IP Phones TFTP error and registration issue
danijel_knezic
I have problem with my Cisco IP phone 7861 which cant registrant with SIP server and my WiFi 8821 phones which are connected to correct WiFi network but both have common error reported TFTP.
I am running Cisco ISR 4331 are voice router and SIP server and I am not sure what is missing in my configuration which could cause this kind of error.
Attached is my ISR 4331 configuration and photos of the my DHCP server config for voice vlan and phones reported errors.
2 Accepted Solutions
No problem. You should do this to enable the webUI on the phones.
telephony-service
 service phone webAccess 0
 create cnf-files
See this document for the full administration guide for CME. https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/manual/cmeadm.html
Response Signature
33 Replies 33
Remove Username and password from Voice registrar Pool. its required when use authenticate register.
secondly check the firmware, sometime phones need firmware upgrade.
Response Signature
Apart from what @Nithin Eluvathingal suggested change the option used in DHCP from 66 to 150 as the former is a legacy thing.
Response Signature
And Use DHCP option 150 instead of 66.
Response Signature
Adam Pawlowski
Hopefully as well that DHCP server implementation accepts a value for the option in that format. Some require it to be a packed hex value. But, just looking at the screenshot, it doesn't say "TFTP Timeout" or "TFTP Error" so it may have obtained the file and then has an issue from there. That would be more obvious in the phone's message log, I don't believe the status will say much otherwise.
Hi Guys,
First of all thanks for your inputs.
At moment status is:
I have tried removing the username and password but didn't help.
DHCP option 150 I don't have as option in my DHCP/Firewall (Kerio NG500) so I open the case with GFI company to see how I can sort this out.
I will try to download the latest phone firmware....
Do I need to do something on my WLC in regards the TFTP and Phones 8821?
My ISR 4331 tftp debug events:
*Jan 21 08:59:50.679: TFTP: Looking for SEPC064E4ECE0DE.cnf.xml
*Jan 21 08:59:50.692: TFTP: Opened flash:/its/SEPC064E4ECE0DE.cnf.xml, fd 0, size 4801 for process 595
*Jan 21 08:59:50.715: TFTP: Finished flash:/its/SEPC064E4ECE0DE.cnf.xml, time 00:00:00 for process 595
*Jan 21 08:59:50.734: TFTP: Looking for WLANRootCA.cer
*Jan 21 08:59:52.825: TFTP: Looking for 8821-WLAND4ADBD0C79BE.xml
*Jan 21 08:59:53.539: TFTP: Looking for AppDialRules.xml
*Jan 21 08:59:55.245: TFTP: Looking for 8821-WLANDefault.xml
*Jan 21 08:59:55.857: TFTP: Looking for WLANRootCA.cer
*Jan 21 08:59:57.175: TFTP: Looking for softkeyDefault_kpml.xml
*Jan 21 08:59:57.176: TFTP: Opened flash:/its/softkeyDefault_kpml.xml, fd 0, size 4846 for process 595
*Jan 21 08:59:57.199: TFTP: Finished flash:/its/softkeyDefault_kpml.xml, time 00:00:00 for process 595
*Jan 21 08:59:58.137: TFTP: Looking for 8821-WLANC064E4ECE0DE.xml
*Jan 21 09:00:00.339: TFTP: Looking for 8821-WLANDefault.xml
*Jan 21 09:00:02.491: TFTP: Looking for softkeyDefault_kpml.xml
*Jan 21 09:00:02.498: TFTP: Opened flash:/its/softkeyDefault_kpml.xml, fd 0, size 4846 for process 595
*Jan 21 09:00:02.531: TFTP: Finished flash:/its/softkeyDefault_kpml.xml, time 00:00:00 for process 595
*Jan 21 09:00:03.964: TFTP: Looking for CTLSEP5061BF3DF344.tlv
*Jan 21 09:00:04.850: TFTP: Looking for ITLSEP5061BF3DF344.tlv
*Jan 21 09:00:05.733: TFTP: Looking for ITLFile.tlv
*Jan 21 09:00:06.674: TFTP: Looking for SEP5061BF3DF344.cnf.xml
*Jan 21 09:00:06.688: TFTP: Opened flash:/its/SEP5061BF3DF344.cnf.xml, fd 0, size 4772 for process 595
