IP telephone Debug tftp events troubleshout
zain_gabon
Hi Support
I have cisco 3845 with cme installed.
using 3 ip phones, 2 7911 and 1 7940.
the 3 ip phones are working fine, can call any ip phone from another.
My issue is when phone start, i have some error message on the screen of 7960, file not found before the ip phone display the extension number
i did the debug tftp event and debug tftp packes.
Here is the output when a restart phones:
1-/ Restart 7940
Jun  8 17:30:34.055: %IPPHONE-6-REG_ALARM: 23: Name=SEP001A2F336D26 Load=8.0(4.0) Last=Reset-Restart
Jun  8 17:30:34.055: %IPPHONE-6-REGISTER: ephone-3:SEP001A2F336D26 IP:172.16.100.5 Socket:5 DeviceType:Phone has registered.
Jun  8 17:30:35.447: TFTP: Server request for port 50078, socket_id 0x6498EA08 for process 81
Jun  8 17:30:35.447: TFTP: read request from host 172.16.100.5(50078) via GigabitEthernet0/0
Jun  8 17:30:35.447: TFTP: Looking for SEP001A2F336D26.cnf.xml
Jun  8 17:30:35.547: TFTP: Opened system:/its/XMLDefault7960.cnf.xml, fd 0, size 793 for process 81
Jun  8 17:30:35.547: TFTP: Sending block 1 (retry 0), socket_id 0x6498EA08
Jun  8 17:30:35.547: TFTP: Server request for port 50079, socket_id 0x643F95AC for process 143
Jun  8 17:30:35.547: TFTP: read request from host 172.16.100.5(50079) via GigabitEthernet0/0
Jun  8 17:30:35.547: TFTP: Looking for RINGLIST.XML
Jun  8 17:30:35.547: TFTP: Sending error 1 No such file
Jun  8 17:30:35.547: TFTP: Received ACK for block 1, socket_id 0x6498EA08
Jun  8 17:30:35.547: TFTP: Sending block 2 (retry 0), socket_id 0x6498EA08
Jun  8 17:30:35.639: TFTP: Received ACK for block 2, socket_id 0x6498EA08
Jun  8 17:30:35.639: TFTP: Finished system:/its/XMLDefault7960.cnf.xml, time 00:00:00 for process 81
Jun  8 17:30:35.639: TFTP: Server request for port 50080, socket_id 0x6498EA08 for process 81
Jun  8 17:30:35.639: TFTP: read request from host 172.16.100.5(50080) via GigabitEthernet0/0
Jun  8 17:30:35.639: TFTP: Looking for DISTINCTIVERINGLIST.XML
Jun  8 17:30:35.639: TFTP: Sending error 1 No such file
5 Accepted Solutions
Zain,
Can you please post the relevant part of your config?
Also, where is RingList.xml in your flash? perhaps you need something like:
tftp-server flash:/Ringtones/RingList.xml alias RingList.xml
Best,
David
Zain,
Did you try the following:
config t
tftp-server flash:ringtones/RingList.xml alias RingList.xml
tftp-server flash:ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
When you go to settings -> Ring type -> select on the 7960 do you get the full list of ringtones?
Regarding the 7911, it looks like its loading?  did you try
telephony-service
create cnf files
Best,
David
Zain,
Under ephone, put the type:
Lets say ephone 5 is the 7911:
config t
ephone 5   <- change this to proper ephone #
type 7911
Also, looks like theres a typo here:
tftp-server flash::phone/7906-7911/apps11.8-3-2-27.sbn  <-please correct flash:/ rather than :: in your config
For these you may also need to alias all these files within folders, for example:
tftp-server flash:/phone/7906-7911/SCCP11.8-3-3S.loads alias SCCP11.8-3-3S.load
for all te files.
Additionally, don't see the 7911 loads under telephony-service:
load 7911 SCCP11.8-3-3S.loads
Best,
David
Hows the 7911 after those changes?
