IP communicator dialing in and out problem.
Hi, user has IPC v.8.6.6.0 , the same version is  working on my pc with no problem, but user is has problem:
when he dials any number via IPC nothing happens , when i dial his number its not ringing on his IPC , but rings on his jabber and deskphone.
IPC shows registered in CUCM .
Any idea how can we fix this ?
Thank you
I found what was causing this problem: so user has  2 NICs wireless and wired. He provided wireless mac address for IPC but IPC was registered with wired lan ip . I asked user to disconnect net cable , ipc registered with wireless and everything works now.
HARIS_HUSSAIN
Check for local firewall in User PC, Disable windows firewall or any other antivirus software & test.
*** Please rate helpful post; Mark "Accept as a Solution" if applicable
Haris
windows firewall is disabled.