*Jan 21 09:00:06.701: TFTP: Finished flash:/its/SEP5061BF3DF344.cnf.xml, time 00:00:00 for process 595
*Jan 21 09:00:12.591: TFTP: Looking for SIP_English_United_States/sp-sip.jar
*Jan 21 09:00:13.611: TFTP: Looking for SIP_United_Kingdom/g3-tones.xml
*Jan 21 09:00:15.475: TFTP: Looking for softkeyDefault_kpml.xml
*Jan 21 09:00:15.502: TFTP: Opened flash:/its/softkeyDefault_kpml.xml, fd 0, size 4846 for process 595
*Jan 21 09:00:15.515: TFTP: Finished flash:/its/softkeyDefault_kpml.xml, time 00:00:00 for process 595
And this is debug tftp packets:
MYALRT01#
*Jan 21 09:06:35.646: TFTP: Server request for port 49794, socket_id 0x7F398E85E418 for proce ss 448
*Jan 21 09:06:35.646: TFTP: read request from host 10.13.2.243(49794) via GigabitEthernet0/0/ 0
*Jan 21 09:06:35.646: TFTP: Looking for CTLSEPC064E4ECE0DE.tlv
*Jan 21 09:06:35.646: TFTP: Sending error 1 No such file
*Jan 21 09:06:38.026: TFTP: Server request for port 52054, socket_id 0x7F398E85E418 for proce ss 448
*Jan 21 09:06:38.026: TFTP: read request from host 10.13.2.243(52054) via GigabitEthernet0/0/ 0
*Jan 21 09:06:38.026: TFTP: Looking for ITLSEPC064E4ECE0DE.tlv
*Jan 21 09:06:38.026: TFTP: Sending error 1 No such file
*Jan 21 09:06:40.356: TFTP: Server request for port 49535, socket_id 0x7F398E85E418 for proce ss 448
*Jan 21 09:06:40.356: TFTP: read request from host 10.13.2.243(49535) via GigabitEthernet0/0/ 0
*Jan 21 09:06:40.356: TFTP: Looking for ITLFile.tlv
*Jan 21 09:06:40.356: TFTP: Sending error 1 No such file
*Jan 21 09:06:42.605: TFTP: Server request for port 50607, socket_id 0x7F397C71F200 for proce ss 448
*Jan 21 09:06:42.605: TFTP: read request from host 10.13.2.243(50607) via GigabitEthernet0/0/ 0
*Jan 21 09:06:42.605: TFTP: Looking for SEPC064E4ECE0DE.cnf.xml
*Jan 21 09:06:42.618: TFTP: Opened flash:/its/SEPC064E4ECE0DE.cnf.xml, fd 0, size 4801 for pr ocess 448
*Jan 21 09:06:42.618: TFTP: Sending block 1 (retry 0), len 512, socket_id 0x7F397C71F200
*Jan 21 09:06:42.622: TFTP: Received ACK for block 1, socket_id 0x7F397C71F200
*Jan 21 09:06:42.622: TFTP: Sending block 2 (retry 0), len 512, socket_id 0x7F397C71F200
*Jan 21 09:06:42.625: TFTP: Received ACK for block 2, socket_id 0x7F397C71F200
*Jan 21 09:06:42.625: TFTP: Sending block 3 (retry 0), len 512, socket_id 0x7F397C71F200
*Jan 21 09:06:42.628: TFTP: Received ACK for block 3, socket_id 0x7F397C71F200
*Jan 21 09:06:42.628: TFTP: Sending block 4 (retry 0), len 512, socket_id 0x7F397C71F200
*Jan 21 09:06:42.631: TFTP: Received ACK for block 4, socket_id 0x7F397C71F200
*Jan 21 09:06:42.631: TFTP: Sending block 5 (retry 0), len 512, socket_id 0x7F397C71F200
*Jan 21 09:06:42.634: TFTP: Received ACK for block 5, socket_id 0x7F397C71F200
*Jan 21 09:06:42.635: TFTP: Sending block 6 (retry 0), len 512, socket_id 0x7F397C71F200
*Jan 21 09:06:42.638: TFTP: Received ACK for block 6, socket_id 0x7F397C71F200
*Jan 21 09:06:42.638: TFTP: Sending block 7 (retry 0), len 512, socket_id 0x7F397C71F200
*Jan 21 09:06:42.642: TFTP: Received ACK for block 7, socket_id 0x7F397C71F200
*Jan 21 09:06:42.642: TFTP: Sending block 8 (retry 0), len 512, socket_id 0x7F397C71F200
*Jan 21 09:06:42.645: TFTP: Received ACK for block 8, socket_id 0x7F397C71F200
*Jan 21 09:06:42.645: TFTP: Sending block 9 (retry 0), len 512, socket_id 0x7F397C71F200
*Jan 21 09:06:42.648: TFTP: Received ACK for block 9, socket_id 0x7F397C71F200
*Jan 21 09:06:42.648: TFTP: Sending block 10 (retry 0), len 193, socket_id 0x7F397C71F200
*Jan 21 09:06:42.651: TFTP: Received ACK for block 10, socket_id 0x7F397C71F200
*Jan 21 09:06:42.651: TFTP: Finished flash:/its/SEPC064E4ECE0DE.cnf.xml, time 00:00:00 for pr ocess 448
*Jan 21 09:06:43.786: TFTP: Server request for port 50089, socket_id 0x7F398E85E418 for proce ss 448
