IP phone not registered to CME
samhopealpha
Hi Everybody
Current environment:
- Router 2851 (c2800nm-adventerprisek9-mz.151-4.M5.bin)
- Switch
- IP Phone 7942 (SCCP42.9-3-1SR1)
- CME8.6
Router ----- Switch ----- IP_Phone
IP phone is able to download and install firmware from CME (SCCP42.9-3-1SR1)
if enabled the debug tftp events
it shows the following messages
Nov  9 16:31:32.857: TFTP: Looking for CTLSEP00269944D1AF.tlv
Nov  9 16:31:32.977: TFTP: Looking for ITLSEP00269944D1AF.tlv
Nov  9 16:31:33.093: TFTP: Looking for ITLFile.tlv
Nov  9 16:31:33.297: TFTP: Looking for SEP00269944D1AF.cnf.xml
Nov  9 16:31:33.297: TFTP: Opened flash:/its/vrf1/SEP00269944D1AF.cnf.xml, fd 10, size 1451 for process 12
Nov  9 16:31:33.305: TFTP: Finished flash:/its/vrf1/SEP00269944D1AF.cnf.xml, time 00:00:00 for process 12
CME config and Phone's cnf.xml have been attached
Anybody could help?
Thanks in advance
Sam
6 Replies 6
Michael Durham
Level 4
Level 4
Sam, It looks like you have gotten a little further than I have.  I am also using a 2851 router. But I cannot figure how to load CME 8.6 as its too big when I copy it to flash:  Are you just coping the above files or did you put hte entire 8.6 file set onthe router.  And if the entire set, how? where?
I am guessing that you too are just getting started learning VoIP.  If you like, I would like to connect with you so we can colaberate and learn from each other.  I am using CBT Nuggets for trainging videos.
Michael
m-ketchum
Go into telephony-service and run the command create cnf...this will update your cnf files.
samhopealpha
Hi michael
I just copied the IOS directly from tftp to flash
Hi m-ketchum
I did the create cnf-file after I update the telephony service and the ephone stuff, but still the same result...
Sent from Cisco Technical Support Android App
Do the following Troubleshooting
1. Erase Cisco 7942 configuration from the phone.
2. Remove the following commands and after that create cnf-file under TS
cnf-file location flash:
cnf-file perphone
Kindly Rate it if helpful
thanks
I have done your suggestion, but it still the same result
Here are some more info from the IP Phone7942 > Settings> Status> Status Messages
07:30:23 VPN Not Configured
07:30:22 SEP00269944D1AF.cnf.xml(TFTP)
07:30:21 No Trust List Installed
07:30:20 No DNS Server IP
Seems there is a strange on the SEP00269944D1AF.cnf.xml(TFTP)..
should it be SEP00269944D1AF.cnf.xml << withouit (TFTP)
One more finding... when type "show license", it shows
Index 1 Feature: ios-ips-update
is it because of license ?
Sam
Problem resolved ... seems the latest IOS c2800nm-adventerprisek9-mz.151-4.M5.bin has problem on 2851
After using the previous/older IOS version.
All phones can registered to CME, the configuration has no problem
