05-30-2018 01:52 PM - edited 03-17-2019 12:55 PM
I would like to know if a line is "off hook" or if the line is busy. I am the admin, and would like to reboot the 8851 phone for a variety of reasons (In this particular case to enable bluethooth). I have googled this a lot, with no info. How do I determine if the phone is off hook by;
1) the phone web interface
2) CUCM
3) all else fails, the CLI on the PUB, SUB, or Gateway
Seems like this would be straight forward, but I can't find out how. NOTE, I did find a "Service State" on the web interface under device information, buy it reads idle even when the phone is in use.
05-30-2018 02:04 PM
05-30-2018 02:10 PM
Hi there
Also you can enable BLF presence (Native presence) in CUCM. Then you can monitor the extension in 2 ways.
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
05-30-2018 03:58 PM
If you use Jabber and all the user/line/device association is in place, you can also add the user in Jabber and you should see the status as soon as the go off-hook as "on a call".
If they dial on-hook and then press call, there is no way to find that out until they actually place the call.