*Jan 21 09:06:43.786: TFTP: read request from host 10.13.2.240(50089) via GigabitEthernet0/0/ 0
*Jan 21 09:06:43.787: TFTP: Looking for CTLSEPD4ADBD0C79BE.tlv
*Jan 21 09:06:43.787: TFTP: Sending error 1 No such file
*Jan 21 09:06:45.306: TFTP: Server request for port 51460, socket_id 0x7F398E85E418 for proce ss 448
*Jan 21 09:06:45.306: TFTP: read request from host 10.13.2.243(51460) via GigabitEthernet0/0/ 0
*Jan 21 09:06:45.306: TFTP: Looking for AppDialRules.xml
*Jan 21 09:06:45.306: TFTP: Sending error 1 No such file
*Jan 21 09:06:45.736: TFTP: Server request for port 52962, socket_id 0x7F398E85E418 for proce ss 448
*Jan 21 09:06:45.736: TFTP: read request from host 10.13.2.240(52962) via GigabitEthernet0/0/ 0
*Jan 21 09:06:45.736: TFTP: Looking for ITLSEPD4ADBD0C79BE.tlv
*Jan 21 09:06:45.736: TFTP: Sending error 1 No such file
*Jan 21 09:06:47.646: TFTP: Server request for port 50256, socket_id 0x7F398E85E418 for proce ss 448
*Jan 21 09:06:47.646: TFTP: read request from host 10.13.2.243(50256) via GigabitEthernet0/0/ 0
*Jan 21 09:06:47.646: TFTP: Looking for WLANRootCA.cer
*Jan 21 09:06:47.646: TFTP: Sending error 1 No such file
*Jan 21 09:06:47.985: TFTP: Server request for port 51969, socket_id 0x7F398E85E418 for proce ss 448
*Jan 21 09:06:47.986: TFTP: read request from host 10.13.2.240(51969) via GigabitEthernet0/0/ 0
*Jan 21 09:06:47.986: TFTP: Looking for ITLFile.tlv
*Jan 21 09:06:47.986: TFTP: Sending error 1 No such file
*Jan 21 09:06:49.936: TFTP: Server request for port 52753, socket_id 0x7F398E85E418 for proce ss 448
*Jan 21 09:06:49.937: TFTP: read request from host 10.13.2.243(52753) via GigabitEthernet0/0/ 0
*Jan 21 09:06:49.937: TFTP: Looking for 8821-WLANC064E4ECE0DE.xml
*Jan 21 09:06:49.937: TFTP: Sending error 1 No such file
*Jan 21 09:06:49.962: TFTP: Server request for port 50030, socket_id 0x7F398E85E418 for proce ss 448
*Jan 21 09:06:49.962: TFTP: read request from host 10.13.2.240(50030) via GigabitEthernet0/0/ 0
*Jan 21 09:06:49.962: TFTP: Looking for SEPD4ADBD0C79BE.cnf.xml
*Jan 21 09:06:49.979: TFTP: Opened flash:/its/SEPD4ADBD0C79BE.cnf.xml, fd 0, size 4801 for pr ocess 448
*Jan 21 09:06:49.980: TFTP: Sending block 1 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:06:49.984: TFTP: Received ACK for block 1, socket_id 0x7F398E85E418
*Jan 21 09:06:49.984: TFTP: Sending block 2 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:06:49.987: TFTP: Received ACK for block 2, socket_id 0x7F398E85E418
*Jan 21 09:06:49.988: TFTP: Sending block 3 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:06:49.989: TFTP: Received ACK for block 3, socket_id 0x7F398E85E418
*Jan 21 09:06:49.990: TFTP: Sending block 4 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:06:49.993: TFTP: Received ACK for block 4, socket_id 0x7F398E85E418
*Jan 21 09:06:49.993: TFTP: Sending block 5 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:06:49.998: TFTP: Received ACK for block 5, socket_id 0x7F398E85E418
*Jan 21 09:06:49.998: TFTP: Sending block 6 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:06:50.003: TFTP: Received ACK for block 6, socket_id 0x7F398E85E418
*Jan 21 09:06:50.003: TFTP: Sending block 7 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:06:50.006: TFTP: Received ACK for block 7, socket_id 0x7F398E85E418
*Jan 21 09:06:50.006: TFTP: Sending block 8 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:06:50.009: TFTP: Received ACK for block 8, socket_id 0x7F398E85E418
*Jan 21 09:06:50.009: TFTP: Sending block 9 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:06:50.012: TFTP: Received ACK for block 9, socket_id 0x7F398E85E418