Remeber to
telephony-service
no cnf files
create cnf files
after the changes
Best,
David
Zain,
There are still spelling errors in your config, and you need to do all the aliases as I have shown before:
config t
ephone  1
mac-address 2893.FE13.8750
button  1:1
type 7911
exi
tftp-server flash:ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:ringtones/FilmScore.raw alias Filmscore.raw
tftp-server flash:ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:ringtones/Pop.raw alias Pop.raw
tftp-server flash:ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:ringtones/Vibe.raw alias Vibe.raw
tftp-server flash:phone/7906-7911/apps11.8-3-2-27.sbn alias apps11.8-3-2-27.sbn
tftp-server flash:phone/7906-7911/cnu11.8-3-2-27.sbn alias cnu11.8-3-2-27.sbn
tftp-server flash:phone/7906-7911/cvm11sccp.8-3-2-27.sbn alias cvm11sccp.8-3-2-27.sbn
tftp-server flash:phone/7906-7911/dsp11.8-3-2-27.sbn alias dsp11.8-3-2-27.sbn
tftp-server flash:phone/7906-7911/jar11sccp.8-3-2-27.sbn alias jar11sccp.8-3-2-27.sbn
tftp-server flash:phone/7906-7911/SCCP11.8-3-3S.loads alias SCCP11.8-3-3S.loads
tftp-server flash:phone/7906-7911/term06.default.loads alias term06.default.loads
tftp-server flash:phone/7906-7911/term11.default.loads alias term11.default.loads
tftp-server flash:phone/7940-7960/P00308000500.sbn alias P00308000500.sbn
telephony-service
no cnf files
create cnf files
exi
ephone 1
reset
Best,
David
Zain,
CME 3.3 does not support the 7911 per the compatibility matrix. You'll need to update to a more recent version. I think the latest your router will support is IOS 15.1(4) and CME 8.6.
A very quick read of your config, everything else looks OK.
Best,
David
18 Replies 18
zain_gabon
sorry, this is the following
2- Restart ip phone 7911
Jun  8 17:37:48.467: TFTP: Server request for port 49185, socket_id 0x645B58C8 for process 81
Jun  8 17:37:48.467: TFTP: read request from host 172.16.100.4(49185) via GigabitEthernet0/0
Jun  8 17:37:48.467: TFTP: Looking for CTLSEP2893FE138750.tlv
Jun  8 17:37:48.467: TFTP: Sending error 1 No such file
Jun  8 17:37:48.551: TFTP: Server request for port 49186, socket_id 0x645B58C8 for process 81
Jun  8 17:37:48.551: TFTP: read request from host 172.16.100.4(49186) via GigabitEthernet0/0
Jun  8 17:37:48.551: TFTP: Looking for SEP2893FE138750.cnf.xml
Jun  8 17:37:48.551: TFTP: Sending error 1 No such file
Jun  8 17:37:48.635: TFTP: Server request for port 49187, socket_id 0x645B58C8 for process 81
Jun  8 17:37:48.635: TFTP: read request from host 172.16.100.4(49187) via GigabitEthernet0/0
Jun  8 17:37:48.635: TFTP: Looking for XMLDefault.cnf.xml
Jun  8 17:37:48.639: TFTP: Opened system:/its/XMLDefault.cnf.xml, fd 0, size 1210 for process 81
Jun  8 17:37:48.639: TFTP: Sending block 1 (retry 0), socket_id 0x645B58C8
Jun  8 17:37:48.639: TFTP: Received ACK for block 1, socket_id 0x645B58C8
Jun  8 17:37:48.639: TFTP: Sending block 2 (retry 0), socket_id 0x645B58C8
