Invalid Upgrades Name does not match any filter pattern
SyedShafi95845
I am in process of upgrading CUCM 10.5.2.17900-13 to 12.5.1.14900-63. Before upgrading I want run or check pre upgrade check cop file (ciscocm.preUpgradeCheck-00028.cop.sha512) but getting message as "Invalid Upgrades" Name does not match any filter pattern.
For reference please find below the screenshot of message.
You need ciscocm.enable-sha512sum-2021-signing-key-v1.0.cop.sgn to be installed first when using sha 512 files.
Before installing the COP, Make sure you read the Release note for the below cop.
Response Signature
As @Nithin Eluvathingal wrote you need to add support for SHA 512 signed files for it to see these files as valid. This should be covered in the recommended reading that you should read through thoroughly before each upgrade.
This would be the list you should read through.
• Release notes
• Upgrade and migration guide
• Check OVA for changes
Response Signature
Jagadish2
Hi Syed,
Even am trying to upgrade from 10.5.2 to 12.5.x, please suggest was the upgrade done successfully or you found any issues during the upgrade.
Also, Please let me know if any other key aspects to be taken care while upgrading, which you found during the upgrade process.
Jagdish
For any Upgrade/Migrations , mandatory  you read the below guides.
  • Install Upgrade Guides
  • Read me Files
  • Release Notes
  • If using PCD, read PCD admin Guides.
Response Signature