*Jan 21 09:06:50.013: TFTP: Sending block 10 (retry 0), len 193, socket_id 0x7F398E85E418
*Jan 21 09:06:50.016: TFTP: Received ACK for block 10, socket_id 0x7F398E85E418
*Jan 21 09:06:50.016: TFTP: Finished flash:/its/SEPD4ADBD0C79BE.cnf.xml, time 00:00:00 for pr ocess 448
*Jan 21 09:06:52.246: TFTP: Server request for port 51174, socket_id 0x7F398E85E418 for proce ss 448
*Jan 21 09:06:52.246: TFTP: read request from host 10.13.2.243(51174) via GigabitEthernet0/0/ 0
*Jan 21 09:06:52.246: TFTP: Looking for 8821-WLANDefault.xml
*Jan 21 09:06:52.246: TFTP: Sending error 1 No such file
*Jan 21 09:06:52.446: TFTP: Server request for port 52492, socket_id 0x7F398E85E418 for proce ss 448
*Jan 21 09:06:52.446: TFTP: read request from host 10.13.2.240(52492) via GigabitEthernet0/0/ 0
*Jan 21 09:06:52.446: TFTP: Looking for AppDialRules.xml
*Jan 21 09:06:52.446: TFTP: Sending error 1 No such file
*Jan 21 09:06:54.431: TFTP: Server request for port 51810, socket_id 0x7F398E85E418 for proce ss 448
*Jan 21 09:06:54.431: TFTP: read request from host 10.13.2.243(51810) via GigabitEthernet0/0/ 0
*Jan 21 09:06:54.431: TFTP: Looking for softkeyDefault_kpml.xml
*Jan 21 09:06:54.433: TFTP: Opened flash:/its/softkeyDefault_kpml.xml, fd 0, size 4846 for pr ocess 448
*Jan 21 09:06:54.433: TFTP: Sending block 1 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:06:54.436: TFTP: Received ACK for block 1, socket_id 0x7F398E85E418
*Jan 21 09:06:54.437: TFTP: Sending block 2 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:06:54.440: TFTP: Received ACK for block 2, socket_id 0x7F398E85E418
*Jan 21 09:06:54.440: TFTP: Sending block 3 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:06:54.443: TFTP: Received ACK for block 3, socket_id 0x7F398E85E418
*Jan 21 09:06:54.443: TFTP: Sending block 4 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:06:54.446: TFTP: Received ACK for block 4, socket_id 0x7F398E85E418
*Jan 21 09:06:54.447: TFTP: Sending block 5 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:06:54.449: TFTP: Received ACK for block 5, socket_id 0x7F398E85E418
*Jan 21 09:06:54.450: TFTP: Sending block 6 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:06:54.453: TFTP: Received ACK for block 6, socket_id 0x7F398E85E418
*Jan 21 09:06:54.453: TFTP: Sending block 7 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:06:54.456: TFTP: Received ACK for block 7, socket_id 0x7F398E85E418
*Jan 21 09:06:54.456: TFTP: Sending block 8 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:06:54.459: TFTP: Received ACK for block 8, socket_id 0x7F398E85E418
*Jan 21 09:06:54.460: TFTP: Sending block 9 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:06:54.462: TFTP: Received ACK for block 9, socket_id 0x7F398E85E418
*Jan 21 09:06:54.463: TFTP: Sending block 10 (retry 0), len 238, socket_id 0x7F398E85E418
*Jan 21 09:06:54.466: TFTP: Received ACK for block 10, socket_id 0x7F398E85E418
*Jan 21 09:06:54.466: TFTP: Finished flash:/its/softkeyDefault_kpml.xml, time 00:00:00 for pr ocess 448
*Jan 21 09:06:54.545: TFTP: Server request for port 50643, socket_id 0x7F398E85E418 for proce ss 448
*Jan 21 09:06:54.546: TFTP: read request from host 10.13.2.240(50643) via GigabitEthernet0/0/ 0
*Jan 21 09:06:54.546: TFTP: Looking for WLANRootCA.cer
*Jan 21 09:06:54.546: TFTP: Sending error 1 No such file
*Jan 21 09:06:56.646: TFTP: Server request for port 49472, socket_id 0x7F398E85E418 for proce ss 448
*Jan 21 09:06:56.646: TFTP: read request from host 10.13.2.240(49472) via GigabitEthernet0/0/ 0
*Jan 21 09:06:56.646: TFTP: Looking for 8821-WLAND4ADBD0C79BE.xml
*Jan 21 09:06:56.646: TFTP: Sending error 1 No such file
*Jan 21 09:06:57.371: TFTP: Server request for port 50102, socket_id 0x7F398E85E418 for proce ss 448