Jun  8 17:37:48.639: TFTP: Received ACK for block 2, socket_id 0x645B58C8
Jun  8 17:37:48.639: TFTP: Sending block 3 (retry 0), socket_id 0x645B58C8
Jun  8 17:37:48.643: TFTP: Received ACK for block 3, socket_id 0x645B58C8
Jun  8 17:37:48.643: TFTP: Finished system:/its/XMLDefault.cnf.xml, time 00:00:00 for process 81
Jun  8 17:37:49.955: %TCP-2-INVALIDTCB: Invalid TCB pointer: 0x645B5580 -Process= "Skinny Socket Server", ipl= 0, pid= 181 -Traceback= 0x6106D3C8 0x61769EAC 0x6176E1E8 0x61741BC8 0x61744A38 0x61748DA0 0x604323D0 0x60432E44 0x61E3E0C4 0x61E3E0A8
Jun  8 17:37:49.955: %TCP-2-INVALIDTCB: Invalid TCB pointer: 0x645B5580 -Process= "Skinny Socket Server", ipl= 0, pid= 181 -Traceback= 0x6106D3C8 0x61769EAC 0x6176E1E8 0x61741BC8 0x617449B8 0x61748DA0 0x604323F4 0x60432E44 0x61E3E0C4 0x61E3E0A8
Jun  8 17:37:49.955: %TCP-2-INVALIDTCB: Invalid TCB pointer: 0x645B5580 -Process= "Skinny Socket Server", ipl= 0, pid= 181 -Traceback= 0x6106D3C8 0x61769EAC 0x6176E1E8 0x61741BC8 0x617449D4 0x61748DA0 0x604323F4 0x60432E44 0x61E3E0C4 0x61E3E0A8
Jun  8 17:37:49.955: %TCP-2-INVALIDTCB: Invalid TCB pointer: 0x645B5580 -Process= "Skinny Socket Server", ipl= 0, pid= 181 -Traceback= 0x6106D3C8 0x61769EAC 0x6176E1E8 0x61741BC8 0x61748DB0 0x60432418 0x60432E44 0x61E3E0C4 0x61E3E0A8
Jun  8 17:37:49.955: %TCP-2-INVALIDTCB: Invalid TCB pointer: 0x645B5580 -Process= "Skinny Socket Server", ipl= 0, pid= 181 -Traceback= 0x6106D3C8 0x61769EAC 0x6176E1E8 0x61741BC8 0x61748DB0 0x60432438 0x60432E44 0x61E3E0C4 0x61E3E0A8
Jun  8 17:37:49.959: %TCP-2-INVALIDTCB: Invalid TCB pointer: 0x645B5580 -Process= "Skinny Socket Server", ipl= 0, pid= 181 -Traceback= 0x6106D3C8 0x61769EAC 0x6176E1E8 0x61741BC8 0x61744FF8 0x61748DDC 0x60432460 0x60432E44 0x61E3E0C4 0x61E3E0A8
Jun  8 17:37:50.087: %IPPHONE-6-REGISTER: ephone-1:SEP2893FE138750 IP:172.16.100.4 Socket:1 DeviceType:Phone has registered.
ROUTER(config-telephony)#
We can read that it's looking for missing files,
can someone help me on this?
Zain,
Best,
David
Dear David
Here is my run config
ROUTER#sh running-config
Building configuration...
Current configuration : 8056 bytes
! No configuration change since last restart
version 12.4
hostname ROUTER
boot-start-marker
boot system flash:c3845-ipvoicek9-mz.124-18.bin
boot-end-marker
enable password cisco
no aaa new-model
memory-size iomem 10
clock timezone WST 1
clock calendar-valid
ip cef
no ip dhcp use vrf connected
ip dhcp pool ITS
   network 172.16.100.0 255.255.255.0
   default-router 172.16.100.1
   option 150 ip 172.16.100.1
no ip domain lookup
voice-card 0
no dspfarm
voice service voip
sip
ip ftp username roland
ip ftp password roland
class-map match-all L3-to-L2_VoIP-Cntrl
match ip dscp af31
class-map match-all L3-to-L2_VoIP-RTP
match ip dscp ef
policy-map output-L3-to-L2
class L3-to-L2_VoIP-RTP
  priority 8
class L3-to-L2_VoIP-Cntrl
