IP Softphone for Mac OS
microaid
Does anyone know of a softphone that can be used on a MAC with the UC520?
IP communicator appears to be only for Windows.
8 Replies 8
buchholr
No Cisco softphones are available for the Macintosh that would work with the UC520.  Cisco has the Unified Personal Communicator that will work with the Mac, but it requires Cisco Unified Presence.
Your only option for a Mac softphone would be a 3rd party SIP client.  I can't provide any guidance on that as I haven't tried to get a SIP softphone working with any express products.  You would also likely lose some functionality with SIP clients.
Hope this helps,
Robert
Robert,
Thank you for the reply. I kinda had a feeling thats the way it was. I have tried the sip soft phones before phones, but never connected to a UC.
Todd
A google search reveals Xlite support for MAC
Im testing that one right now in my MAC as I have good experience with this Sofphone in my Windows XP machine
You may give it a try
http://www.counterpath.com/xlite-comparison.html
gogasca - can you please let us know how your testing with XLite on the Mac and a UC 520 went?  Also, can you post the proper configuration settings for PC and/or Mac based XLite clients for the UC520?  That would be REALLY helpful!
If you provide this information we will gladly help you test it and report back (we are Cisco partners but we're also end-users in this case using a UC520.)
Thanks!
Seth Miller
P.S.: This is far less important) - CounterPath apparently *just* released a version of Bria for the Mac 2 days ago. Would the config on the UC520 be different for this softphone vs. X-Lite?
http://www.counterpath.com/counterpath-launches-bria-3-0-multimedia-voip-softphone-for-mac-and-pc-platforms.html
Brandon Svec
Level 7
Level 7
I haven't tried myself, but telephone should work fine.
http://code.google.com/p/telephone/
Also, you can try sjphone
Let us know what you get working and how.
Brandon
-- please remember to rate and mark answered helpful posts --
HumanTorch
Level 5
Level 5
6 years old but now there's a free solution from Cisco.
Jabber for Mac!
It can be downloaded for free and set up in standalone mode without the IM&P server.
You can even see contacts from Active Directory.
Just wonder:
This Jabber for Mac, what CUCM version will it support? CUCM ver 8? ver10+?
Best regards,
Master002
Jabber documentation covers that, it will depend on the version you want to use:
https://www.cisco.com/c/en/us/support/unified-communications/jabber-windows/products-installation-guides-list.html
Review the planning guide.
java
if this helps, please rate