*Jan 21 09:06:57.371: TFTP: read request from host 10.13.2.242(50102) via GigabitEthernet0/0/ 0
*Jan 21 09:06:57.371: TFTP: Looking for CTLSEP5061BF3DF344.tlv
*Jan 21 09:06:57.371: TFTP: Sending error 1 No such file
*Jan 21 09:06:58.273: TFTP: Server request for port 53106, socket_id 0x7F398E85E418 for proce ss 448
*Jan 21 09:06:58.273: TFTP: read request from host 10.13.2.242(53106) via GigabitEthernet0/0/ 0
*Jan 21 09:06:58.274: TFTP: Looking for ITLSEP5061BF3DF344.tlv
*Jan 21 09:06:58.274: TFTP: Sending error 1 No such file
*Jan 21 09:06:58.656: TFTP: Server request for port 49280, socket_id 0x7F398E85E418 for proce ss 448
*Jan 21 09:06:58.656: TFTP: read request from host 10.13.2.240(49280) via GigabitEthernet0/0/ 0
*Jan 21 09:06:58.656: TFTP: Looking for 8821-WLANDefault.xml
*Jan 21 09:06:58.656: TFTP: Sending error 1 No such file
*Jan 21 09:06:59.177: TFTP: Server request for port 51970, socket_id 0x7F398E85E418 for proce ss 448
*Jan 21 09:06:59.177: TFTP: read request from host 10.13.2.242(51970) via GigabitEthernet0/0/ 0
*Jan 21 09:06:59.177: TFTP: Looking for ITLFile.tlv
*Jan 21 09:06:59.177: TFTP: Sending error 1 No such file
*Jan 21 09:07:00.505: TFTP: Server request for port 52293, socket_id 0x7F398E85E418 for proce ss 448
*Jan 21 09:07:00.505: TFTP: read request from host 10.13.2.242(52293) via GigabitEthernet0/0/ 0
*Jan 21 09:07:00.505: TFTP: Looking for SEP5061BF3DF344.cnf.xml
*Jan 21 09:07:00.506: TFTP: Opened flash:/its/SEP5061BF3DF344.cnf.xml, fd 0, size 4772 for pr ocess 448
*Jan 21 09:07:00.506: TFTP: Sending block 1 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:00.508: TFTP: Received ACK for block 1, socket_id 0x7F398E85E418
*Jan 21 09:07:00.509: TFTP: Sending block 2 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:00.510: TFTP: Received ACK for block 2, socket_id 0x7F398E85E418
*Jan 21 09:07:00.510: TFTP: Sending block 3 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:00.511: TFTP: Received ACK for block 3, socket_id 0x7F398E85E418
*Jan 21 09:07:00.512: TFTP: Sending block 4 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:00.513: TFTP: Received ACK for block 4, socket_id 0x7F398E85E418
*Jan 21 09:07:00.513: TFTP: Sending block 5 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:00.514: TFTP: Received ACK for block 5, socket_id 0x7F398E85E418
*Jan 21 09:07:00.514: TFTP: Sending block 6 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:00.516: TFTP: Received ACK for block 6, socket_id 0x7F398E85E418
*Jan 21 09:07:00.516: TFTP: Sending block 7 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:00.517: TFTP: Received ACK for block 7, socket_id 0x7F398E85E418
*Jan 21 09:07:00.518: TFTP: Sending block 8 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:00.519: TFTP: Received ACK for block 8, socket_id 0x7F398E85E418
*Jan 21 09:07:00.519: TFTP: Sending block 9 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:00.520: TFTP: Received ACK for block 9, socket_id 0x7F398E85E418
*Jan 21 09:07:00.520: TFTP: Sending block 10 (retry 0), len 164, socket_id 0x7F398E85E418
*Jan 21 09:07:00.522: TFTP: Received ACK for block 10, socket_id 0x7F398E85E418
*Jan 21 09:07:00.522: TFTP: Finished flash:/its/SEP5061BF3DF344.cnf.xml, time 00:00:00 for pr ocess 448
*Jan 21 09:07:00.746: TFTP: Server request for port 49857, socket_id 0x7F398E85E418 for proce ss 448
*Jan 21 09:07:00.746: TFTP: read request from host 10.13.2.240(49857) via GigabitEthernet0/0/ 0
*Jan 21 09:07:00.746: TFTP: Looking for softkeyDefault_kpml.xml
*Jan 21 09:07:00.752: TFTP: Opened flash:/its/softkeyDefault_kpml.xml, fd 0, size 4846 for pr ocess 448