interface GigabitEthernet0/0
ip address 172.16.100.1 255.255.255.0
load-interval 30
duplex full
speed auto
media-type rj45
service-policy output output-L3-to-L2
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
media-type rj45
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http path flash:/gui
tftp-server flash:Desktops/320x212x12/CampusNight.png
tftp-server flash:Desktops/320x212x12/CiscoFountain.png
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:Desktops/320x212x12/MorroRock.png
tftp-server flash:Desktops/320x212x12/NantucketFlowers.png
tftp-server flash:Desktops/320x212x12/TN-CampusNight.png
tftp-server flash:Desktops/320x212x12/TN-CiscoFountain.png
tftp-server flash:Desktops/320x212x12/TN-Fountain.png
tftp-server flash:Desktops/320x212x12/TN-MorroRock.png
tftp-server flash:Desktops/320x212x12/TN-NantucketFlowers.png
tftp-server flash:Desktops/320x212x12/Fountain.png
tftp-server flash:gui/admin_user.html
tftp-server flash:gui/admin_user.js
tftp-server flash:gui/CiscoLogo.gif
tftp-server flash:gui/Delete.gif
tftp-server flash:gui/dom.js
tftp-server flash:gui/downarrow.gif
tftp-server flash:gui/ephone_admin.html
tftp-server flash:gui/logohome.gif
tftp-server flash:gui/normal_user.html
tftp-server flash:gui/normal_user.js
tftp-server flash:gui/Plus.gif
tftp-server flash:gui/sxiconad.gif
tftp-server flash:gui/Tab.gif
tftp-server flash:gui/telephony_service.html
tftp-server flash:gui/uparrow.gif
tftp-server flash:gui/xml-test.html
tftp-server flash:gui/xml.template
tftp-server flash:phone/7945-7965/apps45.8-3-2-27.sbn alias apps45.8-3-2-27.sbn
tftp-server flash:phone/7945-7965/cnu45.8-3-2-27.sbn alias cnu45.8-3-2-27.sbn
tftp-server flash:phone/7945-7965/cvm45sccp.8-3-2-27.sbn alias cvm45sccp.8-3-2-27.sbn
tftp-server flash:phone/7945-7965/dsp45.8-3-2-27.sbn alias dsp45.8-3-2-27.sbn
tftp-server flash:phone/7945-7965/jar45sccp.8-3-2-27.sbn alias jar45sccp.8-3-2-27.sbn
tftp-server flash:phone/7945-7965/SCCP45.8-3-3S.loads alias SCCP45.8-3-3S.loads
tftp-server flash:phone/7945-7965/term45.default.loads alias term45.default.loads
tftp-server flash:phone/7945-7965/term65.default.loads alias term65.default.loads
tftp-server flash:phone/7914/S00105000300.sbn alias S00105000300.sbn
tftp-server flash:phone/7920/cmterm_7920.4.0-03-02.bin alias cmterm_7920.4.0-03-02.bin
tftp-server flash:phone/7921/APPS-1.1.1.SBN alias APPS-1.1.1.SBN
tftp-server flash:phone/7921/CP7921G-1.1.1.LOADS alias CP7921G-1.1.1.LOADS
tftp-server flash:phone/7921/GUI-1.1.1.SBN alias GUI-1.1.1.SBN
tftp-server flash:phone/7921/SYS-1.1.1.SBN alias SYS-1.1.1.SBN
tftp-server flash:phone/7921/TNUX-1.1.1.SBN alias TNUX-1.1.1.SBN
tftp-server flash:phone/7921/TNUXR-1.1.1.SBN alias TNUXR-1.1.1.SBN
tftp-server flash:phone/7921/WLAN-1.1.1.SBN alias WLAN-1.1.1.SBN
tftp-server flash:phone/7931/apps31.8-3-2-27.sbn alias apps31.8-3-2-27.sbn
