ip phone 8831 in cme
fernandogarciat
Hi team, I have this 8831 ip phone but I still cannot register it in cme, I've been trying through fast-track method but no positive results.
does anybody has registered a 8831 into a callmanager express?
11 Replies 11
Jaime Valencia
What does your config looks like?
java
if this helps, please rate
Hi, here is the config related to the ip phone 8831
voice register pool-type  8831
 description Cisco SIP Phone 8831.
 reference-pooltype 6921
voice register global
 mode  cme
 source-address 90.0.1.1 port 5060
 max-dn 40
 max-pool 50
 load 8831 sip8831.9-3-3-5.loads
 authenticate realm cisco.com
 create profile sync 0006516043521269
voice register dn  6
 number 116
 allow watch
 name Sala Juntas
 shared-line
voice register pool  6
 lpcor type local
 lpcor incoming users.fac
 busy-trigger-per-button 1
 id mac AC44.F210.A15E
 type 8831
 number 1 dn 6
 cor incoming N6 default
 dtmf-relay sip-kpml
 codec g711ulaw
tftp-server flash:sip8831.9-3-3-5.loads
tftp-server flash:kern8831.9-3-3-5.sebn
tftp-server flash:rootfs8831.9-3-3-5.sebn
tftp-server flash:sboot8831.9-3-3-5.sebn
I do not see registrar command have you configured it.
voice service voip
sip
  registrar server
after configuration did you re-create the profile.
no create profile
create profile
Br,
Nadeem
Br, Nadeem Please rate all useful post.
Hi Nadeem,
thanks a lot for your post
Yes I have it configured, in addition, I have other kind of sip phones (3905) and they are correctly registered.
regards
Can you please do:
 no create profile
 create profile
Then, reset the ip phone and capture the following debugs:
 debug tftp events
 debug ccsip messages
~jorge
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
Hi Jorge.
Here is tue output of the debug. One funny thing I noticed is that in the outpue says voicevlan:4095, but the actual voicevlan is 91
VGW_Hera#sh deb
May 30 16:07:56.885: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REFER sip:90.0.1.1 SIP/2.0
Via: SIP/2.0/UDP 90.0.0.14:5060;branch=z9hG4bK385cdd7b
From: <sip:ac44f210a15e@90.0.0.14>;tag=ac44f210a15e00025ffe63cd-278ffbbb
To: <sip:90.0.1.1>
Call-ID: ac44f210-a15e0002-328d6355-65fdc2a4@90.0.0.14
Date: Sat, 01 Jan 2000 00:00:48 GMT
CSeq: 1000 REFER
User-Agent: Cisco-CP8831G/9.3.2
Expires: 10
Max-Forwards: 70
Contact: <sip:ac44f210a15e@90.0.0.14:5060>
Require: norefersub
Referred-By: <sip:ac44f210a15e@90.0.0.14>
Refer-To: cid:79d7c0c7@90.0.0.14
Content-Id: <79d7c0c7@90.0.0.14>
Allow: ACK,BYE,CANCEL,INVITE,NOTIFY,OPTIONS,REFER,REGISTER,UPDATE,SUBSCRIBE
Content-Length: 1292
Content-Type: application/x-cisco-alarm+xml
Content-Disposition: session;handling=required
<?xml version="1.0" encoding="UTF-8"?>
<x-cisco-alarm>
<Alarm Name="LastOutOfServiceInformation">
<ParameterList>
<String name="DeviceName">SEPAC44F210A15E</String>
<String name="DeviceIPv4Address">90.0.0.11/24</String>
<String name="IPv4DefaultGateway">90.0.0.1</String>
<String name="DeviceIPv6Address"></String>
<String name="IPv6DefaultGateway"></String>
<String name="ModelNumber">CP-8831</String>
<String name="NeighborIPv4Address">0.0.0.0</String>
<String name="NeighborIPv6Address"></String>
<String name="NeighborDeviceID"></String>
<String name="NeighborPortID"></String>
<Enum name="DHCPv4Status">3</Enum>
<Enum name="DHCPv6Status">0</Enum>
<Enum name="TFTPCfgStatus">1</Enum>
<Enum name="DNSStatusUnifiedCM1">4</Enum>
<Enum name="DNSStatusUnifiedCM2">0</Enum>
<Enum name="DNSStatusUnifiedCM3">0</Enum>
<String name="VoiceVLAN">4095</String>
<String name="UnifiedCMIPAddress">90.0.1.1</String>
<String name="LocalPort">-1</String>
<String name="TimeStamp">946685514159946684853780</String>
<Enum name="ReasonForOutOfService">14</Enum>
<String name="LastProtocolEventSent">Sent:REGISTER sip:90.0.1.1 SIP/2.0  Cseq:101 REGISTER CallId:ac44f210-a15e0002-19fa9dd9-4ecb8f3c@90.0.0.14</String>
<String name="LastProtocolEventReceived"></String>
</ParameterList>
</Alarm>
</x-cisco-alarm>
Sent:
SIP/2.0 400 Bad Request
To: <sip:90.0.1.1>;tag=8E53310-1DB3
Date: Fri, 30 May 2014 16:07:56 GMT
Server: Cisco-SIPGateway/IOS-15.4.2.T
CSeq: 1000 REFER
Content-Length: 0
Contact: <sip:90.0.0.1:5060>
