05-28-2014 08:43 AM - edited 03-16-2019 10:55 PM
Hi team, I have this 8831 ip phone but I still cannot register it in cme, I've been trying through fast-track method but no positive results.
does anybody has registered a 8831 into a callmanager express?
05-28-2014 09:35 AM
What does your config looks like?
05-28-2014 10:06 AM
Hi, here is the config related to the ip phone 8831
voice register pool-type 8831
description Cisco SIP Phone 8831.
reference-pooltype 6921
voice register global
mode cme
source-address 90.0.1.1 port 5060
max-dn 40
max-pool 50
load 8831 sip8831.9-3-3-5.loads
authenticate realm cisco.com
create profile sync 0006516043521269
voice register dn 6
number 116
allow watch
name Sala Juntas
shared-line
voice register pool 6
lpcor type local
lpcor incoming users.fac
busy-trigger-per-button 1
id mac AC44.F210.A15E
type 8831
number 1 dn 6
cor incoming N6 default
dtmf-relay sip-kpml
codec g711ulaw
tftp-server flash:sip8831.9-3-3-5.loads
tftp-server flash:kern8831.9-3-3-5.sebn
tftp-server flash:rootfs8831.9-3-3-5.sebn
tftp-server flash:sboot8831.9-3-3-5.sebn
05-29-2014 10:22 AM
I do not see registrar command have you configured it.
voice service voip sip registrar server
after configuration did you re-create the profile.
no create profile
create profile
Br,
Nadeem
05-29-2014 11:28 AM
Hi Nadeem,
thanks a lot for your post
Yes I have it configured, in addition, I have other kind of sip phones (3905) and they are correctly registered.
regards
05-29-2014 01:28 PM
Can you please do:
no create profile
create profile
Then, reset the ip phone and capture the following debugs:
debug tftp events
debug ccsip messages
~jorge
05-30-2014 09:31 AM
Hi Jorge.
Here is tue output of the debug. One funny thing I noticed is that in the outpue says voicevlan:4095, but the actual voicevlan is 91
VGW_Hera#sh deb
May 30 16:07:56.885: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REFER sip:90.0.1.1 SIP/2.0
Via: SIP/2.0/UDP 90.0.0.14:5060;branch=z9hG4bK385cdd7b
From: <sip:ac44f210a15e@90.0.0.14>;tag=ac44f210a15e00025ffe63cd-278ffbbb
To: <sip:90.0.1.1>
Call-ID: ac44f210-a15e0002-328d6355-65fdc2a4@90.0.0.14
Date: Sat, 01 Jan 2000 00:00:48 GMT
CSeq: 1000 REFER
User-Agent: Cisco-CP8831G/9.3.2
Expires: 10
Max-Forwards: 70
Contact: <sip:ac44f210a15e@90.0.0.14:5060>
Require: norefersub
Referred-By: <sip:ac44f210a15e@90.0.0.14>
Refer-To: cid:79d7c0c7@90.0.0.14
Content-Id: <79d7c0c7@90.0.0.14>
Allow: ACK,BYE,CANCEL,INVITE,NOTIFY,OPTIONS,REFER,REGISTER,UPDATE,SUBSCRIBE
Content-Length: 1292
Content-Type: application/x-cisco-alarm+xml
Content-Disposition: session;handling=required
<?xml version="1.0" encoding="UTF-8"?>
<x-cisco-alarm>
<Alarm Name="LastOutOfServiceInformation">
<ParameterList>
<String name="DeviceName">SEPAC44F210A15E</String>
<String name="DeviceIPv4Address">90.0.0.11/24</String>
<String name="IPv4DefaultGateway">90.0.0.1</String>
<String name="DeviceIPv6Address"></String>
<String name="IPv6DefaultGateway"></String>
<String name="ModelNumber">CP-8831</String>
<String name="NeighborIPv4Address">0.0.0.0</String>
<String name="NeighborIPv6Address"></String>
<String name="NeighborDeviceID"></String>
<String name="NeighborPortID"></String>
<Enum name="DHCPv4Status">3</Enum>
<Enum name="DHCPv6Status">0</Enum>
<Enum name="TFTPCfgStatus">1</Enum>
<Enum name="DNSStatusUnifiedCM1">4</Enum>
<Enum name="DNSStatusUnifiedCM2">0</Enum>
<Enum name="DNSStatusUnifiedCM3">0</Enum>
<String name="VoiceVLAN">4095</String>
<String name="UnifiedCMIPAddress">90.0.1.1</String>
<String name="LocalPort">-1</String>
<String name="TimeStamp">946685514159946684853780</String>
<Enum name="ReasonForOutOfService">14</Enum>
<String name="LastProtocolEventSent">Sent:REGISTER sip:90.0.1.1 SIP/2.0 Cseq:101 REGISTER CallId:ac44f210-a15e0002-19fa9dd9-4ecb8f3c@90.0.0.14</String>
<String name="LastProtocolEventReceived"></String>
</ParameterList>
</Alarm>
</x-cisco-alarm>
Sent:
SIP/2.0 400 Bad Request
To: <sip:90.0.1.1>;tag=8E53310-1DB3
Date: Fri, 30 May 2014 16:07:56 GMT
Server: Cisco-SIPGateway/IOS-15.4.2.T
CSeq: 1000 REFER
Content-Length: 0
Contact: <sip:90.0.0.1:5060>
May 30 16:07:56.897: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 90.0.0.14:5060;branch=z9hG4bK09b4d6f3