tftp-server flash:phone/7931/cnu31.8-3-2-27.sbn alias cnu31.8-3-2-27.sbn
tftp-server flash:phone/7931/cvm31sccp.8-3-2-27.sbn alias cvm31sccp.8-3-2-27.sbn
tftp-server flash:phone/7931/dsp31.8-3-2-27.sbn alias dsp31.8-3-2-27.sbn
tftp-server flash:phone/7931/jar31sccp.8-3-2-27.sbn alias jar31sccp.8-3-2-27.sbn
tftp-server flash:phone/7931/SCCP31.8-3-3S.loads alias SCCP31.8-3-3S.loads
tftp-server flash:phone/7931/term31.default.loads alias term31.default.loads
tftp-server flash:phone/7937/apps37sccp.1-1-1-1.bin alias apps37sccp.1-1-1-1.bin
tftp-server flash:phone/7940-7960/P00308000500.bin alias P00308000500.bin
tftp-server flash:phone/7940-7960/P00308000500.loads alias P00308000500.loads
tftp-server flash:phone/7940-7960/P00308000500.sb2 alias P00308000500.sb2
tftp-server flash:phone/7975/cvm75sccp.8-3-2-27.sbn alias cvm75sccp.8-3-2-27.sbn
tftp-server flash:phone/7975/dsp75.8-3-2-27.sbn alias dsp75.8-3-2-27.sbn
tftp-server flash:/phone/7906-7911/apps11.8-3-2-27.sbn
tftp-server flash:/phone/7906-7911/cnu11.8-3-2-27.sbn
tftp-server flash:/phone/7906-7911/cvm11sccp.8-3-2-27.sbn
tftp-server flash:/phone/7906-7911/dsp11.8-3-2-27.sbn
tftp-server flash:/phone/7906-7911/jar11sccp.8-3-2-27.sbn
tftp-server flash:/phone/7906-7911/term06.default.loads
tftp-server flash:/phone/7906-7911/term11.default.loads
tftp-server flash:phone/7940-7960/P00308000500.sb2 alias P00308000500.sbn
tftp-server system:/its/XMLDefault.cnf.xml
tftp-server system:/its/XMLDefault7961.cnf.xml
tftp-server system:/its/XMLDefault7910.cnf.xml
control-plane
telephony-service
load 7910 P004E302
load 7960-7940 P00308000500
load 7914 S00105000300
load 7920 cmterm_7920.4.0-03-02
load 7961 SCCP41.8-3-3S
load 7971 SCCP70.8-3-3S
load 7970 SCCP70.8-3-3S
max-ephones 10
max-dn 20
ip source-address 172.16.100.1 port 2000
system message IPNET-SERVICES
time-zone 21
time-format 24
create cnf-files version-stamp 7960 Jun 08 2012 21:18:25
max-conferences 10 gain -6
web admin system name cisco password cisco
time-webedit
transfer-system full-consult
ephone-dn  1
number 100
ephone-dn  2
number 101
ephone-dn  3
number 102
ephone-dn  4
number 104
ephone  1
button  1:1
ephone  2
mac-address 2893.FE13.81EC
button  1:2
ephone  3
mac-address 001A.2F33.6D26
button  1:3
ephone  4
mac-address 0022.644A.E6C9
button  1:4
line con 0
line aux 0
line vty 0 4
password cisco
login
scheduler allocate 20000 1000
ntp master 1
end
ROUTER#
Zain,
config t
telephony-service
create cnf files
Best,
David
Dear David,
Just write the commands on the post,
Regarding 7911, it working but the output of debug show the output below
Jun  8 20:44:01.739: %IPPHONE-6-UNREGISTER_NORMAL: ephone-1:SEP2893FE138750 IP:172.16.100.2 Socket:2 DeviceType:Phone has unregistered normally.
Jun  8 20:44:01.899: TFTP: Server request for port 49225, socket_id 0x64ED1B8C for process 81
Jun  8 20:44:01.899: TFTP: read request from host 172.16.100.2(49225) via GigabitEthernet0/0
