Ip phone 7821diconnect outcoming and icoming calls
najoua_tahiri
Ip phone blocks outcoming and incoming calls
10 Replies 10
Describe your setup
What command should I use?
It is not about the command that you need to run. Kindly describe your issue here with Topology and the call flow. For Ex:-
-Are you using CUCM or CME ?
-What exactly is happening while calling ?
-Share the exact call flow of the affected calls.
-Is this a new set up and was working earlier ?
Abhay
Abhay Singh Reyal
The Only Way To Do Great Work Is To Love What You Do. If You Haven’t Found It Yet, Keep Looking. Don’t Settle
Ok, I'm using CUCM System version: 10.5
If it's an incoming call, it's immediatly interrupted and in case of outcoming call, it gives a busy line. And sometimes, it gives a noisy line and it cuts
Thank u in advance
Protocols being used ? PRI/POTS etc ? SIP/H.323.MGCP ?
IP Protocols : SIP,MGCP,H.323
Analog Telephony Protocols : POTS,FXO
Digital Telephony Protocols : BRI
So you are using all the protocols for your calls ? Which is the problematic call flow ?
The problem is that (in and out )calls ara disconnected after a while or we hear some noise and after that it's immediatly chopped off..I don't know if it's a provider problem or not, cuz the local calls are working just fine.
I understand but we need to know what your call flow/protocols are in order to suggest any changes/logs etc for troubleshooting. Is there a GW ? Can you send a "show run" from the CLI of the GW alongwith the IP addresses of your CUCM ?
You find the result of the 'show run' in the attached txt file