From: <sip:116@90.0.1.1>;tag=ac44f210a15e00032229f563-4ad22cee
To: <sip:116@90.0.1.1>
Call-ID: ac44f210-a15e0002-10f004f0-6f621f67@90.0.0.14
Max-Forwards: 70
CSeq: 101 REGISTER
Contact: <sip:8080-1232@90.0.0.14:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-ac44f210a15e>";+u.sip!devicename.ccm.cisco.com="SEPAC44F210A15E";+u.sip!model.ccm.cisco.com="659"
Supported: replaces,join,sdp-anat,norefersub,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-5.2.0,X-cisco-xsi-8.5.1
Content-Length: 0
Reason: SIP;cause=200;text="cisco-alarm:14 Name=SEPAC44F210A15E Load=sip8831.9-3-3-5.loads Last=cm-closed-tcp"
Expires: 3600
May 30 16:07:56.901: //156/65DFCECA80AC/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:116@90.0.1.1>;tag=8E5331C-1165
CSeq: 101 REGISTER
Supported: X-cisco-cme-sis-1.0.0
Supported: X-cisco-srtp-fallback
Contact: <sip:116@90.0.0.14:5060>;expires=600;x-cisco-newreg
Expires: 600
Content-Length: 0
May 30 16:07:57.425: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <sip:90.0.1.1>
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
<x-cisco-alarm>
<ParameterList>
</ParameterList>
</Alarm>
</x-cisco-alarm>
May 30 16:07:57.429: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:90.0.1.1>;tag=8E5352C-84E
Date: Fri, 30 May 2014 16:07:57 GMT
CSeq: 1000 REFER
Content-Length: 0
May 30 16:07:57.437: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 101 REGISTER
Content-Length: 0
Expires: 3600
May 30 16:07:57.437: //156/65DFCECA80AC/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 101 REGISTER
Expires: 600
Content-Length: 0
May 30 16:07:58.477: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 101 REGISTER
Content-Length: 0
Expires: 3600
May 30 16:07:58.477: //156/65DFCECA80AC/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 30 May 2014 16:07:58 GMT
CSeq: 101 REGISTER
Expires: 600
Content-Length: 0
May 30 16:08:00.497: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 101 REGISTER
Content-Length: 0
Expires: 3600
May 30 16:08:00.497: //156/65DFCECA80AC/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 30 May 2014 16:08:00 GMT
CSeq: 101 REGISTER
Expires: 600
Content-Length: 0
May 30 16:08:04.525: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 101 REGISTER
Content-Length: 0
Expires: 3600
May 30 16:08:04.525: //156/65DFCECA80AC/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 30 May 2014 16:08:04 GMT
CSeq: 101 REGISTER
Expires: 600
Content-Length: 0
May 30 16:08:08.565: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 101 REGISTER
Content-Length: 0
Expires: 3600
May 30 16:08:08.565: //156/65DFCECA80AC/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 30 May 2014 16:08:08 GMT
CSeq: 101 REGISTER
Expires: 600
Content-Length: 0
May 30 16:08:12.605: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 101 REGISTER
Content-Length: 0
Expires: 3600
May 30 16:08:12.605: //156/65DFCECA80AC/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 30 May 2014 16:08:12 GMT
CSeq: 101 REGISTER
Expires: 600
Content-Length: 0
May 30 16:08:16.637: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 101 REGISTER
Content-Length: 0
Expires: 3600
May 30 16:08:16.637: //156/65DFCECA80AC/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 30 May 2014 16:08:16 GMT
CSeq: 101 REGISTER
Expires: 600
Content-Length: 0
May 30 16:08:20.665: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 101 REGISTER
Content-Length: 0
Expires: 3600
May 30 16:08:20.669: //156/65DFCECA80AC/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 30 May 2014 16:08:20 GMT
CSeq: 101 REGISTER
Expires: 600
Content-Length: 0
May 30 16:08:24.697: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 101 REGISTER
Content-Length: 0
Expires: 3600
May 30 16:08:24.697: //156/65DFCECA80AC/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 30 May 2014 16:08:24 GMT
CSeq: 101 REGISTER
Expires: 600
Content-Length: 0
May 30 16:08:28.725: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 101 REGISTER
Content-Length: 0
Expires: 3600
May 30 16:08:28.725: //156/65DFCECA80AC/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 30 May 2014 16:08:28 GMT
CSeq: 101 REGISTER
Expires: 600