Jun  8 20:44:01.899: TFTP: Looking for CTLSEP2893FE138750.tlv
Jun  8 20:44:01.899: TFTP: Sending error 1 No such file
Jun  8 20:44:01.991: TFTP: Server request for port 49226, socket_id 0x64ED1B8C for process 81
Jun  8 20:44:01.991: TFTP: read request from host 172.16.100.2(49226) via GigabitEthernet0/0
Jun  8 20:44:01.991: TFTP: Looking for SEP2893FE138750.cnf.xml
Jun  8 20:44:01.991: TFTP: Sending error 1 No such file
Jun  8 20:44:02.083: TFTP: Server request for port 49227, socket_id 0x64ED1B8C for process 81
Jun  8 20:44:02.083: TFTP: read request from host 172.16.100.2(49227) via GigabitEthernet0/0
Jun  8 20:44:02.083: TFTP: Looking for XMLDefault.cnf.xml
Jun  8 20:44:02.183: TFTP: Opened system:/its/XMLDefault.cnf.xml, fd 0, size 1210 for process 81
Jun  8 20:44:02.183: TFTP: Sending block 1 (retry 0), socket_id 0x64ED1B8C
Jun  8 20:44:02.187: TFTP: Received ACK for block 1, socket_id 0x64ED1B8C
Jun  8 20:44:02.187: TFTP: Sending block 2 (retry 0), socket_id 0x64ED1B8C
Jun  8 20:44:02.187: TFTP: Received ACK for block 2, socket_id 0x64ED1B8C
Jun  8 20:44:02.191: TFTP: Sending block 3 (retry 0), socket_id 0x64ED1B8C
Jun  8 20:44:02.191: TFTP: Received ACK for block 3, socket_id 0x64ED1B8C
Jun  8 20:44:02.191: TFTP: Finished system:/its/XMLDefault.cnf.xml, time 00:00:00 for process 81
Jun  8 20:44:03.643: %TCP-2-INVALIDTCB: Invalid TCB pointer: 0x64ED12D4 -Process= "Skinny Socket Server", ipl= 0, pid= 181 -Traceback= 0x6106D3C8 0x61769EAC 0x6176E1E8 0x61741BC8 0x61744A38 0x61748DA0 0x604323D0 0x60432E44 0x61E3E0C4 0x61E3E0A8
Jun  8 20:44:03.643: %TCP-2-INVALIDTCB: Invalid TCB pointer: 0x64ED12D4 -Process= "Skinny Socket Server", ipl= 0, pid= 181 -Traceback= 0x6106D3C8 0x61769EAC 0x6176E1E8 0x61741BC8 0x617449B8 0x61748DA0 0x604323F4 0x60432E44 0x61E3E0C4 0x61E3E0A8
Jun  8 20:44:03.643: %TCP-2-INVALIDTCB: Invalid TCB pointer: 0x64ED12D4 -Process= "Skinny Socket Server", ipl= 0, pid= 181 -Traceback= 0x6106D3C8 0x61769EAC 0x6176E1E8 0x61741BC8 0x617449D4 0x61748DA0 0x604323F4 0x60432E44 0x61E3E0C4 0x61E3E0A8
Jun  8 20:44:03.643: %TCP-2-INVALIDTCB: Invalid TCB pointer: 0x64ED12D4 -Process= "Skinny Socket Server", ipl= 0, pid= 181 -Traceback= 0x6106D3C8 0x61769EAC 0x6176E1E8 0x61741BC8 0x61748DB0 0x60432418 0x60432E44 0x61E3E0C4 0x61E3E0A8
Jun  8 20:44:03.643: %TCP-2-INVALIDTCB: Invalid TCB pointer: 0x64ED12D4 -Process= "Skinny Socket Server", ipl= 0, pid= 181 -Traceback= 0x6106D3C8 0x61769EAC 0x6176E1E8 0x61741BC8 0x61748DB0 0x60432438 0x60432E44 0x61E3E0C4 0x61E3E0A8
Jun  8 20:44:03.647: %TCP-2-INVALIDTCB: Invalid TCB pointer: 0x64ED12D4 -Process= "Skinny Socket Server", ipl= 0, pid= 181 -Traceback= 0x6106D3C8 0x61769EAC 0x6176E1E8 0x61741BC8 0x61744FF8 0x61748DDC 0x60432460 0x60432E44 0x61E3E0C4 0x61E3E0A8
Jun  8 20:44:03.755: %IPPHONE-6-REGISTER: ephone-1:SEP2893FE138750 IP:172.16.100.2 Socket:2 DeviceType:Phone has registered.
