01-20-2021 02:14 AM
I have problem with my Cisco IP phone 7861 which cant registrant with SIP server and my WiFi 8821 phones which are connected to correct WiFi network but both have common error reported TFTP.
I am running Cisco ISR 4331 are voice router and SIP server and I am not sure what is missing in my configuration which could cause this kind of error.
Attached is my ISR 4331 configuration and photos of the my DHCP server config for voice vlan and phones reported errors.
Solved! Go to Solution.
01-22-2021 12:43 AM - edited 01-22-2021 12:44 AM
No problem. You should do this to enable the webUI on the phones.
telephony-service service phone webAccess 0 create cnf-files
See this document for the full administration guide for CME. https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/manual/cmeadm.html
01-21-2021 02:39 AM
01-21-2021 01:40 AM
Your TFTP address is 10.13.2.254. and your source-address 10.13.2.254
But I don't see interface configured on router for this IP 10.13.2.254.
01-21-2021 01:51 AM
my interface g0/0/0 has config
interface GigabitEthernet0/0/0
ip address dhcp
ip nat inside
ip nbar protocol-discovery
negotiation auto
vlan-id dot1q 2
And it is configured to get as DHCP but i config static IP in DHCP. Should I config static IP on the interface?
01-21-2021 02:10 AM
If you have a reservation in DHCP so that the router always get the same IP that would work equally good as if you had a static IP set on the interface in IOS configuration.
01-21-2021 02:22 AM
Yes DHCP IP reservation is in place for this device.
01-21-2021 02:48 AM - edited 01-22-2021 12:19 AM
You have configured network-locale GB. can you make sure the files are extracted properly to right folder on router. Because in the picture which you shared shows "error uploading Network Locale"
Refer your CME version Guide.
01-22-2021 12:42 AM
I am sorry to say but quite not sure what you want to say when you talking about network-local GB
01-22-2021 12:46 AM
01-22-2021 12:51 AM
So it might be problem because my WLC is network-location is Qatar so I should change this to GB
01-22-2021 01:10 AM
There are two types of locales available
User Locales - which control the language of the actual display, help menus and other menu's
Network Locales - These control the tones you hear when making and receiving calls
if not required remove network-locale GB. and recreate CNF/Profiles again and try to register.
if you need to use Locale you need to upload the file to router flash downloaded from Cisco portal.
01-22-2021 08:56 AM
Hi there,
I don't suppose you have tried the following after adding the phone?
voice register global
no create-profile
create-profile
01-25-2021 12:51 AM
Hi Guys ,
I have managed to activate ssh and web access to my phones but still registration is not passing even thought I have removed network-locale GB and try to
no create-profile
create-profile
I have extracted debug session form the my IP Phone. You can find it attached. Not sure where I am doing mistake so hope someone while shade some light.
01-25-2021 02:02 AM
Did your firewall gave option to add 150 . if not create the DHCP pool on your CME router with option 150.
ip dhcp pool Voice
network 10.60.51.0 255.255.255.0
default-router 10.60.51.1
option 150 ip 10.60.51.10 10.60.51.11
Use the latest Firmware for phones.
Below link explains how to do it.
http://www.firewall.cx/cisco-technical-knowledgebase/cisco-voice/930-cisco-phone-upgrade.html
01-25-2021 03:58 AM
Unfortunately Kerio has only legacy option DHCP 66 so cant change this option in firewall.