Content-Length: 0
May 30 16:08:31.441: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 90.0.0.14:5060;branch=z9hG4bK25ebfe74
From: <sip:ac44f210a15e@90.0.0.14>;tag=ac44f210a15e00044bdf1823-7d3846f7
To: <sip:90.0.1.1>
Call-ID: ac44f210-a15e0003-64eab6db-6b2e5453@90.0.0.14
Date: Sat, 01 Jan 2000 00:01:23 GMT
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
Refer-To: cid:69a9e24d@90.0.0.14
Content-Id: <69a9e24d@90.0.0.14>
<x-cisco-alarm>
<ParameterList>
</ParameterList>
</Alarm>
</x-cisco-alarm>
May 30 16:08:31.445: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:90.0.1.1>;tag=8E5BA10-1D18
Date: Fri, 30 May 2014 16:08:31 GMT
CSeq: 1000 REFER
Content-Length: 0
May 30 16:08:31.449: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 90.0.0.14:5060;branch=z9hG4bK269e92ce
From: <sip:116@90.0.1.1>;tag=ac44f210a15e00050bd22f26-3fbfb033
Call-ID: ac44f210-a15e0003-405a4b9d-50f6ade5@90.0.0.14
Max-Forwards: 70
CSeq: 102 REGISTER
Content-Length: 0
Expires: 3600
May 30 16:08:31.453: //158/7A78A36D80B0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:116@90.0.1.1>;tag=8E5BA18-D72
CSeq: 102 REGISTER
Expires: 600
Content-Length: 0
May 30 16:08:31.965: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <sip:90.0.1.1>
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
<x-cisco-alarm>
<ParameterList>
</ParameterList>
</Alarm>
</x-cisco-alarm>
May 30 16:08:31.969: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:90.0.1.1>;tag=8E5BC1C-2605
CSeq: 1000 REFER
Content-Length: 0
May 30 16:08:31.973: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 102 REGISTER
Content-Length: 0
Expires: 3600
May 30 16:08:31.973: //158/7A78A36D80B0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 102 REGISTER
Expires: 600
Content-Length: 0
May 30 16:08:32.985: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
.^@-^^@-^.1 SIP/2.0
To: <sip:90.0.1.1>
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
<x-cisco-alarm>
<ParameterList>
</ParameterList>
</Alarm>
</x-cisco-alarm>
May 30 16:08:32.989: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 102 REGISTER
Content-Length: 0
Expires: 3600
May 30 16:08:32.989: //158/7A78A36D80B0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 30 May 2014 16:08:32 GMT
CSeq: 102 REGISTER
Expires: 600
Content-Length: 0
May 30 16:08:35.017: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
.^@-^^@-^.1 SIP/2.0
To: <sip:90.0.1.1>
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
<x-cisco-alarm>
<ParameterList>
</ParameterList>
</Alarm>
</x-cisco-alarm>
May 30 16:08:35.021: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 102 REGISTER
Content-Length: 0
Expires: 3600
May 30 16:08:35.021: //158/7A78A36D80B0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 30 May 2014 16:08:35 GMT
CSeq: 102 REGISTER
Expires: 600
Content-Length: 0
May 30 16:08:39.053: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
.^@-^^@-^.1 SIP/2.0
To: <sip:90.0.1.1>
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
<x-cisco-alarm>
<ParameterList>
</ParameterList>
</Alarm>
</x-cisco-alarm>
May 30 16:08:39.057: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 102 REGISTER
Content-Length: 0
Expires: 3600
May 30 16:08:39.061: //158/7A78A36D80B0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 30 May 2014 16:08:39 GMT
CSeq: 102 REGISTER
Expires: 600
Content-Length: 0
May 30 16:08:43.089: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
.^@-^^@-^.1 SIP/2.0
To: <sip:90.0.1.1>
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
<x-cisco-alarm>
<ParameterList>
</ParameterList>
</Alarm>
</x-cisco-alarm>
May 30 16:08:43.093: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 102 REGISTER
Content-Length: 0
Expires: 3600
May 30 16:08:43.097: //158/7A78A36D80B0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 30 May 2014 16:08:43 GMT
CSeq: 102 REGISTER
Expires: 600
Content-Length: 0
May 30 16:08:47.125: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
.^@-^^@-^.1 SIP/2.0
To: <sip:90.0.1.1>
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
<x-cisco-alarm>
<ParameterList>
</ParameterList>
</Alarm>
</x-cisco-alarm>
May 30 16:08:47.129: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 102 REGISTER