Jun  8 20:44:03.891: %TCP-2-INVALIDTCB: Invalid TCB pointer: 0x64478134 -Process= "Skinny Socket Server", ipl= 0, pid= 181 -Traceback= 0x6106D3C8 0x61769EAC 0x6176E1E8 0x61741BC8 0x61744A38 0x61748DA0 0x604323D0 0x60432E44 0x61E3E0C4 0x61E3E0A8
Jun  8 20:44:03.891: %TCP-2-INVALIDTCB: Invalid TCB pointer: 0x64478134 -Process= "Skinny Socket Server", ipl= 0, pid= 181 -Traceback= 0x6106D3C8 0x61769EAC 0x6176E1E8 0x61741BC8 0x617449B8 0x61748DA0 0x604323F4 0x60432E44 0x61E3E0C4 0x61E3E0A8
Jun  8 20:44:03.891: %TCP-2-INVALIDTCB: Invalid TCB pointer: 0x64478134 -Process= "Skinny Socket Server", ipl= 0, pid= 181 -Traceback= 0x6106D3C8 0x61769EAC 0x6176E1E8 0x61741BC8 0x617449D4 0x61748DA0 0x604323F4 0x60432E44 0x61E3E0C4 0x61E3E0A8
Jun  8 20:44:03.895: %TCP-2-INVALIDTCB: Invalid TCB pointer: 0x64478134 -Process= "Skinny Socket Server", ipl= 0, pid= 181 -Traceback= 0x6106D3C8 0x61769EAC 0x6176E1E8 0x61741BC8 0x61748DB0 0x60432418 0x60432E44 0x61E3E0C4 0x61E3E0A8
Jun  8 20:44:03.895: %TCP-2-INVALIDTCB: Invalid TCB pointer: 0x64478134 -Process= "Skinny Socket Server", ipl= 0, pid= 181 -Traceback= 0x6106D3C8 0x61769EAC 0x6176E1E8 0x61741BC8 0x61748DB0 0x60432438 0x60432E44 0x61E3E0C4 0x61E3E0A8
Jun  8 20:44:03.895: %TCP-2-INVALIDTCB: Invalid TCB pointer: 0x64478134 -Process= "Skinny Socket Server", ipl= 0, pid= 181 -Traceback= 0x6106D3C8 0x61769EAC 0x6176E1E8 0x61741BC8 0x61744FF8 0x61748DDC 0x60432460 0x60432E44 0x61E3E0C4 0x61E3E0A8
Looking for some files
Thanks David
No error from 7940 ip phone,
just to correct my tftp-server line config
Zain,
config t
type 7911
for all te files.
Best,
David
Remeber to
telephony-service
no cnf files
create cnf files
after the changes
Best,
David
the 7911 is woking but there are some errors,
I must again check my confg regarding the load 7911
i have this error message
Jun  8 21:49:29.423: TFTP: Server request for port 49187, socket_id 0x6528A6F8 for process 33
Jun  8 21:49:29.423: TFTP: read request from host 172.16.100.2(49187) via GigabitEthernet0/0
Jun  8 21:49:29.423: TFTP: Looking for CTLSEP2893FE138750.tlv
Jun  8 21:49:29.423: TFTP: Sending error 1 No such file
Jun  8 21:49:29.547: TFTP: Server request for port 49188, socket_id 0x6528A6F8 for process 33
Jun  8 21:49:29.547: TFTP: read request from host 172.16.100.2(49188) via GigabitEthernet0/0
Jun  8 21:49:29.547: TFTP: Looking for SEP2893FE138750.cnf.xml
Jun  8 21:49:29.551: TFTP: Opened system:/its/XMLDefault7910.cnf.xml, fd 0, size 450 for process 33
Jun  8 21:49:29.551: TFTP: Sending block 1 (retry 0), socket_id 0x6528A6F8
Jun  8 21:49:29.551: TFTP: Received ACK for block 1, socket_id 0x6528A6F8
Jun  8 21:49:29.551: TFTP: Finished system:/its/XMLDefault7910.cnf.xml, time 00:00:00 for process 33
Jun  8 21:49:40.999: TFTP: Server request for port 49189, socket_id 0x6528A6F8 for process 33
Jun  8 21:49:40.999: TFTP: read request from host 172.16.100.2(49189) via GigabitEthernet0/0
Jun  8 21:49:40.999: TFTP: Looking for SCCP11.loads
Jun  8 21:49:40.999: TFTP: Sending error 1 No such file
The only thing regarding 7940 is that it take a long time rebooting.
Zain,
config t
ephone  1
button  1:1
type 7911
exi
telephony-service
no cnf files
create cnf files
exi
ephone 1
reset
Best,
David
Also, looks like your 7940 is ephone 3, you may want to add type 7940 under the ephone.
Best,
David
Hi David
I have no load 7911 on my router
below is my load option under telephony-service
ROUTER(config-telephony)#load ?