*Jan 21 09:07:00.753: TFTP: Sending block 1 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:00.757: TFTP: Received ACK for block 1, socket_id 0x7F398E85E418
*Jan 21 09:07:00.757: TFTP: Sending block 2 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:00.760: TFTP: Received ACK for block 2, socket_id 0x7F398E85E418
*Jan 21 09:07:00.760: TFTP: Sending block 3 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:00.763: TFTP: Received ACK for block 3, socket_id 0x7F398E85E418
*Jan 21 09:07:00.763: TFTP: Sending block 4 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:00.766: TFTP: Received ACK for block 4, socket_id 0x7F398E85E418
*Jan 21 09:07:00.766: TFTP: Sending block 5 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:00.769: TFTP: Received ACK for block 5, socket_id 0x7F398E85E418
*Jan 21 09:07:00.770: TFTP: Sending block 6 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:00.774: TFTP: Received ACK for block 6, socket_id 0x7F398E85E418
*Jan 21 09:07:00.774: TFTP: Sending block 7 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:00.777: TFTP: Received ACK for block 7, socket_id 0x7F398E85E418
*Jan 21 09:07:00.777: TFTP: Sending block 8 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:00.780: TFTP: Received ACK for block 8, socket_id 0x7F398E85E418
*Jan 21 09:07:00.780: TFTP: Sending block 9 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:00.785: TFTP: Received ACK for block 9, socket_id 0x7F398E85E418
*Jan 21 09:07:00.786: TFTP: Sending block 10 (retry 0), len 238, socket_id 0x7F398E85E418
*Jan 21 09:07:00.789: TFTP: Received ACK for block 10, socket_id 0x7F398E85E418
*Jan 21 09:07:00.789: TFTP: Finished flash:/its/softkeyDefault_kpml.xml, time 00:00:00 for pr ocess 448
*Jan 21 09:07:07.838: TFTP: Server request for port 50815, socket_id 0x7F398E85E418 for proce ss 448
*Jan 21 09:07:07.838: TFTP: read request from host 10.13.2.242(50815) via GigabitEthernet0/0/ 0
*Jan 21 09:07:07.838: TFTP: Looking for SIP_English_United_States/sp-sip.jar
*Jan 21 09:07:07.838: TFTP: Sending error 1 No such file
MYALRT01#
MYALRT01#
MYALRT01#
MYALRT01#
*Jan 21 09:07:08.886: TFTP: Server request for port 51214, socket_id 0x7F398E85E418 for proce ss 448
*Jan 21 09:07:08.886: TFTP: read request from host 10.13.2.242(51214) via GigabitEthernet0/0/ 0
*Jan 21 09:07:08.886: TFTP: Looking for SIP_United_Kingdom/g3-tones.xml
*Jan 21 09:07:08.886: TFTP: Sending error 1 No such file
*Jan 21 09:07:10.134: TFTP: Server request for port 49555, socket_id 0x7F398E85E418 for proce ss 448
*Jan 21 09:07:10.134: TFTP: read request from host 10.13.2.242(49555) via GigabitEthernet0/0/ 0
*Jan 21 09:07:10.134: TFTP: Looking for softkeyDefault_kpml.xml
*Jan 21 09:07:10.139: TFTP: Opened flash:/its/softkeyDefault_kpml.xml, fd 0, size 4846 for pr ocess 448
*Jan 21 09:07:10.139: TFTP: Sending block 1 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:10.141: TFTP: Received ACK for block 1, socket_id 0x7F398E85E418
*Jan 21 09:07:10.142: TFTP: Sending block 2 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:10.143: TFTP: Received ACK for block 2, socket_id 0x7F398E85E418
*Jan 21 09:07:10.143: TFTP: Sending block 3 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:10.144: TFTP: Received ACK for block 3, socket_id 0x7F398E85E418
*Jan 21 09:07:10.145: TFTP: Sending block 4 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:10.146: TFTP: Received ACK for block 4, socket_id 0x7F398E85E418
*Jan 21 09:07:10.146: TFTP: Sending block 5 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:10.148: TFTP: Received ACK for block 5, socket_id 0x7F398E85E418
*Jan 21 09:07:10.148: TFTP: Sending block 6 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:10.149: TFTP: Received ACK for block 6, socket_id 0x7F398E85E418
