Ip phones 6921
cpelosin
Hi all,
I have some 6921 registered on a CUCM7.1 and i need to change the maximum number of call from 2 to 1 .
I see that with the current version of CUCM is not possible , can i change the maximum number of call by installing a new version of firmware ?
Thanks a lot
12 Replies 12
acampbell
What is the value of the Busy Trigger  on the line you are trying to alter.
Also if you reduce the MAX calls to 1 you will no longer be able to use the transfer function
Alex
Regards, Alex. Please rate useful posts.
I have a similar issue. Am not sure how to enable call waiting feature in 6921 IP Phones. I think  cpelosin is also trying to do the same...
PC
Hi PC,
Are the 6921s using SCCP or SIP
Alex
Hi Alex,
6921 using SCCP and the busy trigger value is 1 . Also the busy trigger is not editable .
I know that if i reduce the maximum number of call to 1 ,  i can not use the transfer function but is a request from my customer .
Carluccio
Hi Campbell,
                   They are SCCP,  CUCM 7.1.3, Phone firmware: SCCP69xx.8-5-3-0
I have tried searching for relevant bugs re Max No of Calls & Busy Triggers for both CUCM Ver 7.1 or 6921s.
I can not find any relevance.
I suggest you raise a TAC case.
Alex
I will try to oper a case to the TAC .
I attach the configuration of a 6921 and a 3911 for the maximum number of call .
Were you able to find a solution? thanks
Hello Dmitry,
                   TAC recommended a patch installation. But we didnt do it, since started upgrading to 8.6. In 8.6 it works fine..
Thank You
     PC
In 8.something (Maybe 8.5) CUCM/69xx phones were enhanced to allow you to configure busy trigger. When the 69xx first came out, they were hard coded to only have busy trigger values of 2/1
GTG
Please rate all helpful posts.
Just a note for Gordon: In 8.6 not 8.5 phones were anhaced to allow you to configure bussy trigger
Please rate all useful posts
_____________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
MDGDP, CCNA, CCNA Voice certified
__________________________________________________
Please remember to rate useful posts clicking on the stars below.
Yes in 8.6 you can set the max calls per line and busy trigger to values much higher than before.
However the phone itself will not allow you to interact with those additional line appearances..  For example if you have a 69xx phone and you set the line to 4  calls and 2 calls trigger busy, you will be able to transfer / conference, and receive a 2nd call.
Only problem is you won't have an answer / divert softkey when the 2nd  call comes in, and you won't be able to navigate between calls to select the call you wish to resume.
So thanks Cisco, it seems you have only half way resolved this issue.
Either allow us to assign the same DN to multiple button on a phone, or allow us to navigate within the lines of a single button.  Otherwise we are forced to create phantom partitions and complicated forwarding rules.
Brian S. Turner
CCIE 6145