Content-Length: 0
Expires: 3600
May 30 16:08:47.129: //158/7A78A36D80B0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 30 May 2014 16:08:47 GMT
CSeq: 102 REGISTER
Expires: 600
Content-Length: 0
May 30 16:08:51.165: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
.^@-^^@-^.1 SIP/2.0
To: <sip:90.0.1.1>
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
<x-cisco-alarm>
<ParameterList>
</ParameterList>
</Alarm>
</x-cisco-alarm>
May 30 16:08:51.169: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 102 REGISTER
Content-Length: 0
Expires: 3600
May 30 16:08:51.169: //158/7A78A36D80B0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 30 May 2014 16:08:51 GMT
CSeq: 102 REGISTER
Expires: 600
Content-Length: 0
May 30 16:08:55.205: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
.^@-^^@-^.1 SIP/2.0
To: <sip:90.0.1.1>
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
<x-cisco-alarm>
<ParameterList>
</ParameterList>
</Alarm>
</x-cisco-alarm>
May 30 16:08:55.209: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 102 REGISTER
Content-Length: 0
Expires: 3600
May 30 16:08:55.209: //158/7A78A36D80B0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 30 May 2014 16:08:55 GMT
CSeq: 102 REGISTER
Expires: 600
Content-Length: 0
un
May 30 16:08:59.245: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
.^@-^^@-^.1 SIP/2.0
To: <sip:90.0.1.1>
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
<x-cisco-alarm>
<ParameterList>
</ParameterList>
</Alarm>
</x-cisco-alarm>
May 30 16:08:59.441: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 102 REGISTER
Content-Length: 0
Expires: 3600
May 30 16:08:59.445: //158/7A78A36D80B0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 30 May 2014 16:08:59 GMT
CSeq: 102 REGISTER
Expires: 600
Content-Length: 0
un all
% Invalid input detected at '^' marker.
VGW_Hera#
May 30 16:09:03.273: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
.^@-^^@-^.1 SIP/2.0
To: <sip:90.0.1.1>
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
<x-cisco-alarm>
<ParameterList>
</ParameterList>
</Alarm>
</x-cisco-alarm>
May 30 16:09:03.385: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 102 REGISTER
Content-Length: 0
Expires: 3600
May 30 16:09:03.385: //158/7A78A36D80B0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 30 May 2014 16:09:03 GMT
CSeq: 102 REGISTER
Expires: 600
Content-Length: 0
un all
All possible debugging has been turned off
VGW_Hera#
May 30 16:22:56.033: VOICE REGISTER POOL-6 has unregistered. Name:SEPAC44F210A15E IP:90.0.0.14 DeviceType:Phone
05-30-2014 10:42 AM
I can see phone is sending is Registration message to CME and subsequently CME is sending 200OK of REGISTER message, however since we have authentication enable ie Authenticate realm cisco.com , it should challenge and response as per rfc 2617 is authenticated.
Received:
Max-Forwards: 70
CSeq: 102 REGISTER
Content-Length: 0
Expires: 3600
Sent:
SIP/2.0 200 OK
CSeq: 102 REGISTER
Expires: 600
Content-Length: 0
Can you please try removing the authentication from voice register global
mode cme
max-dn 40
max-pool 50
authenticate realm cisco.com ====> remove this and do re-create profile.
Br,
Nadeem
05-30-2014 10:55 AM
Hi Nadeem.
I'm not sure how but suddenly the phone got registered, I didn't even removed the command you mentioned.
Now the voice vlan in the phone menu looks fine.
The configuration I sent in early post remains the same
thanks all of you
05-30-2014 11:24 AM
that's great news, but as i said the logs indicates endpoint is sending REGISTER message to CME and CME is responding to REGISTER message with 200OK which is w/o doing authentication and trying to get register.
but good to know issue solved.
06-05-2014 02:34 AM
seems like you got it to work, great but how about licensing? there does not appear to be a CME license available for a 8831 - SW-CCME-UL-8831
06-05-2014 07:40 AM
to answer my own question -
The 8831 phones will and is supported on IoS versions 15.4(1) T and later. Although the datasheets refers to an earlier release. The phone will be supported.
You can use the new CME licensing SKU’s which are based on UCL licensing.
SW-CCME-UL-ENH= for 8831 phones
