ip phone 8845 speed dial problem
ozden ozdugun
when I added the 9 speed dial numbar to phone;ı only see the left side the screen and 4 speed dial how can ı add the right side and see 9 sd
Prassha
Hello Ozden
8845 have 10 programmable button which you can utilize for speed dial. You can set up speed dial from Self care portal or directly from CCM page. Make sure you are selecting the sequence number 6-10 to appear the speed dial on right right side and label button is selected.
For more information you can refer Data sheet :
https://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/unified-ip-phone-8800-series/datasheet-c78-734730.html
Let me know if this is helpful to you.
Prassha3
If you find this helpful dont forget to rate.
Prassha3
Rate if you find this helpful
Rate if you find this helpful or Mark Solutions as Accepted
Prassha
Hello Ozden
Prassha3
Prassha3
I added the attach;how ı did this
George Sotiropoulos
Hello Ozden,
If you are using a CUCM server, you will need to enable Enhance Line Mode on the Phone to have available the right side 5 softkeys.
Please be aware that not all features are available when on ELM: https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/8800-series/english/adminguide/P881_BK_C136782F_00_cisco-ip-phone-8800_series/P881_BK_C136782F_00_cisco-ip-phone-8811-8841_chapter_01011.html#reference_B79D0A49A50063E00AFD61EA83CC1D0C
Let me know if CUCM is the case,
George
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
Arnaud Mln
Hello George, very useful !
Thank you
Arnaud
