IP Telephony and Phones
watch here Journey banner_2
Labels
Hello I have this code to get the number of messages on a mailbox  run cuc dbquery unitymbxdb1 select count (*) as Messages from vw_message,unitydirdb:vw_mailbox, unitydirdb:vw_user where mailboxobjectid in (select mailboxid from vw_mailbox where uni...
Hello,we have a CUCM 12.0 and I'm stuck with creating a presence policy.Our goal is nobody should be able to watch the presence status of another user (U).Except the status of some Assistants (A) should be visible by everybody.U => U = status not vis...
rwesel by Level 1
  • 367 Views
  • 0 replies
International dialing is not working for number starts with 6 but all other international numbers are working.We have two TPs, one for number starts with 6 and the other one is for all otehr international numbersNOt working : Call scenario for number...
Yenosh by Level 1
  • 454 Views
  • 2 replies
Hello,I have accidentally wiped the flash: of my VG310. So now it boots straight to Rommon. I wanted to Xmodem a new image to it, but it does not seem to accept the copy command ("copy" not found). Any help would be greatfully received.Andrew
Hello,   I have done the configuration for the cme part and its working great, now I will have to configure the CUE. I have also done the basic configurations and I can also log on to the web interface, I need to Enable AA feature, I precisely mean w...
Hey guys, I have an issue with sip calls coming in from our provider, we are getting error 500 Q.850 cause 44any ideas? thanks  *Nov 1 20:14:54.065: //415/822D05688518/SIP/Msg/ccsipDisplayMsg:Sent:SIP/2.0 500 Internal Server ErrorVia: SIP/2.0/UDP 123...
stoofer by Level 1
  • 2336 Views
  • 2 replies