*Jan 21 09:07:10.149: TFTP: Sending block 7 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:10.150: TFTP: Received ACK for block 7, socket_id 0x7F398E85E418
*Jan 21 09:07:10.151: TFTP: Sending block 8 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:10.152: TFTP: Received ACK for block 8, socket_id 0x7F398E85E418
*Jan 21 09:07:10.152: TFTP: Sending block 9 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:10.153: TFTP: Received ACK for block 9, socket_id 0x7F398E85E418
*Jan 21 09:07:10.154: TFTP: Sending block 10 (retry 0), len 238, socket_id 0x7F398E85E418
*Jan 21 09:07:10.155: TFTP: Received ACK for block 10, socket_id 0x7F398E85E418
*Jan 21 09:07:10.155: TFTP: Finished flash:/its/softkeyDefault_kpml.xml, time 00:00:00 for pr ocess 448
*Jan 21 09:07:13.847: TFTP: Server request for port 53029, socket_id 0x7F398E85E418 for proce ss 448
*Jan 21 09:07:13.847: TFTP: read request from host 10.13.2.242(53029) via GigabitEthernet0/0/ 0
*Jan 21 09:07:13.847: TFTP: Looking for CTLSEP5061BF3DF344.tlv
*Jan 21 09:07:13.847: TFTP: Sending error 1 No such file
*Jan 21 09:07:14.748: TFTP: Server request for port 53015, socket_id 0x7F398E85E418 for proce ss 448
*Jan 21 09:07:14.748: TFTP: read request from host 10.13.2.242(53015) via GigabitEthernet0/0/ 0
*Jan 21 09:07:14.748: TFTP: Looking for ITLSEP5061BF3DF344.tlv
*Jan 21 09:07:14.749: TFTP: Sending error 1 No such file
*Jan 21 09:07:15.641: TFTP: Server request for port 52902, socket_id 0x7F398E85E418 for proce ss 448
*Jan 21 09:07:15.641: TFTP: read request from host 10.13.2.242(52902) via GigabitEthernet0/0/ 0
*Jan 21 09:07:15.641: TFTP: Looking for ITLFile.tlv
*Jan 21 09:07:15.641: TFTP: Sending error 1 No such file
*Jan 21 09:07:16.600: TFTP: Server request for port 52304, socket_id 0x7F398E85E418 for proce ss 448
*Jan 21 09:07:16.601: TFTP: read request from host 10.13.2.242(52304) via GigabitEthernet0/0/ 0
*Jan 21 09:07:16.601: TFTP: Looking for SEP5061BF3DF344.cnf.xml
*Jan 21 09:07:16.616: TFTP: Opened flash:/its/SEP5061BF3DF344.cnf.xml, fd 0, size 4772 for pr ocess 448
*Jan 21 09:07:16.617: TFTP: Sending block 1 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:16.618: TFTP: Received ACK for block 1, socket_id 0x7F398E85E418
*Jan 21 09:07:16.619: TFTP: Sending block 2 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:16.620: TFTP: Received ACK for block 2, socket_id 0x7F398E85E418
*Jan 21 09:07:16.620: TFTP: Sending block 3 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:16.623: TFTP: Received ACK for block 3, socket_id 0x7F398E85E418
*Jan 21 09:07:16.623: TFTP: Sending block 4 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:16.624: TFTP: Received ACK for block 4, socket_id 0x7F398E85E418
*Jan 21 09:07:16.624: TFTP: Sending block 5 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:16.625: TFTP: Received ACK for block 5, socket_id 0x7F398E85E418
*Jan 21 09:07:16.626: TFTP: Sending block 6 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:16.627: TFTP: Received ACK for block 6, socket_id 0x7F398E85E418
*Jan 21 09:07:16.627: TFTP: Sending block 7 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:16.628: TFTP: Received ACK for block 7, socket_id 0x7F398E85E418
*Jan 21 09:07:16.628: TFTP: Sending block 8 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:16.630: TFTP: Received ACK for block 8, socket_id 0x7F398E85E418
*Jan 21 09:07:16.630: TFTP: Sending block 9 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:16.631: TFTP: Received ACK for block 9, socket_id 0x7F398E85E418
*Jan 21 09:07:16.631: TFTP: Sending block 10 (retry 0), len 164, socket_id 0x7F398E85E418