May 30 16:07:56.897: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 90.0.0.14:5060;branch=z9hG4bK09b4d6f3
From: <sip:116@90.0.1.1>;tag=ac44f210a15e00032229f563-4ad22cee
To: <sip:116@90.0.1.1>
Call-ID: ac44f210-a15e0002-10f004f0-6f621f67@90.0.0.14
Max-Forwards: 70
CSeq: 101 REGISTER
Contact: <sip:8080-1232@90.0.0.14:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-ac44f210a15e>";+u.sip!devicename.ccm.cisco.com="SEPAC44F210A15E";+u.sip!model.ccm.cisco.com="659"
Supported: replaces,join,sdp-anat,norefersub,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-5.2.0,X-cisco-xsi-8.5.1
Content-Length: 0
Reason: SIP;cause=200;text="cisco-alarm:14 Name=SEPAC44F210A15E Load=sip8831.9-3-3-5.loads Last=cm-closed-tcp"
Expires: 3600
May 30 16:07:56.901: //156/65DFCECA80AC/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:116@90.0.1.1>;tag=8E5331C-1165
CSeq: 101 REGISTER
Supported: X-cisco-cme-sis-1.0.0
Supported: X-cisco-srtp-fallback
Contact: <sip:116@90.0.0.14:5060>;expires=600;x-cisco-newreg
Expires:  600
Content-Length: 0
May 30 16:07:57.425: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <sip:90.0.1.1>
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
<x-cisco-alarm>
<ParameterList>
</ParameterList>
</Alarm>
</x-cisco-alarm>
May 30 16:07:57.429: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:90.0.1.1>;tag=8E5352C-84E
Date: Fri, 30 May 2014 16:07:57 GMT
CSeq: 1000 REFER
Content-Length: 0
May 30 16:07:57.437: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 101 REGISTER
Content-Length: 0
Expires: 3600
May 30 16:07:57.437: //156/65DFCECA80AC/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 101 REGISTER
Expires:  600
Content-Length: 0
May 30 16:07:58.477: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 101 REGISTER
Content-Length: 0
Expires: 3600
May 30 16:07:58.477: //156/65DFCECA80AC/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 30 May 2014 16:07:58 GMT
CSeq: 101 REGISTER
Expires:  600
Content-Length: 0
May 30 16:08:00.497: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 101 REGISTER
Content-Length: 0
Expires: 3600
May 30 16:08:00.497: //156/65DFCECA80AC/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 30 May 2014 16:08:00 GMT
CSeq: 101 REGISTER
Expires:  600
Content-Length: 0
May 30 16:08:04.525: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 101 REGISTER
Content-Length: 0
Expires: 3600
May 30 16:08:04.525: //156/65DFCECA80AC/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 30 May 2014 16:08:04 GMT
CSeq: 101 REGISTER
Expires:  600
Content-Length: 0
May 30 16:08:08.565: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 101 REGISTER
Content-Length: 0
Expires: 3600
May 30 16:08:08.565: //156/65DFCECA80AC/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 30 May 2014 16:08:08 GMT
CSeq: 101 REGISTER
Expires:  600
Content-Length: 0
May 30 16:08:12.605: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 101 REGISTER
Content-Length: 0
Expires: 3600
May 30 16:08:12.605: //156/65DFCECA80AC/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 30 May 2014 16:08:12 GMT
CSeq: 101 REGISTER
Expires:  600
Content-Length: 0
May 30 16:08:16.637: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 101 REGISTER
Content-Length: 0
Expires: 3600
May 30 16:08:16.637: //156/65DFCECA80AC/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 30 May 2014 16:08:16 GMT
CSeq: 101 REGISTER
Expires:  600
Content-Length: 0
May 30 16:08:20.665: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 101 REGISTER
Content-Length: 0
Expires: 3600
May 30 16:08:20.669: //156/65DFCECA80AC/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 30 May 2014 16:08:20 GMT
CSeq: 101 REGISTER
Expires:  600
Content-Length: 0
May 30 16:08:24.697: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 101 REGISTER
Content-Length: 0
Expires: 3600
May 30 16:08:24.697: //156/65DFCECA80AC/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 30 May 2014 16:08:24 GMT
CSeq: 101 REGISTER
Expires:  600
Content-Length: 0
May 30 16:08:28.725: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 101 REGISTER
Content-Length: 0
Expires: 3600
May 30 16:08:28.725: //156/65DFCECA80AC/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 30 May 2014 16:08:28 GMT
