03-22-2016 11:18 AM - edited 03-18-2019 11:53 AM
I am trying to create a phone template with more than 5 lines. We have the 8811 throughout our network and it has 10 buttons on the face, I just kind of figured it was a shame if you couldn't use more than just the 5 to the left. I tried to create a template that had 6 lines but it gave me an error when the phone tried to register. According to this: https://quickview.cloudapps.cisco.com/quickview/bug/CSCus85518 it is a bug present in our current firmware. It doesn't specifically say you can have more than 5 lines if I upgrade them to 11, but it does say known fixed releases. I just want to make sure that I can actually have more than 5 lines before I decide to upgrade the firmware.
Thanks in advance.
Solved! Go to Solution.
03-22-2016 11:47 AM
Hi Sean,
we can only configure up to 5 lines on 88XX phones, any other line configuration will move to KEM if it’s there. The below link confirms the same, refer section: Programmable feature buttons and Session.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/8800-series/english/adminguide/P881_BK_C136782F_00_cisco-ip-phone-8800_series.pdf
Demo video from the data sheet.
http://www.cisco.com/c/en/us/products/collaboration-endpoints/ip-phone-8851/index.html
As the defect states, configure expansion module with the latest firmware suggested to have more than five programmable lines supported.
-Venkatesh.
03-22-2016 11:52 AM
Hi Sean,
As my friend Venkatesh nicely noted (+5) the new firmware will NOT allow more than 5 lines but it does allow the phone to register even if it is configured with a Phone Button template that designates more than 5 lines.
Cheers!
Rob
03-22-2016 11:47 AM
Hi Sean,
-Venkatesh.
03-22-2016 11:52 AM
Hi Sean,
Cheers!
Rob
05-24-2017 05:38 AM
As of SIP firmware version 11.5.1, the CP-8811 will support up to 10 lines. If you download and install the latest Device Package for your version of CUCM, you will get a firmware version higher than this minimum version.
05-24-2017 05:56 AM
Awesome! I recently installed the device pack that updated the firmware to sip88xx.11-5-1SR1-1 so I should be able to configure more than 5 now? Is that correct?
EDIT: This is correct. I found that you have to change the line mode from Session Line Mode to Enhanced Line mode and now you can configure up to 10 lines.
12-04-2017 09:38 AM
Hello Sean,
What option is that under of the phone config page?
Matt
12-06-2017 08:58 AM
3rd item from the bottom on the Device configuration page. Option is Line Mode*
Change it from Session to Enhanced. Save. Apply config.
Voila, 10 line buttons instead of 5.
NOTE: 8841/8851 MUST be running 11.5 firmware or newer (my 8851 is running 11-7-1-17).
12-06-2017 02:33 PM
Upgraded to 11-7-1-17 but I still do not see that option under the phone config page of the 8851. What version of CUCM are you running?
12-08-2017 06:27 AM
12-08-2017 06:33 AM
12-08-2017 06:49 AM
Still do see those last three options and I am also running 10.5.2. Did you have to reboot your cluster to see those options or did you just upload cop file and restart the tftp service?
12-08-2017 12:45 PM
12-08-2017 01:05 PM
This is what I installed:cmterm-88xx-sip.11-7-1-17.k3.cop.sgn. Is there another upload it would need?
Matt
12-09-2017 04:30 AM - edited 12-09-2017 04:31 AM
Again, what you installed is a firmware for 88XX phones, it won't add the feature to the device configuration pages. You need to install the device package. A device package contains all the newest firmware for your CUCM version, and additional settings for the devices.
In your case, the newest device package you need to install is: cmterm-devicepack10.5.2.16134-1.cop.sgn
And you can download it from here:
Take under consideration:
12-09-2017 11:31 AM
Thanks.