*Jan 21 09:07:16.632: TFTP: Received ACK for block 10, socket_id 0x7F398E85E418
*Jan 21 09:07:16.633: TFTP: Finished flash:/its/SEP5061BF3DF344.cnf.xml, time 00:00:00 for pr ocess 448
*Jan 21 09:07:22.885: TFTP: Server request for port 49549, socket_id 0x7F398E85E418 for proce ss 448
*Jan 21 09:07:22.886: TFTP: read request from host 10.13.2.242(49549) via GigabitEthernet0/0/ 0
*Jan 21 09:07:22.886: TFTP: Looking for SIP_English_United_States/sp-sip.jar
*Jan 21 09:07:22.886: TFTP: Sending error 1 No such file
*Jan 21 09:07:23.946: TFTP: Server request for port 50007, socket_id 0x7F398E85E418 for proce ss 448
*Jan 21 09:07:23.946: TFTP: read request from host 10.13.2.242(50007) via GigabitEthernet0/0/ 0
*Jan 21 09:07:23.946: TFTP: Looking for SIP_United_Kingdom/g3-tones.xml
*Jan 21 09:07:23.946: TFTP: Sending error 1 No such file
*Jan 21 09:07:25.180: TFTP: Server request for port 53141, socket_id 0x7F398E85E418 for proce ss 448
*Jan 21 09:07:25.180: TFTP: read request from host 10.13.2.242(53141) via GigabitEthernet0/0/ 0
*Jan 21 09:07:25.180: TFTP: Looking for softkeyDefault_kpml.xml
*Jan 21 09:07:25.195: TFTP: Opened flash:/its/softkeyDefault_kpml.xml, fd 0, size 4846 for pr ocess 448
*Jan 21 09:07:25.196: TFTP: Sending block 1 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:25.197: TFTP: Received ACK for block 1, socket_id 0x7F398E85E418
*Jan 21 09:07:25.197: TFTP: Sending block 2 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:25.199: TFTP: Received ACK for block 2, socket_id 0x7F398E85E418
*Jan 21 09:07:25.199: TFTP: Sending block 3 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:25.200: TFTP: Received ACK for block 3, socket_id 0x7F398E85E418
*Jan 21 09:07:25.201: TFTP: Sending block 4 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:25.202: TFTP: Received ACK for block 4, socket_id 0x7F398E85E418
*Jan 21 09:07:25.202: TFTP: Sending block 5 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:25.203: TFTP: Received ACK for block 5, socket_id 0x7F398E85E418
*Jan 21 09:07:25.204: TFTP: Sending block 6 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:25.205: TFTP: Received ACK for block 6, socket_id 0x7F398E85E418
*Jan 21 09:07:25.205: TFTP: Sending block 7 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:25.206: TFTP: Received ACK for block 7, socket_id 0x7F398E85E418
*Jan 21 09:07:25.207: TFTP: Sending block 8 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:25.208: TFTP: Received ACK for block 8, socket_id 0x7F398E85E418
*Jan 21 09:07:25.208: TFTP: Sending block 9 (retry 0), len 512, socket_id 0x7F398E85E418
*Jan 21 09:07:25.210: TFTP: Received ACK for block 9, socket_id 0x7F398E85E418
*Jan 21 09:07:25.210: TFTP: Sending block 10 (retry 0), len 238, socket_id 0x7F398E85E418
*Jan 21 09:07:25.211: TFTP: Received ACK for block 10, socket_id 0x7F398E85E418
*Jan 21 09:07:25.211: TFTP: Finished flash:/its/softkeyDefault_kpml.xml, time 00:00:00 for pr ocess 448
From what I can tell all requests for files via TFTP completes with success from the perspective of your router. You'd need to look at the logs from the phone(s) to see what it complains about.
Response Signature
This is message status for the phones
You do know I assume that you can get the logs from the phones if you access them via the webUI or via SSH?
Response Signature
I have tried  both web GUI and SSH but I can't access the phones. IPs I can ping but access denied.
Both options are off from default. You need to enable it and for SSH you'd have to define a user name and password.
Response Signature
Sorry if I am asking basic but I am new into VoIP. Do I need to do this config for webGUI in my ISR 4331
Telephony-service 0
Service phone webAccess 1
Create cnf-files