CSeq: 101 REGISTER
Expires:  600
Content-Length: 0
May 30 16:08:31.441: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 90.0.0.14:5060;branch=z9hG4bK25ebfe74
From: <sip:ac44f210a15e@90.0.0.14>;tag=ac44f210a15e00044bdf1823-7d3846f7
To: <sip:90.0.1.1>
Call-ID: ac44f210-a15e0003-64eab6db-6b2e5453@90.0.0.14
Date: Sat, 01 Jan 2000 00:01:23 GMT
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
Refer-To: cid:69a9e24d@90.0.0.14
Content-Id: <69a9e24d@90.0.0.14>
<x-cisco-alarm>
<ParameterList>
</ParameterList>
</Alarm>
</x-cisco-alarm>
May 30 16:08:31.445: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:90.0.1.1>;tag=8E5BA10-1D18
Date: Fri, 30 May 2014 16:08:31 GMT
CSeq: 1000 REFER
Content-Length: 0
May 30 16:08:31.449: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 90.0.0.14:5060;branch=z9hG4bK269e92ce
From: <sip:116@90.0.1.1>;tag=ac44f210a15e00050bd22f26-3fbfb033
Call-ID: ac44f210-a15e0003-405a4b9d-50f6ade5@90.0.0.14
Max-Forwards: 70
CSeq: 102 REGISTER
Content-Length: 0
Expires: 3600
May 30 16:08:31.453: //158/7A78A36D80B0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:116@90.0.1.1>;tag=8E5BA18-D72
CSeq: 102 REGISTER
Expires:  600
Content-Length: 0
May 30 16:08:31.965: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <sip:90.0.1.1>
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
<x-cisco-alarm>
<ParameterList>
</ParameterList>
</Alarm>
</x-cisco-alarm>
May 30 16:08:31.969: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:90.0.1.1>;tag=8E5BC1C-2605
CSeq: 1000 REFER
Content-Length: 0
May 30 16:08:31.973: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 102 REGISTER
Content-Length: 0
Expires: 3600
May 30 16:08:31.973: //158/7A78A36D80B0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 102 REGISTER
Expires:  600
Content-Length: 0
May 30 16:08:32.985: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
 .^@-^^@-^.1 SIP/2.0
To: <sip:90.0.1.1>
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
<x-cisco-alarm>
<ParameterList>
</ParameterList>
</Alarm>
</x-cisco-alarm>
May 30 16:08:32.989: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 102 REGISTER
Content-Length: 0
Expires: 3600
May 30 16:08:32.989: //158/7A78A36D80B0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 30 May 2014 16:08:32 GMT
CSeq: 102 REGISTER
Expires:  600
Content-Length: 0
May 30 16:08:35.017: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
 .^@-^^@-^.1 SIP/2.0
To: <sip:90.0.1.1>
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
<x-cisco-alarm>
<ParameterList>
</ParameterList>
</Alarm>
</x-cisco-alarm>
May 30 16:08:35.021: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 102 REGISTER
Content-Length: 0
Expires: 3600
May 30 16:08:35.021: //158/7A78A36D80B0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 30 May 2014 16:08:35 GMT
CSeq: 102 REGISTER
Expires:  600
Content-Length: 0
May 30 16:08:39.053: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
 .^@-^^@-^.1 SIP/2.0
To: <sip:90.0.1.1>
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
<x-cisco-alarm>
<ParameterList>
</ParameterList>
</Alarm>
</x-cisco-alarm>
May 30 16:08:39.057: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 102 REGISTER
Content-Length: 0
Expires: 3600
May 30 16:08:39.061: //158/7A78A36D80B0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 30 May 2014 16:08:39 GMT
CSeq: 102 REGISTER
Expires:  600
Content-Length: 0
May 30 16:08:43.089: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
 .^@-^^@-^.1 SIP/2.0
To: <sip:90.0.1.1>
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
<x-cisco-alarm>
<ParameterList>
</ParameterList>
</Alarm>
</x-cisco-alarm>
May 30 16:08:43.093: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 102 REGISTER
Content-Length: 0
Expires: 3600
May 30 16:08:43.097: //158/7A78A36D80B0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 30 May 2014 16:08:43 GMT
CSeq: 102 REGISTER
Expires:  600
Content-Length: 0
May 30 16:08:47.125: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
 .^@-^^@-^.1 SIP/2.0
To: <sip:90.0.1.1>
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
<x-cisco-alarm>
<ParameterList>
</ParameterList>
</Alarm>
</x-cisco-alarm>
