Is it possible to update line settings through a CSV file not by query?
applegreen
I have CUCM 7.1.3, I need to update line settings for almost 2 thousand selected records, is it possible to use UPDATE the line settings by using a CSV file , in CUCM BAT, the only option availabe is to select by query, however that's not an option for me, appreciate any input, thanks Yvonne
Rob Huffman
Hi Yvonne,
There is a fine overview from the great Bill Bell here
https://supportforums.cisco.com/message/3039692#3039692
Cheers!
Rob
Rob Huffman
Hi Yvonne,
Cheers!
Rob
that's a great post, thank you very much Rob and Bill
