12-06-2013 09:09 AM - edited 03-16-2019 08:44 PM
Guys,
very quick one I not seen before.
Just upgraded a single phone to SCCP45.9-3-1SR2-1S, before we do a mass upgrade just to check it out.
On the phone http page i see
Version | *SCCP45.9-3-1SR2-1S* |
What does the * indicate
The current default load is
SCCP45.9-3-1SR1-1S, will change once all the phone are upgraded as we have multiple sites
thanks as always.
Paul
Solved! Go to Solution.
12-06-2013 09:13 AM
Paul,
I don't know that it has any special meaning. I noticed the same when I upgraded phones for a customer about a month ago. I upgraded a little over 2000 phones to the same version. I think it is just cosmetic.
-Bill
(b) http://ucguerrilla.com
(t) @ucguerrilla
Please remember to rate helpful responses and identify helpful or correct answers.
12-06-2013 09:13 AM
Paul,
-Bill
(t) @ucguerrilla
12-06-2013 09:19 AM
William,
thanks for the quick response, we just about to upgrade over 4000 over the coming week so if you done 2000 and they are just fine that should be good for me
thank you
Paul
12-06-2013 09:43 AM
Hey Paul/Bill,
My guess would be that it references the Security enhancements with
this firmware version;
Firmware Release 9.3(1)SR2 contains the following security enhancements:
This feature had no user impact.
Cheers!
Rob
"When it comes to luck you make your own "
- Springsteen
12-08-2013 12:56 PM
Rob,
As always thinking outside the box, thank you once again sir.
Hope you are staying safe during the weather in your neck of the woods
Kind regards
Paul