  12SP       Select the firmware load file for 12SP+ and 30VIP phones
  7902       Select the firmware load file for 7902
  7905       Select the firmware load file for 7905
  7910       Select the firmware load file for Telecaster 7910 phones
  7912       Select the firmware load file for 7912
  7914       Select the firmware load file for sidecar 7914
  7920       Select the firmware load file for 7920
  7935       Select the firmware load file for 7935 Conference Station
  7936       Select the firmware load file for 7936
  7960-7940  Select the firmware load file for Telecaster 7960 & 7940 phones
  7970       Select the firmware load file for 7970
  7971       Select the firmware load file for 7971
  ATA        Select the firmware load file for ATA
There is no 7911 ip phone
Hi David,
My cme is 3.3, my router is 3845
ROUTER#sh version
Cisco IOS Software, 3800 Software (C3845-IPVOICEK9-M), Version 12.4(18), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Fri 30-Nov-07 23:50 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T10, RELEASE SOFTWARE (fc1)
ROUTER uptime is 11 minutes
System returned to ROM by reload at 00:10:28 WST Sat Jun 9 2012
System restarted at 00:11:26 WST Sat Jun 9 2012
System image file is "flash:c3845-ipvoicek9-mz.124-18.bin"
Cisco 3845 (revision 1.0) with 236544K/25600K bytes of memory.
Processor board ID FCZ1240703B
2 Gigabit Ethernet interfaces
4 Voice FXO interfaces
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
125184K bytes of ATA System CompactFlash (Read/Write)
ROUTER#
ROUTER#sh telephony-service
CONFIG (Version=3.3)
Version 3.3
Cisco CallManager Express
For on-line documentation please see:
www.cisco.com/univercd/cc/td/doc/product/access/ip_ph/ip_ks/index.htm
the run config
ROUTER#sh run
Current configuration : 4656 bytes
version 12.4
hostname ROUTER
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip dhcp pool ITS
no ip domain lookup
voice-card 0
no dspfarm
voice service voip
sip
match ip dscp af31
match ip dscp ef
  priority 8
load-interval 30
duplex full
speed auto
media-type rj45
no ip address
shutdown
duplex auto
speed auto
media-type rj45
ip http server
tftp-server flash:/phone/7906-7911/apps11.8-3-2-27.sbn alias apps11.8-3-2-27.sbn
tftp-server flash:/phone/7906-7911/cnu11.8-3-2-27.sbn alias cnu11.8-3-2-27.sbn
tftp-server flash:/phone/7906-7911/cvm11sccp.8-3-2-27.sbn alias cvm11sccp.8-3-2-27.sbn
tftp-server flash:/phone/7906-7911/dsp11.8-3-2-27.sbn alias dsp11.8-3-2-27.sbn
tftp-server flash:/phone/7906-7911/jar11sccp.8-3-2-27.sbn alias jar11sccp.8-3-2-27.sbn
tftp-server flash:/phone/7906-7911/SCCP11.8-3-3S.loads alias SCCP11.8-3-3S.loads
tftp-server flash:/phone/7906-7911/term06.default.loads alias term06.default.loads
tftp-server flash:/phone/7906-7911/term11.default.loads alias term11.default.loads
tftp-server system:/its/XMLDefault7910.cnf.xml alias XMLDefault7910.cnf.xml
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/ringtones/Pop.raw alias Pop.raw
tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
control-plane
telephony-service
load 7910 SIP11
load 7905 CP7905080001SCCP051117A.sbin
load 7902 CP7902080002SCCP051117A.sbin
load 7912 CP7912080003SCCP070409A.sbin
max-ephones 10
max-dn 20
time-zone 29
time-format 24
create cnf-files version-stamp 7960 Jun 09 2012 00:11:43
time-webedit
ephone-dn  1
number 100
ephone-dn  2
number 101
ephone-dn  3
number 102
ephone-dn  4
number 104
ephone  1
type 7910
button  1:1
ephone  2
type 7910
button  1:2
ephone  3
type 7940
button  1:3 2:4
ephone  4
button  1:4
line con 0
line aux 0
line vty 0 4
password cisco
login
ntp master 1
end
ROUTER#
Zain,
Best,
David
Many Thanks,
It's very late from my side (it's 00h:35 mn)
Thanks for your help
will do the necessary to upgrade my cme