May 30 16:08:47.129: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 102 REGISTER
Content-Length: 0
Expires: 3600
May 30 16:08:47.129: //158/7A78A36D80B0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 30 May 2014 16:08:47 GMT
CSeq: 102 REGISTER
Expires:  600
Content-Length: 0
May 30 16:08:51.165: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
 .^@-^^@-^.1 SIP/2.0
To: <sip:90.0.1.1>
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
<x-cisco-alarm>
<ParameterList>
</ParameterList>
</Alarm>
</x-cisco-alarm>
May 30 16:08:51.169: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 102 REGISTER
Content-Length: 0
Expires: 3600
May 30 16:08:51.169: //158/7A78A36D80B0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 30 May 2014 16:08:51 GMT
CSeq: 102 REGISTER
Expires:  600
Content-Length: 0
May 30 16:08:55.205: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
 .^@-^^@-^.1 SIP/2.0
To: <sip:90.0.1.1>
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
<x-cisco-alarm>
<ParameterList>
</ParameterList>
</Alarm>
</x-cisco-alarm>
May 30 16:08:55.209: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 102 REGISTER
Content-Length: 0
Expires: 3600
May 30 16:08:55.209: //158/7A78A36D80B0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 30 May 2014 16:08:55 GMT
CSeq: 102 REGISTER
Expires:  600
Content-Length: 0
un
May 30 16:08:59.245: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
 .^@-^^@-^.1 SIP/2.0
To: <sip:90.0.1.1>
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
<x-cisco-alarm>
<ParameterList>
</ParameterList>
</Alarm>
</x-cisco-alarm>
May 30 16:08:59.441: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 102 REGISTER
Content-Length: 0
Expires: 3600
May 30 16:08:59.445: //158/7A78A36D80B0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 30 May 2014 16:08:59 GMT
CSeq: 102 REGISTER
Expires:  600
Content-Length: 0
un all
% Invalid input detected at '^' marker.
VGW_Hera#
May 30 16:09:03.273: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
 .^@-^^@-^.1 SIP/2.0
To: <sip:90.0.1.1>
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 70
Require: norefersub
<x-cisco-alarm>
<ParameterList>
</ParameterList>
</Alarm>
</x-cisco-alarm>
May 30 16:09:03.385: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 102 REGISTER
Content-Length: 0
Expires: 3600
May 30 16:09:03.385: //158/7A78A36D80B0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 30 May 2014 16:09:03 GMT
CSeq: 102 REGISTER
Expires:  600
Content-Length: 0
un all
All possible debugging has been turned off
VGW_Hera#
May 30 16:22:56.033: VOICE REGISTER POOL-6 has unregistered. Name:SEPAC44F210A15E  IP:90.0.0.14  DeviceType:Phone
Nadeem Ahmed
I can see phone is sending is Registration message to CME and subsequently CME is sending 200OK of REGISTER message, however since we have authentication enable ie Authenticate realm cisco.com , it should challenge and response as per rfc 2617 is authenticated.
Received:
Max-Forwards: 70
CSeq: 102 REGISTER
Content-Length: 0
Expires: 3600
Sent:
SIP/2.0 200 OK
CSeq: 102 REGISTER
Expires:  600
Content-Length: 0
Can you please try removing the authentication from voice register global
 mode  cme
 max-dn 40
 max-pool 50
 authenticate realm cisco.com ====> remove this and do re-create profile.
Br,
Nadeem
Hi Nadeem.
I'm not sure how but suddenly the phone got registered, I didn't even removed the command you mentioned.
Now the voice vlan in the phone menu looks fine.
The configuration I sent in early post remains the same
thanks all of you
that's great news, but as i said  the logs indicates endpoint is sending REGISTER message to CME and CME is responding to REGISTER message with 200OK which is w/o doing authentication and trying to get register.
but good to know issue solved.
justin.devos
seems like you got it to work, great but how about licensing? there does not appear to be a CME license available for a 8831 - SW-CCME-UL-8831
to answer my own question -
The 8831 phones will and is supported on IoS versions 15.4(1) T and later. Although the datasheets refers to an earlier release. The phone will be supported.
You can use the new CME licensing SKU’s which are based on UCL licensing.
SW-CCME-UL-ENH= for 8831 phones
