysostomos_CY
Level 5
Level 5
Hi to all
We have one CME and one Panasonic KX-TDE 600.we need to integrate these PBX via H323 or via SIP protocol
From my site(CME) i have created one dial peer like the below
i think that we this we are ok from our site right?
Do you know anything about Panasonic site?
its asked me A credentials for the sip but we dont use any credential for the sip trunking, dial peer on CME
FOR THE SIP PART
dial-peer voice 19 voip
destination-pattern 1..
session protocol sipv2
session target ipv4:192.168.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
FOR THE H323 PART
dial-peer voice 21 voip
destination-pattern 1...
dtmf-relay h245-alphanumeric
REGARDS
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
29 Replies 29
Then try H.323 that has no authentication.
Hi.
Thanks for help. I reall appriciate, this week i will be trying it.
I guess the issue is that the panasonic has the wrong user and pass or something is missing.
Anyway, there is no option to make an IOS router as SIP proxy?
BR,
SIP proxy == SIP server. Some vendor use different terms, but they are essentialy the same thing in a simple case like this.
Chrysostomos_CY
Level 5
Level 5
if you find anything pls update the discussion ..
But as i said we cant do anything.. Panasonic for a reason is
Not understand the authentication that we send. If you disable the authentication in cme then the call disconnected again with authorization required coming from
Pamasonic site
This is they key of your problem:
Received: SIP/2.0 404 Not Found
Via: SIP/2.0/UDP 192.168.5.5:5060;branch=z9hG4bKBECC2404
To: sip:805@192.168.28.8;tag=27181
From: "PavlosG" <>0911@bbtb.cyta.com.cy>;tag=C2F16A30-1EEB
Call-ID: BBCAD501-C8E811E1-9A6B9574-9CA30A2A@192.168.5.5
CSeq: 102 INVITE
Allow: INVITE,ACK,CANCEL,BYE,REGISTER
Content-Length: 0
Aslk Panasonic why.
Chrysostomos_CY
Level 5
Level 5
I agree with you..
I am sure that the problem is at panasonic side. Unfortunately they don't have enough support
From their vendor so the problem will remain for ever
SANTIAGO
Do you have any update ??
I'm trying to make a h.323 trunk channel betwenn Panasonic TDE series and 2901.
Did you try to establish h.323 channel between this two devices? Did it work correctly?
Chrysostomos_CY
Level 5
Level 5
I dont believe that panasonic can support h323 trunk
It supports, today i've successfully created h.323 trunk between 2901 CME and TDE-200.
Everything works fine.
Can you help pls with that?
Need settings in panasonic site and also in cisco router
Thanking you in advance
Yea, sure.
On Panasonic I've phone nubmerx 2XX, on CCME - 5XX
Panasonic site (Configuration through PBX UMC)
1) Insert a  V-IPGW16 card in your virtual unit (Item - 1.1)
2) Then go to properties of the system unit (righ click on V-IPGW16)
3) Click on gateway settings
4) Fill all fields in first line (specially - IP address in my config it's - 172.16.0.1 (and remember the number of gateway)). According to my example my gate number - "1"
5) Then click on D2IP and write in first column first nubmer of CISCO CME phone numbers, in my config it's - 5, second column next possible amount of numbers befor "5", my config - "2". And the last column - gate number - according to   item 4) - gate number - "1"
7)Then item 2.6.1 on PBX UMC, choose third tab (numbers of local PBX). And for example in first line, write the first nubmer of phones, that belong to CME, according to my example, it's - 5.
That's all on Pana site
CCME 2901 (A bit easier than Pana)
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729br8
dial-peer voice 1000 voip
destination-pattern 2..
session target ipv4:172.16.0.250
That's all h.323 - established successfully. Hope it will help you, If you have some difficulties, i'll help;)
Chrysostomos_CY
Level 5
Level 5
Don't have words to say thank you mate
If i have any issue i will contact you again
Thank you again
Also i return with a feedback
No problem, mate, i'glad, that i helped you
I have an update regarding this issue
Finally we have established a succesfully SIP interconnection for both ways
IN CME SITE:
dial-peer voice 1003 voip
description **FROM PANASONIC **
session target sip-server
incoming called-number 09..
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
codec g729br8
ip qos dscp cs5 media
ip qos dscp cs4 signaling
dial-peer voice 1005 voip
description **TO PANASONIC**
destination-pattern [678]..
session target ipv4:x.x.x.x
no voice-class sip localhost
no voice-class sip outbound-proxy       -------> Without this commnad here "no voice-class sip outbound-proxy" the
                                                               call went to the SIP trunk with the ISP and not to Panasonic site..
dtmf-relay rtp-nte
codec g729br8
After we solved the above issue the calls went to panasonic site correctly but we were recieving 404 not found..
The problem was that the Panasonic was listening to SIP calls on port 35060 while the CME was trying to reach it with 5060 where was the default port for the sip
After the two changes that i mentioned above ewveryhting working perfect now
